Question about Xerox Phaser 8400 Laser Printer
Printer error 07,010,43;6662
Printer switches on but does nothing other than the above mentioned error.
    President:
  • 2,072 Answers
That is the print head tilt. 1 of two things is the normal cause.
There is a print head block on the lower left side of th frame about 2/3rd of the way back and near the bottom of the frame. It gets contaminated with ink and needs to be removed and cleaned.
The other is the print head wiper that is located between the print head and the drum has tacked to the print head. You neet to access the print head area and gently detack it from the print head.
Posted on Jan 05, 2009
SHOWING ATTENTION REQUIRED PRINTER HAS A PROBLEM THAT REQUIRES YOUR INTERVATION
The page at the link below has a comprehensive listing of all of the error codes for your printer.If you do not find an answer there, you may need to find and install drivers for your printer.
PIXMA Printer Error Codes and Error Messages
Apr 28, 2015 | Canon PIXMA Office Equipment & Supplies
Error 0xc18a0106
This is most common error in inkjet HP inkjet printers.But you are not mentioned model number, any how try this:
Step 1.
> Remove all the supplies like print heads & cartridges..
> Remove USB or any other device connectivity from system.
> Switch off the printer.
> Wait couple of minutes.
> Switch on the printer, wait till printer asked for the supplies.
> Insert supplies as per specified messages.
> Check for ready mode, insert data cable & give print command.
>>>Check.. no message.. END.
Step 2:
> If problem remain same..(I will suggest for tech guys)
> switch off the machine, remove all the supplies
> Open printer side covers.
> find out the CMOS batter mounted on formatter ,remove it..
> wait couple of minutes..
> with out CMOS batter do the above said step 1 process.
> check.. I hope it will resolve this issue..give print command.. verify..once its resolved CMOS batter has to be installed.
> Switch off the machine,
> insert CMOS battery,
> do again step1 process,,..
......END....
Best of luck...Thanks for choosing FIXYA
Dec 12, 2011 | HP PhotoSmart Office Equipment & Supplies
Error code 0xc19a0035
Step 1.
Step 2:
......END....
Dec 09, 2011 | HP PhotoSmart Office Equipment & Supplies
Unable to clean error message
just swith of the printer even the swich of the main switch where the printer's plug is connected wait for 40 second then power it on again it will start working again if everything is connected perfactly
May 07, 2010 | Brother MFC-5840CN All-In-One InkJet...
My printer says its not aligning and is only shooting out blank paper
please try the following steps :
1.disconnect the power cable from the back of the printer
2.press and hold the power button for 20-30 seconds
3.reconnect the power cable back to the printer
4.restart the printer
if you still get the error message then try cleaning the cartridges(follow the documents to clean and reinstall the cartridges )
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01578490&cc=us&lc=en&dlc=en&product=374568
from the above mentioned url only follow the clean cartridges step and no other steps
if still nothing happens , try doing a reset from the below mentioned url :
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01577214&tmp_track_link=ot_recdoc/c01578337/en_us/c01577214/loc:1&lc=en&dlc=en&cc=us&lang=en&product=374568
only follow the step to reset the printer from the above mentioned document
if still nothing works
5.check for a paper jam
6.try and move the carriage manually and check if it moves freely or not
if nothing works contact HP they may replace the printer for you if the printer is under warranty
if still you have a problem let us know we will surely help you out :
hope this works (BEST OF LUCK)
thanks
regards
Hamid
Feb 23, 2010 | HP PSC 1315 All-In-One InkJet Printer
Printer sends error message HP p2015
As mentioned above, install the universal PCL 5 drivers from HP website. This will fix the error.
Feb 23, 2009 | HP LaserJet P2015 Printer
Nothing prints when documents are sent to printer
You didn't mention whether the error was given by the printer or by the PC but I'll give you a couple of tips for troubleshooting this...
Switch the cable to another port on the PC to see if the OS identifies it (if you're using Windows you'll get an audio sound when it gets plugged in). Try to print to it from the new port.
Worst case scenario follow this link to download and re-install your print drivers.
Feb 21, 2009 | Brother MFC 420CN All-In-One InkJet...
Kyocera 3900DN Error Code
F030 General failure
Miscellaneous failure with the main
PWB, other than F000, F010, F020,
F040 and F226, above.
Defective main-PWB
Turn the power switch off/on to restart the
printer.If the error is not resolved, replace
main PWB
Sep 04, 2008 | Kyocera FS-3900DN Laser Printer
INTERNAL ERROR--FALSE
My printer was able to print an "INTERNAL ERROR - FALSE, Position: 0x1227e (74366)" error message as well as a test page, but not documents sent to print.
However, the problem was fixed once I switched to another USB port as the person above mentioned. So for any other people with similar problems, try that! In addition to power cycling the printer (I did that first)
Jan 23, 2008 | Samsung ML 2010 Laser Printer
ERROR CODE 6C00
The printer has a Reset mode- somewhere. But different makers/models have different settings. Try the manual and if not mentioned there try the Canon website. Failing that try this- with the printer switched off press a combination of 2 buttons[any 2] with them pressed switch the printer on did it reset?- then try another combination. take a look also at www.fixyourownprinter.com also here http://www.fixya.com/support/p360551-canon_pixma_mp780_all_in_one_inkjet
May 14, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Xerox Phaser 8400 Laser Printer Logo
106 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
