Question about Whirlpool Refrigerators
Rust at bottom of molding around ice & water opening on freezer door
How do I get the molding off to fix the rust problem, I'm told to just slip a puddy knife in and it snaps off, is this true? Model # is ED25TDXFN01 Built 4/98 Wally e-mail wawa@aloha.net home phone in Hawaii 808-329-9651
  • wawa408 Nov 02, 2008
    I used aputty knife and it worked, job done. My appliance man told me the same thing. Wawa408
  • 59 Answers
Yes, slip a puddy knife or flat screw driver under the bottom edge and then twist and pull the trim out until it snaps free. There are two slots on the bottom that will easily accept a screw driver.
Posted on Nov 02, 2008
Freezer door is rusted at base of the water and ice dispenser. What causes this?
Rust is cause by presence of water
you either have condensation (due to we insulation) or some kind of water leak.
Jul 21, 2014 | Hotpoint HSS25GFP Side by Side...
Our ice maker has rust on ice sometimes and can't understand why or how to fix
You would need to remove the ice storage bucket and dump the ice, check the corkscrew wire in the bucket for any signs of rust, some auger wires were chrome plated and not aluminum. If no rust there, remove the ice maker it's self and check the ice making mold for signs of rust. Replace all rusted parts found. Pleazer Appliance...
May 06, 2014 | Frigidaire GLRS237ZA Side by Side...
MY FREZER HAS FROST AROUND THE DOOR AND MOLD IS GROWING AROUND IT
You need to replace the door gasket. It's leaking air causing the frost.
May 04, 2011 | Whirlpool Freezers
I have what appears to be a water leak of some kind in the freezer section near the ice making part of the freezer. You can tell because the freezer is building up ICE all around the bottom of the ICE...
Check to be sure your ICE door chute is closed or closing properly! I have encountered many of these units that have had the flap break off the mounting tabs inside the dispenser opening. If the flap appears to be intact, I would next guess that your ice maker timing is allowing the ice maker to over fill and spill water into the ice bucket.
You can confirm this problem by looking at the ice maker and seeing if the ice cubes in it are filled right up to the center bar that drives the cubes out of the mold.
Let me know if you have any more questions!
Thanks, BOB
Aug 18, 2010 | KitchenAid KSBP25FKSS Side by Side...
How to get to the drain line on my Frigidaire side by side refrigerator model number MRS22WNGW7. Water keeps coming out of the freezer side onto the floor (front left side). I was told it could be a...
I just opened up the back of my Frigidaire Side by Side counter depth to find the drain hose was bent and collapsed coming right out of the bottom of the freezer and the pan was dry as a bone. It doesn't look like my drain hose has ever drained a drop of water. The freezer bottom is full of ice And the rust and chipping paint under the bottom of the freezer door along with the mysterious puddles of water every morning means the drain system definetely never worked. Frigidaire should be responsible for this. This, along with the ice maker rebuild I had to do,... after ice was spilling all through the fridge. I actually had warrantty left on that one and called customer support in India to find out I could make the repair myself. Yep I had to do it. Frigidaire you failed.
May 14, 2010 | Refrigerators
I have rust on the front of the door, just below the ice/water dispenser
if the door is stainless steel, use a little steel wool to lightly rub the rust out rub with the grain
Oct 30, 2009 | Samsung RF265AA Bottom Freezer French Door...
Rust ruining door at lower corners of ice/water dispenser.
when you dispense ice or water, you are allowing the drip tray to overfill and the water builds underneath the tray until the water reaches the point were it will leak down the front of the door. the water will rust the panel beyond repair. you will have to replace the whole door at this point. hope this helps.
Oct 20, 2009 | GE GSS22JEM Side by Side Refrigerator
How to get the icemaker overlay off the freezer door on modeled25rf
Slip a puddy knife or flat screw driver under the bottom edge and then twist and pull the trim out until it snaps free. There are two slots on the bottom that will easily accept a screw driver.
Oct 29, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Rust
assuming that this is not stainless steel model, for that shouldnt be rusting. but that being said if you look closly at the underside of the facade surrounding hte dispensor youll see 2 little slits approx. an inch in from either side along the bottom, gently pry off with a screwdriver from theses points,( should twist off and lift up, to reinstall simply "hang " on top clips and snap back down into positon.
Jul 07, 2008 | KitchenAid Superba Architect KSCS25INSS...
Ice door opener
GE side x side GSS22SGMC stainless steelJust fixed my own problem of jammed ice door. 1. pull the light switch plate off (just under the front bottom edge, push through the holes, pull) 2. unscrew the dispenser assembly, 4 screws, pull the unit out  3. WR62X10020 SOLENOID is in the upper right, unplug the black wires from the board. 4. unscrew the right screw from the door-stop assembly (above the ice door)- pull the plastic out of the solenoid piston 4. unscrew solenoid, 3 screws, from back 5. pull the piston, scrape-sand-file off all rust, then lube with oil 6. scrape off rust from inside,  solenoid with shoving steel wool-file-degreaser to get off rust, then lube 7. reassemble, WORKS!! 8. save 35.00 for new solenoid 9. save repair cost of whole new door (happened!) good luck
Feb 20, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
111 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
