Question about Maxon MCB-30 40-Channels Base CB Radio
How do I wire this to my truck?
Where do the three wires (the red positive, the orange continous power, and the ground wires) connect to when I install this in my truck?
Thank you,
    Problem Solver:
The 'Red' (+'ve) wire connects through the ignition to a power source so that there is only power through it when the ignition is on. The 'Orange' wire connects to a (permanent) power source, and the 'Black' (-'ve) wire connects to any part of the vehicle's (metal) body or chassis. This only applies where the vehicle is a 'Negative to earth' vehicle.
Posted on Oct 30, 2008
Midland 77-118. Three wires coming out of unit red,black,and orange. What is the orange for? Also need manual.
Its like the wiring in your house. That little three prong plug. There are three wires, one black,one white, and one green. The green is a ground wire , the black is neg flow and the white is positive flow. Well the red wire is hot ,the yellow wire is neg flow,and the black is ground. Some times the yellow wire isn't even connected. Look inside your radio and you will only see a red and black wire???you will have to google the radio model as such ( 77-118 owners manual)
Sep 01, 2015 | Midland Radio Communications
Which wires go to what in the radio
ITEM - WIRE COLOR - POLARITY - WIRE LOCATION
12V - red - POSITIVE - ignition harness
STARTER - white - POSITIVE - ignition harness
IGNITION - red - POSITIVE - ignition harness
ACCESSORY - red - POSITIVE - ignition harness
SECOND ACCESSORY - yellow - POSITIVE - ignition harness
BRAKE WIRE - white - POSITIVE - brake pedal switch
RADIO 12V - red - POSITIVE - radio
RADIO GROUND - black - NEGATIVE - radio
RADIO SWITCH - yellow - POSITIVE - radio
RADIO ILLUMINATE - pink - POSITIVE - radio
POWER ANTENNA - gray/orange - POSITIVE - radio
LF SPEAKER - white - brown - radio
RF SPEAKER - green - orange - radio
LR SPEAKER - yellow - black - radio
RR SPEAKER - orange - blue - radio
Jul 02, 2011 | Hyundai Motor 2003 Elantra
IM TRYING TO WIRE A PIONEER DEH-5 TO MY STOCK WIRES IN MY 1996 VOLKS JETTA. I CHECKED OUT THE WIRING DIAGRAM ON THE JETTA AND SOME OF THE WIRES DID NOT MATCH UP,LIKE FOR INSTANCE THE SWITCHED WIRE ON THE...
Hi, the plain orange wire is the power wire. The constant wire is only for maintaining the station presets--it does not power the unit on. The other orange wires are for speakers. See the full color code below, and let me know if you have any more questions.
1996 Volkswagen Jetta Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Red/White
Car Radio Switched 12v+ Wire: Orange
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: Gray/Blue
Car Stereo Amplifier Location: If equipped, each speaker has an individual amplifier located at the speaker.
Left Front Speaker Positive Wire (+): Blue/Black
Left Front Speaker Negative Wire (-): Orange/Black
Right Front Speaker Positive Wire (+): Red/White
Right Front Speaker Negative Wire (-): Orange/White
Left Rear Speaker Positive Wire (+): Red/Light Green
Left Rear Speaker Negative Wire (-): Orange/Black
Right Rear Speaker Positive Wire (+): Blue/Light Green
Right Rear Speaker Negative Wire (-): Orange/Red
May 07, 2011 | Alpine CDM-7874 CD Player
How do i install the visors in my dodge stratus 2000 SE 2.0, and where exactly do i connect the power cords to to get the power to get them to work, and how do i connect them to my car video stereo ? if u...
connect the red wire to the red/white wire here is the wiring diagram
2000 Dodge Stratus Car Radio Stereo Audio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink/Yellow
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Orange/Brown
Car Stereo Dimmer Wire: Black/Light Blue
Car Stereo Antenna Trigger: Orange/Red
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
pls rate
Aug 17, 2010 | Pyle PLVSR72GR Sun Visor Monitor
I have a 2001 dodge ram, when I connect either the ground wire, power wire, or both from the cd player I am installing, all of the dash gauges quit working.
make sure your not connecting the power wire to the power for the gauges here is the wiring diagram
2001 Dodge Ram 2500 Truck Car Stereo Wiring Schematic
Car Radio Battery Constant 12v+ Wire: Red
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: Orange/White
Car Stereo Antenna Trigger Wire: Yellow
pls rate
Aug 16, 2010 | Car Audio & Video
On a Maxon MCB-30 cb radio, there are three wires. Red, Black and Orange. Red and black are the power and ground, but whats the point of the orange wire and what do you connect it to?
Hello stud
The orange wire is for memory retention for the last channel you were on if the red wire loses power as in switched on and off with the car ignition just hook up the orange to a 12 volt source that is on all the time. By the way those are some neat little radios wish I had one.
Ray
May 05, 2010 | Maxon MCB-30 40-Channels Base CB Radio
Wireing diagram/coloring?
Yellow: Constant Power (+)
Red: Switched Ignition Power (+)
Black: Ground (-)
White: Front Left Positive (+)
White/Black: Front Left Ground (-)
Grey: Front Right Positive (+)
Grey/Black: Front Right Ground (-)
Green: Rear Left Positive (+)
Green/Black: Rear Left Ground (-)
Purple: Rear Right Positive (+)
Purple/Black: Rear Right Ground (-)
Blue: Remote wire
Blue/White: Antenna wire
Orange: Running Lights
Orange/White: Dimmer Lights
Nov 26, 2009 | Pioneer DEH-345 CD Changer
Where do the 3 wires in back of my Cobra18wxst11 go? Can I use a cigarette lighter plug?
From www.Cobra.com
"Where do I connect the three power wires? (radios with 3 power leads)
Answer: Connect the black wire to chassis ground.
Connect the red wire to a switched +12 volt source, such as the fuse for the AM/FM radio.
The orange wire is for the memory retention of your CB radio, and should be connected to a constant +12 volt source. The fuse for the brake lights is usually a good choice.
With the radio wired as above, the radio will turn off when the ignition is turned off. The orange wire will provide power to the radio so that it remembers the channel.
If you are installing your Cobra CB radio in an application where you wish to utilize a cigarette plug to power the unit, connect the black wire to the negative lead (side terminal) on the plug. Connect both the red and orange wires together to the positive lead (center tip) of the plug. Your unit will function properly this way but will not retain the channel memory. When power is applied your radio will come up on channel 9."
Oct 23, 2009 | Cobra 18 WX ST 40-Channels Base CB Radio
I have a pioneer keh-p5450. can please send me a wiring diagram for this unit?
Here is the breakdown of what wire does what:
+Red..............12v ignition
-Black............Ground
+Blue.............Power antenna
+Blue/white.......Remote turn on
Orange...........Dashlight/dimmer
Orange/white.....Dashlight/dimmer
Orange/black.....Dashlight/dimmer
+White............Front left positive
-White/black......Front left negative
+Grey.............Front right positive
-Grey/black.......Front right negative
+Green............Rear left positive
-Green/black......Rear left negative
+Purple...........Rear right positive
-Purple/black.....Rear right negative
Oct 05, 2009 | Pioneer Car Audio & Video
Need a wiring diagram because the harness i boughtfor my cd player is wired slightly wrong
yellow wire - continous power
red wire - power ( when switch is on)
black wire - ground
blue wire - remote ( has power when switch is on) ( must be connected)
blue/light blue - rear right speakers
yellow/brown - rear left speakers
white/white striped - front left speakers
grey/pink - front right speakers
orange wire- dimmer lights ( not important)
these are the wires coming from car follow this diagram and you should be fine
Jul 22, 2008 | 2000 Oldsmobile Alero
Maxon MCB-30 40-Channels Base CB Radio Logo
201 people viewed this question
Top Maxon Radio Communications Experts
Steve
AnyMHz.com
AnyMHz.com
Mike Charette
Are you a Maxon Radio Communication Expert? Answer questions, earn points and help others
