Question about Sceptre X37sv-Naga 37 in. LCD Television
Flaw in display
I have an odd shaped dark region of pixels appearing in my 37" Septre lcd screen after about a year of regular use in all inputs and modes. Any thoughts?
  • 3 more comments
  • cconnors_71 Oct 31, 2008
    I have the exact same problem. a dark spot that almost looks like a water stain. it is less visible dependingon the predominant color on the screen at the time...for instance it almost disapears if the whole screen is blue. It is ver irritating and makes me seriously regret purchasing the tv if something like this happens only after a couple years of use!
  • RDW22 Dec 31, 2008
    I have exactly the same thing happening. It seems to be spreading to more area. This is so upsetting. It's only three years old & it all started about a year ago. I paid good money for this (A LOT more expensive back then) and to have such a flaw is frustrating!
  • unknownperso Jan 06, 2009
    Same problem. Started within first 6 months. Honestly thought it was something someone wiped across the screen at first. Should have demanded refund.
    Steadily growing.
    Will not purchase another.
  • ihatesceptre Apr 27, 2009
    Seems a lot of people are experiencing the same problem with areas of discoloration. Don't bother contacting Sceptre as their service department is not only rude but will avoid servicing anything even if it is still under warranty.
    Most people will notice movement and/or expansion and contraction of the discolored area making it either darker or lighter depending on which it does. Stick to name brand manufacturers that stand behind their product with a decent warranty.
  • puboxer May 07, 2009
    Did you purchase from Costco less than 2 years ago? Look here:http://www.costco.com/Service/FeaturePag...
I had the exact same issue. I bought a new tv for my family room and moved the Sceptre to a seldom used location. When I did turn the Sceptre on after a couple of months, it was good as new. The dark areas disappeared completely
Posted on Jan 08, 2009
Dark colored thick line in the screen picture
If it appears using any input - TV, Video, HDMI, etc. it is an internal fault and needs serious repair. If it appears on only 1 input it might be internal or external to the TV. Try feeding the same input with a different device.
Dec 10, 2013 | Proview PA-37JK1A 37 in. LCD Television
Pixelation
The problem is more or less with the LCD screen itself. The manufatcurer covers dead or burnt pixels.I would suggest contact Vizio Support on the following number
Technical Support
Toll-Free: 877.698.4946
Thanks
proton
Aug 09, 2008 | Vizio Gallevia GV42LF 42 in. LCD...
I have a LG 42LB5D 42" 1080 LCD television that
hi, usually you can correct this issue with only a few system checks, dark streaks can be caused by damaged pixels on the screen, in which case you need to replace the TV.
  • Inspect where the dark streaks are on the television. If the streaks occur at the same place on the top and bottom of the screen, they are due to the formatting of a movie or television show you are watching. This is normal. Also, if the streaks appear on the left and right of the screen, they are due to the show being filmed in full-screen instead of wide-screen. This also is normal.
  • Change the input setting so you are viewing the contents of a different device. If the dark streaks are gone, you know they are due to the device connected to it. However, if the dark streaks remains no matter what input the TV is connected to, the problem lies with the television.
  • Inspect the cable connection. Oftentimes when connecting a computer to an LCD TV, you can have strange dark streaks across the screen. Use a DVI-to-HDMI cable connection when plugging in your computer, then press the "Menu" button on your TV remote, select "Picture" and chose "Square Pixel." See whether the image adjusts and the dark streak goes away.
  • Contact the manufacturer of your LCD television if the dark streak remains. This streak can be caused by a defect in the television; if the TV is still under warranty, you can have it replaced.
  • Feb 02, 2011 | LG 42LB5D 42 in. LCD Television
    Dark spot on right side of LCD screen in the shape of Illinois has appeared gradually over the past few weeks. Very noticable between commercial and when news channels show graphics/slides. Pixels are not...
    In most of the case, the problem is a defective display LCD panel, this problem in some terminology is called PIXEL RETAINING, it means the pixels are locked up, there is no good permanent solutions for it, you have to change the LCD panel.
    Jun 02, 2017 | Vizio L32 32 in. LCD HDTV
    Magnavox 42"
    You are correct=====Return it ! It's new, you should not have to have it repaired this soon.
    Sep 23, 2009 | SNK Magnavox 42MF231D 42 in. Plasma TV
    "Display connected non-HDCP compliant" error
    The HDMI cable was causing "Display connected non-HDCP compliant" error message to appear.
    When I reconnected my DVD to TV using regular cable with 3 color connectors(i don't know what is the proper name for that cable) that error message no longer appears on my screen and I was able to watch my movie normally.
    May 17, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
    17 in monitor
    Set the resolution to match the new screen.
    In XP, Go to control panel, display, settings tab and change the screen resoution slider. If you have a regular shape screen (not widescreen) choose 1280 by 1024 pixels. If yours is a widescreen, choose 1280 by 768 pixels.
    Feb 20, 2008 | Acer AL1716 17" LCD Monitor
    Black/Dark Colors Fuzzy w/Red Pixel Outline
    Sorry, I haven't been on here for a while.
    I haven't found the cause. I find that leaving it switched on overnight cures it.
    Feb 18, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
    Sceptre X37sv-Naga 37 in. LCD Television Logo
    328 people viewed this question
    Top Sceptre Televison & Video Experts
    Henry  Thomas
    Henry Thomas
    Are you a Sceptre Televison and Video Expert? Answer questions, earn points and help others
