Question about HP Business InkJet 2800 Printer
Light bar displayed on the photo print.
We have a printer and it is used to print high quality photo prints such as advertisments. But the printout has light shaded bars and it is very obvious as the photo picture on the screen is very perfect.
The printer is new and about 2 months old, since the HP warrenty guys are headache hence trying to find real problem so as to convince the guys.
You may have had a cartridge leak especially if you have used remanufactured cartridges. It happend to me. I had to take it all apart starting with the screws underneath. You will need an allen wrench. If your lucky you might be able to avoid taking it apart. wipe down all electrical connectors with alcohol swabbed fabric and blow it out with compressed air. Use only an electronic safe cloth soaked in alcohol or electronic cleaner.
I wiped down everything, then used a compressed air can and blew it all out. After putting it all back together and aligning/cleaning the printheads it worked fine again.
Posted on Dec 11, 2008
Hello , I think during the firstinstallation I missed something because I do not see colors properly. are very pale. I do not know how to give a general reset.
Perhaps you need to adjust the printer settings in your computer?
Pay special attention to the print quality settings (if Draft mode is default, then you'll get weak colors), and to the paper (media) type - it won't let you print photo quality printouts on plain paper, as normal paper cannot accept too much ink (it would get soaked and colors would blend ugly).
If you put in high quality, expensive photo paper, and in the settings the paper would be set to "plain paper" - you'll get washed out colors on the printout, because the print driver in your system thinks that the paper is ordinary and limits the amount of ink used.
Please come back and leave a rating/testimonial if helped or post a comment for further assistance.
Thank you for using FixYa, the community-based help site :)
Jul 28, 2011 | HP PS C4780 All in One InkJet Printer
Do I need a special paper for this printer?
no not necessarily. I suggest you align your printer tray in such a way that it will instantly insert the paper and print it successfully. Otherwise the problem is maybe the unit itself or the drivers..
Mar 09, 2011 | Dell Inkjet 720 Printer
PRINTING ON PAGE IS VERY FADED AND SOME PARTS NOT PRINTING AT ALL
First, checkthat the USB cable is secure in both the printer and the computer and that theprinter is sitting on a flat surface. The printer may not work if it is tilted.
Next, run a printer check to make sure the printer is operational. To run aprinter check, turn off the printer and the computer and unplug the USB cable.Turn on the printer and press the Maintenance button. Use the down arrow buttonon the printer to highlight More Options on the display screen and press OK.Highlight Nozzle Check and press OK twice. If a page prints out, reinstall theR300 software on your computer.
Lines inPrintout
R300 mayproduce printouts with light horizontal lines that are not a part of theprintout. This is called banding and can have several causes. First, trycleaning the printer head to clear any clogged nozzles. To clean the printerhead on the R300, press the down arrow button to highlight More Options andpress OK. Use the arrow buttons to highlight Head Cleaning and press OK twice.The printer will take about 30 seconds to clean the print head, after which youshould run a printer check as described above. If the printout has gaps, pressthe STOP button to run the print head cleaning feature again. Once there are nogaps in the printout, press OK.
If the printout still has banding, open the Print window on your computer andclick on Properties. In the Properties window you can choose the print quality,speed and printer type. Select a higher print quality and a lower speed andmake sure the paper type matches the type you are using for the printout.
Finally, check that the ink cartridges are not empty or close to empty andreplace them as needed.
Faint Printout
If your printout looksfaint or faded when using the R300, try cleaning the print head. Next, replaceany ink cartridges that are old, low on ink or out of ink. Check that the papersetting on the computer matches the type of paper you are using for theprintout.
Another potential cause of faded printouts is incorrectly loaded paper. Sometypes of paper have a printable side that is whiter or shinier on one sidecompared to the other. The printable side of the paper needs to be loaded intothe printer face up.
Nov 20, 2010 | Epson Stylus Photo R300 InkJet Printer
Horzontal white lines cut through print and picture copies. When doing head allignment the horozontal bars all have a white gap, 1 through 7. Epson Stylus CX5400
You don't need to do head alignment, because it is for vertical banding in printout. Vertical banding can be minimized by disabling high speed option without doing head alignment. If your printout have horizontal white lines, do check nozzle and head cleaning, or you can minimize white lines by printing in best quality (photo).
Oct 21, 2009 | Epson Stylus CX5400 All-In-One InkJet...
When I print photos, they have uniform vertical streaks.
Issue: Banded or streaked prints
Solution: Change the Print Quality Settings (Windows)
Change the Print Quality Settings (Windows) The Quality setting controls how finely ink droplets are placed on the printed page. Depending on the type of paper being used a higher Print Quality setting does not always insure a better print. Print speed will decrease as the Print Quality setting is increased. Follow the instructions below to change the print quality settings in the Canon printer driver for the Windows operating system through a printing application.
  1. Click 'Properties' in the Print dialog box.
    Note: Depending on the Application software, 'Properties' may be displayed as 'Preferences'.
  2. Set the desired print quality in the 'Print Quality' section.
  3. Select 'High', 'Standard', or 'Draft / Fast'.
To set more detailed print quality settings, follow this procedure:
  1. Select 'Custom' and click 'Set'.
  2. In the Set Print Quality dialog drag the slide bar from 'Fast' to 'Fine' to select the print quality.
    Note: There are five options in 'Quality'. However, selectable options are limited depending on the media type.
  3. Select 'Auto', 'Dither', or 'Diffusion' from the 'Halftoning' section.
Apr 22, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Ink not printing the same image quality that is on computer
Issue When printing directly from a memory card, the printouts have an abnormally high red tone.
NOTE: This does not affect the prints that were originally sent from the computer. Solution Press the Photo Fix button to turn off the Photo Fix feature before printing from a memory card. Cause The Photo Fix feature was originally designed to reduce/enhance printed pictures by making colors more vibrant. However, it can also have a side-effect to make some prints have more red tone than desired. In the HP Photosmart D7100 series printer, this feature is “ON” by default.
Dec 15, 2008 | HP Photosmart D7160 InkJet Printer
Photosmart C6300 pictures are printing very wet and grainy. printer is also very loud - almost as though the parts were scraping and banging.
Sounds like you have the wrong paper setting in your print properties. I would use photo or high bright 24lb paper and set the paper type in your printer properties prior to executing the print job.
Regards,
Worldvet
Nov 12, 2008 | HP Office Equipment & Supplies
Photos are not good
Make sure that your quality is set to best and you are using a high quality photo paper for maximum resolution and quality.
Jun 11, 2008 | HP PSC 1210 All-In-One InkJet Printer
Poor quality printouts from my canon mp150
before printing check the quality printing in printing preferrences to change it to best or normal.
Dec 04, 2007 | Canon PIXMA MP150 All-In-One InkJet...
HP Business InkJet 2800 Printer Logo
48 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
