Question about Samsung Yepp YP-Z5AB / YP-Z5AS MP3 Player
Samsung YP-Z5 malfunctions and can't connect to pc
Samsung YP-Z5 cannot play files via Music folder etc, only through 'Browse Files'. When turned on, resets to default settings and wrong time. Can't upload or remove songs, as it doesn't connect to pc. Stuck.. Emailed samsung through their suggested online support system, but they didn't reply. Obviously, I cannot upgrade firmware, as PC doesn't recognise device anyway (even in UMS). Reset doesn't do anything, and when I check for Version in System Info, it displays System Error. Apparently some file inside the YP-Z5 must be corrupted, but how can it be fixed when it's impossible to access the device via pc and the reset button or 'reset settings' option don't have any effect? See thread:
http://www.fixya.com/support/t209637-samsung_yp_z5_connect_pc
  • 1 more comment
  • Anonymous Jan 08, 2009
    ya, its pretty screwed up, i finally found someone with the same problem, quite disspointed that Fixya don't have any solutions even though i have been reading through this site for my spoilt YP-Z5F for at least 1 year...
  • Anonymous Jan 11, 2009
    Ugh, Yea same thing happened to me. Exactly
    like that.
  • chunderiii May 17, 2009
    Same thing has happened to me.
SOURCE:
SOURCE: other way to sync the yp-z5 withought windows media player
Hi, I recently spoke to the tchnicians from Samsung who put me onto the Samsung website where you can download the Samsung media Player. That also allows you to sync the unit. Thanks
Posted on Apr 25, 2007
SOURCE: Samsung YP-Z5AB/ELS mp3 player problem
...Samsung returned my player after 3 weeks. Some problems fixed, but not all. Their customer service & tech support lines are hopeless, and eventually suggested I return the unit to Amazon ! Amazon have agreed a refund & Samsung have lost a customer permanently. It's a shame because this could be a great player if the internals were up to the mark.
Posted on Jun 19, 2007
SOURCE: Samsung YP-z5 won't connect to the PC!
This might help getting it connected to the computer.
UMS mode allows the Z5 to interface to the computer as if it were a removable hard drive. You can then use Windows File Explorer to manage the files in the Z5.
To get into UMS mode, connect the Z5 to the USB port while simultaneously holding down the "return" button (the top of the square keypad) while connecting. This will put the player into UMS mode for that connection period only.
If you upgrade to the new firmware, you have the option of making it always connect in UMS mode.
The steps to install the latest firmware are:
(1) Download version 2.37 or newest of the Z5 firmware http://www.samsung.com.
(2) Unzip it to get the file named "Z5Update.dat".
(3) Disconnect the Z5 from the USB port.
(4) Reconnect the Z5 to the USB port while simultaneously holding down the "return" button (the top of the square keypad) while connecting. This will put the player into UMS mode for that connection period only.
(5) Open a File Explorer window, and find the YP-Z5 device.
(6) At this point, make sure the Z5 is fully charged and has at least 30MBytes of free space.
(7) Copy the file "Z5Update.dat" to the root directory of the YP-Z5 device.
(8) Now disconnect the Z5 from the USB port.
(9) The Z5 will display the option to upgrade to the new software, or to cancel.
(10) Select "Upgrade". This will power off the Z5.
(11) Connect the USB cable to the Z5. Now it will upgrade the firmware under USB power. DO NOT DISCONNECT THE USB UNTIL THE UPGRADE FINISHES. After finishing the upgrade, new firmware will be started automatically.
(12) Check the version information in the "Settings > System Info > Version" tab.
Now you can turn on the UMS only option.
Settings / System Info / UMS Only = On
Posted on Jan 07, 2008
SOURCE: SAMAUNG-YP-Z5,LOW-BATTERY
After using my YP-Z5 for about 8 months, all of a sudden I had the same problem yesterday, (low battery, usb deferred) and again today, on two different pc's. This afternoon I tried another usb port on the first pc. The connection screen appeared without any delay, and the battery started charging. The funny thing was that when retrying the first usb port, the player functioned normally as well!
Brent
Posted on Feb 22, 2008
SOURCE: How do you reformat samsung YP-Z5 mp3 player?
Go into my computer then right click on the removable storage icon and then on format.
Hope this helps, I have had mine for nearly 2 years and it has only allowed me to play one album for the last 18 months, the worst £130 I have ever spent.
Posted on Mar 15, 2008
I have a samsung yp-z5f but i can't get in menu and it keeps freezeing.i reseted it but sill nothing.can you help?
A firmware upgrade may solve the issue. To upgrade firmware follow these steps:
  1. Download the firmware file from the Samsung Download Center by clicking here.
  2. Remember to save the file to your desktop or documents.
  3. Uncompress the downloaded file in a folder (use winrar or winzip). DATA file will be displayed.
  4. Connect the player to your PC with the USB cable.
  5. Right click on the Start button, and then left click Explore to open Windows Explorer on your PC. [Samsung YP-Z5] is displayed in Windows Explorer.
  6. Select the uncompressed files and drag-and-drop it into the Samsung YP-Z5 Data folder.
  7. Disconnect the YP-Z5 from your PC. After disconnecting the USB Cable, the upgrade screen appears.
  8. Select [Upgrade] to upgrade firmware.
Try it and see.
Nov 29, 2009 | Samsung YPZ5FZB 1 GB, BLACK, MP3 Player,...
First thing you can do here is to reset the unit to its default settings so all settings will be clear and that will help fixing this problem....and also try connecting this unit to a different computer and check if it will be conencted fine because if it will stay connected to you can update of flash the software for this ....
Oct 14, 2008 | Samsung YP-Z5 MP3 Player
How do you down load music from CD on to your YP-Z5 MP3 ?
you should have a usb cable to connect the player to the pc.
if you have a music folder, open it, choose files you want to load, open edit at the top of the page, hit copy, then open the disk in my computer that is the player, and hit paste under edit at the top tool bar
Feb 01, 2008 | Samsung YP-Z5 MP3 Player
Deleting
you may have to reformat the MP3 player by clicking on the drive its listed under and right click and go to Format. Formatting is done with FAT, not NTFS. This will remove any games or other data on it too. Sometimes the reset thing might work. In general, anything you erase from it using a computer should erase off the MP3 player too.
Nov 11, 2007 | Samsung YP-Z5 MP3 Player
Sep 29, 2007 | Samsung Yepp YP-Z5AB / YP-Z5AS MP3 Player
Mp3 Not Being Recognised and Samsung Media Studio Not Installing
As with any issue with this type of digital device, you should always "RESET" the device first (little micro switch - next to the USB port, or on back)...press with a pin (or similar) for 2-3 sec's. I then suggest you fully 'remove' any Samsung Media software (via add/remove programs under control panel). Re-boot your pc, then connect your Z5 into a know working USB port on pc. See if it installs the Z5's driver correctly (ie starts communicating). If this gets it going, you must now download the newest firmware from Samsung's website (download centre), and then save the files into your Z5 (ie overwrite the old firmware). If this fails, then try Samsung directly for further intructions. Good luck.
Jun 18, 2007 | Samsung Yepp YP-Z5QB MP3 Player
Keeps restting itself
Firstly, try "re-setting" the Z5 (ie micro switch) first. If this doesn't resolve, then firstly save a backup of all your files...then use the 'format' function (ie open My Computer, then open the YP-Z5 folder, then look for the Format function), which will clean out your entire memory, including hidden files. Then download the latest firmware update from Samsung website (download centre/mp3) and save newest firmware onto your Z5. Always update your Z5 with latest firmware (appropriate with your Windows OS). Good luck.
Mar 06, 2007 | Samsung Yepp YP-Z5QB MP3 Player
Files to large on mp3 player
Feb 10, 2007 | Samsung Yepp YP-Z5QB MP3 Player
System Error on yp-z5
I have a smilar problem. I reformatted my yp-z5f to NTFS file system . Now it does not work. I am looking for a solution.
Jan 11, 2007 | Samsung Yepp YP-Z5AB / YP-Z5AS MP3 Player
Open Questions:
Samsung Yepp YP-Z5AB / YP-Z5AS MP3 Player Logo
136 people viewed this question
Top Samsung Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
