Question about Husqvarna Rose
MACHINE SEWING IN REVERSE
I PURCHASED A USED HUSQVARNA VIKING ROSE MACHINE AND WHEN I TURNED IT ON TO SEW AND IT IS SEWING IN REVERSE. I HAVE READ THE INSTRUCTIONS BUT CAN'T SEEM TO GET IT OUT OF REVERSE. ANY HELP WOULD BE GREATLY APPRECIATED.
  • amjstark Apr 13, 2009
    I, too, have the same problem. This machine, however, has been sewing for years in the forward and backward. My last project ended with reverse sewing and I can't seem to get it out of reverse again. HELP!
  • 3 Answers
If you have located the reverse button and pressed it once - this should shut off that feature. If this does not, then I am afraid you are going to have to take it in to be reprogramed. Any local shop that is familiar with Husky should be able to help you out. Good Luck!
Posted on Nov 19, 2007
SOURCE:
What does the dongle for an old Viking Rose sewing machine look like?
Contact these people. They are the best supplier and may be able to help you.
Husqvarna Viking Sewing Machine & Serger Parts - Sewing Parts Online
www.sewingpartsonline.com/viking-sewing-machine-parts-model-list.aspx
  1. Cached
  2. Similar
If you can't find the Husqvarna Viking Part(s) you are looking for, send us an email at info@sewingpartsonline.com or click here to contact us. Or, shop for Husqvarna Viking Presser ... 250C Eden Rose · 2840 · 305 · 3310 · 340D · 341 · 341D.
dongle for an old Viking Rose sewing machine Google Search
Apr 14, 2017 | Sewing Machines
My Husqvarna Viking model 6000SL Sewing Machine would only sew in reverse the dealer has got it to sew forward but says the cam is jammed and he cannot get it off can you help?
You will need to have it serviced by a Viking Service Tech. You can find a dealer near you by using the link 'Locate a Dealer' at the Husqvarna Viking Website - http://www.husqvarnaviking.com/us
If the local dealer cannot repair, they can send it to the Viking Service Center in Nashville, TN for repair.
Jul 12, 2014 | Husqvarna Viking 1
How do you remove the rose sewing machine case
That's a tricky fix. I recently fixed one (I'm a Service Tech). The spring is wedged into the front cover in the housing. The sewing head has to be removed to access the area. Suggest you take it to an Authorized Viking Dealer to have the work done. You can find the nearest Viking Dealer by going to Viking website - http://www.husqvarnaviking.com/us and clicking on Locate a Dealer
Feb 24, 2014 | Husqvarna Designer I
Need an operation manual for a viking rose
try these sites
sew usa
sewing manuals.com
ebay
Jul 23, 2010 | Husqvarna Rose
The presser foot is down but the machine thinks it's up and won't sew
Sounds like a sensor needs to cleaned or reset. This will have to be done by a certified Husqvarna Viking service technician. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
Jan 20, 2010 | Husqvarna Rose
Have a Rose Husqvarna sewing machine and just purchased a Designer SE. Purchased a Rose reader writer for my cards and want to put them on the computer to use with my Designer. Can not find any...
If you bought your SE from a dealer they will be able to transfer those designs for you. If not, you need the Husqvarna Viking software so you can "read" the designs from your rose cards into your computer, then you will be able to send them to your USB stick for the SE.
The software really unlocks the potential for that machine. The first module of the software is about $400, comes with about 100 fonts and many designs and abilities to alter the text you want to sew. If you go up to the $900 option, you can cut designs apart and save different aspects of the design by themselves and also get an automatic digitizing option that works well. Husqvarna's web site shows their software in detail.
Oct 08, 2009 | Husqvarna Rose
I have a Husqvarna Viking quilt 870 sewing
The overload message is usuall due to a bind in the mechanical function of the machine. When the motor has an extra "load" caused by something like a tight belt or dry bearing, it "overloads" the motor and the error message is displayed. It is doubtful your problem is computer related. Either way a trip to your service tech is required. If you continue to sew with it, you do run the risk of possible damage to some other parts of your machine. The computer portion of your Husqvarna is guaranteed for 5 years and the mechanical parts carry a 20 or 25 year guarantee depending on when you purchased your machine. A copy of your bill of sale from a Husqvarna Viking dealer or a stamped warranty card is the proof of purchase needed to obtain warranty replacement of parts. Labor is only guaranteed for 1 year.
Sep 26, 2009 | Husqvarna Viking 1
Buttonholes
Put on the C foot. Select the buttonhole stitch. The machine will start sewing in the bottom left corner of the the buttonhole. Sew the length that you need, press and release the reverse button and sew the right side of the buttonhole. When you get back to the bottom, press and release the reverse button again and the buttonhole will be finished and the thread will tie off and the machine will stop. If the buttonhole is what you want, press and release the Stop button and the machine will repeat this buttonhole as many times as you need until the machine is turned off or the Stop is pressed again. When repeating, you need not press the reverse. Just press down on the foot control and continue until the machine stops by itself.
If you don't like the first one, just sew another one using the reverse button to set the ends.
Jun 28, 2008 | Husqvarna Viking 1
Sewing Machines Logo
200 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
MissFixIt828
Level 1 Expert
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
