Question about GE (PSS26MSRSS) Side by Side Refrigerator
Freezer fan surges up and down
  • atlanta mom Nov 12, 2008
    I also have this problem. It started about 6 months ago. It drives me nuts. How do I fix it?
  • Danny W Dec 02, 2008
    Could you take another look at this problem? My GE Side by Side fan surges up and down loudly, the refrigerator gets too cold (freezing milk, etc.), and if I adjust the temps of freezer and frig, sometimes they "readjust" back to all 9!!!! (Coldest). Do I need to replace mother board?
  • 1,543 Answers
Don't worry, that is a variable speed DC fan motor. Fan speed is regulated by the mother board as needed.
Posted on Oct 31, 2008
I have a Whirlpool MFI2266AES and few days ago the ice/water dispenser stopped working. At the same time the freezer temprature started to rise and the temp alarm started beeping. The freezer fan was...
Hi, it sounds like your having problems with the thermostat ,they don't last for ever. I had the same problem with a fridge freezer and i got the temp thermostat replaced. You have a modern unit and you may have two but i think you have to look at the ice cube maker side first. Check that the water supply is getting to it.Have a look at your manual or you can type in the make and model and look up online .
Mar 06, 2014 | Maytag Refrigerators
Subzero 611 freezer not cooling
Could be but before that check if settings are working. Set the freezer settings to coolest and see if cools. If ok, set to desired temp.
Dec 30, 2013 | Refrigerators
My side by side fridge has stopped chilling down, the power is Ok, and moter seems to be working, but no cold inside. A few months ago the freezer side stopped, but as i did not use it , i just left well...
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Jun 14, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer fan in my GE side by side refrigerator surges and whistle
With you model and brand I would want to check the voltage on the fan and shaft play. Meaning the fan may be going bad or the voltage being altered at the motherboard. I do know your model with the control board that it has if a fan becomes defective the board is also affected. If the fan goes bad and replaced it is very possible that the board will fail and cause the new fan to fail. If you need help with diagnostics please let me know, Thanks, Sea breeze
Dec 13, 2009 | GE GSS20IEP Side by Side Refrigerator
We have a Kenmore model 596.71864101 that is probably around 10 years old. The freezer is doing what it should but the refrigerator is not cooling. It did the same thing a few weeks ago, but suddenly...
There is a fan in the rear of the freezer that delivers cold air to the frig. Turn temp control down to make the freezer call for cold, the fan should also turn on, even if the door is open. This is an easy self install if it is the fan.
Jul 08, 2009 | Kenmore Refrigerators
Fridge and freezer not staying cold but lights and fan working
the problem is going to more then likely in the main control board which is on the back of the refrigerator in a little compartment this board is bad about going out if you have power surges or outages
Jan 03, 2009 | Samsung RS2630SH Side by Side Refrigerator
The outside metal around the freezer area is very warm.
We were informed that because of a lot of power outages and surges that the freezer was in constant defrost mode. Since the freezer had been in constant defrost for at least 5 days, we were told that the condenser would probably short out. Even though the fridge was 7 years new. We decided it would be cheaper in the long run to get a newer more energy efficient one, because we didn't know what other damage had been done and if fixing everything would just be too expensive and it could quit before everything was fixed.
Sep 13, 2008 | Haier HTE18WAA Top Freezer Refrigerator
5 year old Maytag Wide by Side Refrigerator side not cooling
Same issue with my 6 yr old Maytag side-by-side model #MSD2756GEW. Turned out it was caused by a faulty circuit board. This circuit board is located in the upper right fridge section. Apparently these boards are sensitive to power surges (which we have here in central Texas from time to time.) When the circuit board is fried, it makes a noise like a fan blade malfunctioning and it stops the auto defrost feature in the freezer from working. So the freezer ices up at the back, and the ice prevents the cold air from reaching the fridge section.
Our circuit board (which we thought was a fan) made ominous noises for a few months. (The noise would last only a minute or so and stop shortly after we opened a door). Eventually we noticed that the fridge wasn't as cold and the freezer had snow in it. Finally the board stopped making noise and about a week or so afterward we noticed that the milk had spoiled and the fridge wasn't very cold. The food in the freezer side pretty solidly frozen, thankfully.
In addition to replacing the circuit board, the fridge had to be de-iced or it would not work properly. I put it all frozen into a large camping cooler where it stayed for several hours. I opened the freezer doors and put table fan and pointed a hobby light which gets quite hot, at the back of the freezer. Within 3 hours, the ice had melted significantly so I could see through the grate at the back of the freezer. This really great technician named Tracy, made a special trip to the parts store to get the circuit board and came back within a couple hours, bringing with him a steamer. He removed the back panel inside the freezer section (the coils are behind there) and used the steamer to melt the rest of the ice before he left.
Tracey, who works for a local appliance repair company, told me that about 4 years ago, Maytag started making their fridges with built-in surge protection, so the circuit boards apparently don't get fried on the newer models as they do on my 6 yr old model. He recommended that we put plug the fridge into a heavy-duty surge protector - which we are definitely going to do.
Feb 13, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
Clicking noise on and off every 2-3 mins
compressor has locked up -- call maytag -- if its less than 5 yrs old it might still be under the sealed system warranty -- which means its fixed free of charge.
Dec 13, 2007 | Maytag MBF2256H Bottom Freezer...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
216 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
