Question about HP LaserJet 4200tn Printer
Hp 4200 tn networking problems
I changed phone and isp providers today and once the printer was reconnected, none of the computers on the network could locate it. I can't even ping the ip address. Everything else on the network is functioning properly.
    Scholar:
  • 101 Answers
I would suggest, print a diagnostic page from the printer, what IP address does it show? It is on the same network as your computers? If not then it will require changing the printer to either DHCP or giving it a static IP within the same range as your other workstations.
Posted on Jan 08, 2009
Can't find sharp ar-bc320 driver for 64bit, there's only PCL5 driver which won't work, we need PCL6 driver for this model.
Sharp does not natively support or provide a PCL6 driver for this device. That being said, another possible workaround to provide you with a PCL6 driver for this is to try the HP Universal Print Driver for Windows PCL6 x64bit. This driver simply prints direct to the IP address that the printer uses on the network. You may sacrifice a few special features of the device using this driver, but I've had excellent success with it and recommend trying it.
Here's a link to the driver:
http://hp.driversdown.com/hp-drivers-download/HP-Universal-Print-Driver-for-Windows-PCL6-x64_18967.shtml
Hope this helps!
Jun 20, 2011 | Computers & Internet
My HP 309 series printer will not stay connected to my wireless network. Can someone help? I end up having to go through wireless network wizard all over again with my WEP password. Very time consuming!
Hello geekgurl !
There are a few things you have to check
When choosing a location for your wireless router, avoid having the following items between the wireless router and wireless devices on the network: long distances, walls, other wireless devices (like cordless phones), and large appliances.
Don't use two wireless routers in your home unless you are very knowledgeable about wireless networking. If your Internet Service Provider (ISP) provides your wireless router as part of their equipment, don't add another wireless router to it or attempt to change the existing settings without the ISP's help or knowledge.
Make the following settings on your wireless router, or verify that they've already been made:
1-Change the manufacturer's default name for the network name (SSID) to something unique.
2-Set the broadcast SSID to "on" or "enable". Note that "on" or "enable" is typically the default setting.
On the printer:
1- See if the wireless indicator lamp is illuminated. Can you turn on the wireless radio from the control panel of the printer?
Print a Network Configuration page and a Wireless Network Test report from your printer's control panel, if available.
* Does the Wireless Network Test report indicate trouble?
* Do the reports indicate that the printer is connected to your wireless router, and not to a neighbor's? The network name the printer is connected to will be shown on the both the Network Configuration page and Wireless Network Test report.
* Compare the printer's IP address to the gateway IP address. They should have a similar format (for example, the gateway IP address might be 192.168.0.1 and the printer IP address 192.168.0.5). If the printer has an IP address similar to 169.254.XXX.XXX, it probably is not connected to your wireless network.
* On some printers, the Network Configuration Page will list all wireless networks detected in your area. Is your network listed among those found? Does it have good signal strength?
* Are there several networks on your same channel or using channels close to your channel? You should use a channel at least 5 channels away from the closest used channel. Consider changing your wireless router's channel to 1, 6 or 11.
* Make sure your computer is not connected through a VPN (Virtual Private Network). You cannot access devices on your wireless network while connected to a VPN.
* Disable your operating system's firewall and your security system's firewall and re-test. If this fixes the problem open ports in the firewall.
HP's Network Diagnostic Utility can also be useful
Visit this link
http://h20180.www2.hp.com/apps/Nav?h_pagetype=s-926&h_lang=en&h_client=s-h-e013-1&h_keyword=dg-NDU&jumpid=ex_r4155/en/hho/ipg/easy_wireless/network_diag/
Check if theres anyway to set an Static IP (does not change) on your printer instead of a Dynamic Hp (constantly changes)
Good Luck !
Aug 13, 2010 | Office Equipment & Supplies
Wish to setup hp k550dtn printer with ethernet support to a wireless trendnet router..432BRP. Two laptops will share this printer
You can use a print server to connect your printer to your computers over the ethernet/wifi connection, All printers will be using a network printer..
OR..
You can Attach the printer onto 1 of your computers, set the properties to share the printer, and then set up a new printer on the other computers (network printer)
Make sure all the computers on your home network are on the same WORKGROUP
Jul 17, 2010 | Trendware TRENDnet TEW-432BRP 54Mbps...
I am trying to locate the ip address on an office hp 4200n
Usually you can print a configuration page and it will tell you the IP address that is assigned to the printer. You should be able to use the small menu screen on the printer to navigate to, and print a configuration page, or use it to navigate to the network settings to view and/or edit the current configuration. If all else fails, sometimes you can run Angry IP Scanner on a computer that is on the same network as the printer and see if any of the hosts come up with a name that matches the printer, then you will see the address of that host.
Jul 20, 2010 | HP LaserJet 4200 Printer
LaserJet 4200 Printer: HP LJ 4200 has Jetdirect card that worked fine unt...
Is the jetdirect card part number a 615n? If so, replace it with a 620N. The 615 cards were bad from the get go. Hp recalled them for about a year providing free upgrades to the 620.
May 16, 2010 | HP LaserJet 4200 Printer
Linksys router connects and says it has an excellent signal but will not aquire an address please help
Try a hardwire computer and get into the setup page of the router by typing 192.168.1.1 on your browser . Make sure you have changed the SSID or the network name of your router to your choice. Check if you have security set. If you have one make sure they match your computer.
Nov 11, 2009 | Linksys Wireless-G Broadband Router
Hp laserjet 4200 printer- how to find the current ip address?
To have an IP address for the printer you must either have a HP4200n or install a Jetdirect card into the printer. The Jetdirect or "N" version of the printer with the built in Jetdirect holds the network IP address. Subnet Mask, Gateway Derfault and handles the networking functions. If you have a 4200n or Jetdirect installed it will print out on the configuration page.
The standard HP 4200 doesn't have the networking capability without adding the card. In the event that you have a card installed and its not recognizing the card on the configutation page it may be bad. The HP 615n cards are known to have burn out issues. If you have to install a card to upgrade your printer, I recommend a HP 620n or better to get around the known bad issues with the 615n cards.
Jul 07, 2008 | HP LaserJet 4200 Printer
Network connection
search for the network tab in the printer menu ( the setup isnt done from the computer)
and update the wanted IP address according to your network rules
Apr 06, 2008 | HP LaserJet 4200 Printer
HP LaserJet 4200tn Printer Logo
266 people viewed this question
Seeker5211
Seeker5211
