Question about Kenmore 2.1 cu. ft. Portable Top Load Washer
Kenmore portable washing machine does not drain water properly
I have a 3.5 year old Kenmore portable washing machine, and all of sudden it does not train the water properly into the sink. I would like to find out what possibly could be a problem, and how to fix it before I ask for service from the Sears. Thanks, Kay
    Genius:
  • 1,122 Answers
MOST KENMORE MORE WASHERS THE LID SWITCH DOES BAD FROM CLOSING ALL THE TIME,YOU CAN REMOVE THE LIP SWITCH WIRES(2 OF THEM) WIRE THEM TOGETHER AND YOU HAVE BY PASSED THE SWITCH AND YOUR DONE,LET ME KNOW HOW YOU DO-MIKE
Posted on Nov 01, 2008
Kenmore washer - water won't drain. It stops
If the water drains between the wash and rinse cycles, your motor and pump are probably OK. If this is a machine with a dial, try a different cycle, like normal instead of heavy duty. If that works and the machine completes the entire cycle then the timer probably has a bad spot. You might try to find a replacement timer if that is the case although I didn't have any luck with my 10 year old washing machine. Best of luck
Mar 20, 2010 | Washing Machines
Front loading washer won't spin
my amana washer wont spin and does not drain
Sep 11, 2009 | Kenmore Washing Machines
Kenmore 70 series top loadwasher does not completely drain water
the smell is raly bad because it doesnt drain all the water out , so it sits there. if all else with the machine works well, this means the water level sensor needs replacing
Jul 19, 2009 | Washing Machines
Drum doesn't move or spin
kenmore tumble action washer model#417.44152400,
Washer is approximately 3 years old. Will not drain or spin. When it tries to spin, clicking noise heard inside of unit. Would a clog insie the lines disable the spin cycle ?
Oct 18, 2008 | Kenmore 43142 Front Load Washer
Kenmore 44722
You need a new circuit board. Sorry, no way around it, the board needs replaced. You didn't mention how old your machine is.
Jul 22, 2008 | Kenmore 2.1 cu. ft. Portable Top Load...
Kenmore 90 washer won't drain
Check first drain line or water pump to see if they are clogged.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump.
Jan 14, 2008 | Washing Machines
Kenmore 2.1 cu. ft. Portable Top Load Washer Logo
422 people viewed this question
Richard Roth
Richard Roth
Archaeology
Archaeology
Fordexpert
