Question about Nokia N95 Cellular Phone
N95 right button and button with pencil sign both stopped working
The phone was exposed to heat for about 10 to 15 minutes. At first, the phone was acting really wierd, when i press a certain button, it doesnt a different task. but after about 2 hours. it returned to normal. except for those 2 buttons. Is there any way of fixing them?
    Brigadier General:
  • 7,752 Answers
You wil have to take the phone and have them change the keyboard
Posted on Nov 02, 2008
My n95-3 turns on but stops at the nokia logo and shuts down and won't charge from what i gather have new battery new charger still no go? so basiclly won't turn on only lights up to nokia logo and turns...
Here are a couple of codes to soft/hard reset/format a Nokia N95 mobile device:
Soft reset code *#7370#
Hard reset code *#7780#
If the hard format code mentioned aboive does not work, try the following manual method to hard reset/format Nokia N95:
+ Turn off the mobile device.
+ Press and Hold the following three buttons: the green Call Answer button, the "*" button, and the number "3? button.
+ While holding these buttons, turn on the phone and keep holding the keys untill the mobile phone restarts and prompts you to enter details.
Regards
Egroeg
Mar 24, 2011 | Nokia N95 Cellular Phone
The phone has switched on T9 text on its own.How do I get normal text back?the phone is Nokia N95
Hi try this:
To turn predictive text on or off quickly press # twice
Here's a link to a free online user manual for your convenience
http://darlamack.blogs.com/NokiaN95usermanualUS.pdf
Please leave us 4 thumbs up :)
Nov 30, 2009 | Nokia Cell Phones
How to reseta nokia n95 memory
you can do a soft reset that will reset the memory for your nokia n95 . Here are a couple of codes to soft/hard reset/format a Nokia N95 mobile device: Soft reset code *#7370# Hard reset code *#7780# If the hard format code mentioned aboive does not work, try the following manual method to hard reset/format Nokia N95: + Turn off the mobile device. + Press and Hold the following three buttons: the green Call Answer button, the ?*? button, and the number ?3′ button. + While holding these buttons, turn on the phone and keep holding the keys untill the mobile phone restarts and prompts you to enter details. (note a hard reset will erase all data that is not saved to a sim or card) a soft reset only resets the memory and the phone. it will not erase your data that you saved
Nov 11, 2009 | Nokia N95 Cellular Phone
Nokia N95 Dictionary
i assume you mean to activate the dictionary,if that is correct
goto menu messages ,new message, then text message ,
once you have opened a new text message to be written ,
you will notice in the upper right hand corner thier is  a picture of a pencil and the letters abc. in one of the following ways
if you press the hash key the  letters will change from uppercase to lowercase keep pressing the hash key until a double underling apears before the pencil symbol , once you see that you have activated the dictionary..
Hope that helps
May 13, 2009 | Nokia N95 Cellular Phone
Nokia N95 keys wont work after being in my pocket in the rain
remove the battery and, soak the phone in 90% isoprophyl alcohol (rubbing) using a spraybottle soak your phone completely let it sit for an hour (don't worry you will not harm it) then: using a hairdryer on low gently dry your phone replace the battery and, start it this should work if it doesn't then you must diassemble the phone and use the alcohol again inside it or, return the phone for repair the alcohol can be purchased at a drug store
Apr 27, 2009 | Nokia N95 Cellular Phone
N95 RESTART AND RESTART AND STOP FUNCTION
Try the following manual method to hard reset/format Nokia N95:
1) Turn off the mobile device.
2) Turn on the phone and quickly Press and Hold the following three buttons: the green Call Answer button, the “*” button, and the number “3′ button. keep holding the keys untill the mobile phone restarts and prompts you to enter details time and country.
Warning: Make sure the battery is at least 25% capacity so the phone will not power down during hard reset. ( Hard reset normally takes about 2 minutes only).
Warning: Hard reset will format everythings in your phone ( Your contact, calender, photos, installed Apps, Etc.) and the phone will be returned to its original state as if it was purchaced new.
( Mini memory card MMC) will not be effected :)
Dec 06, 2008 | Nokia N95 Cellular Phone
My n95
Vibrate must be enabled for the profile you are in. You can change profiles by pushing the power button and not holding it down. As far as touch screens go, the Nokia N95 does not come with a touch screen on any version, if you had this capability then you must have a different phone or a fake N95. Hope this helps! Happy Hollidays!
-Joshua Childs
Sep 11, 2008 | Nokia N95 Cellular Phone
Nokia n95 button not working
You need to get the button replaced.If you can open the phone then it can be done easily.But i advice you to get it done from a technician
Sep 02, 2008 | Nokia N95 Cellular Phone
Re: my whirlpool digital oven
The red key sign is a lock against children. To cancel it you have to hold the two buttons at the same time for 5 seconds (you activate it the same way).
The STOP sign appears after the cooker switches of after a power cut. You just have to press the left button, and, using the right knob, set the time.
Jun 24, 2008 | Ovens
Nokia N95 Cellular Phone Logo
37 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
