Question about Motorola Mobility V60s
Battery or phone problem??
I do have the correct battery in my v60 motorola phone, but i get no more than two day battery life after full recharge. occasionally i get a reading of "invalid battery". before i get a new battery just want to be sure it is not the phone.
0 characters
1 Points
The battery life is VERY much shorter on my phone than it used to be. I'm having to buy new ones every 3/4months? What's wrong? I always buy the best possible type from a reliable supplier.
battery life depends on 2 things
the amount of time you spend on the phone and the number of apps you are running
and the level of charge at which you recharge the phone
Recent questions put to a phone repair shop got the answer that 3 days from a fully charged battery was exceptional as most only do 1 day on normal use and less if watching live streaming
as to the level at recharge , batteries have a habit of developing a level memory and will not charge past that point
So if you continually recharge at almost flat, and allow for a full recharge , you get full battery life
at the other end of the period , if you recharge at say 75% charge , the battery memory starts and then it doesn't matter how long you charge the battery for , it will only charge 25% which means you wind up with a flat battery more often
so how to overcome the problem---the more you use it the quicker the battery runs down and when recharging always allow the battery to be less than 5% charge before recharging it ( dead flat is best) and leave it on charge for the max amount of time ( overnight is best)
Apr 22, 2016 | Cell Phones
Battery dead, even after recharge. how long should battery last before it must be replaced?
the life span of a battery depends on the cell of the life.If the battery is a genuine battery, it can last for about a day because the make of the phone you are using.
An LG phone does not normally have very strong battery life, but at least it can last for a day before recharging it.
The battery of the phone you are using i think the battery cell of the phone is weak that is while it dies so quickly, so it need a replacement.
Take care.
Mar 15, 2010 | LG Flare Cellular Phone
Battery life only last one full day on normal usage n web surfing and music and video
The battery is nearly worn out. Rechargeable batteries have a finite number of charge and discharge cycles and the maximum battery capacity reduces with age and use.
You need to purchase a new battery.
Nov 25, 2009 | Nokia E63 Cell Phone
In my Motorola W230 mobile, the battery life is too low
Check your battery.. if it is too old then better you replace your battery and don't charge your very frequently.
Feb 06, 2009 | Motorola Mobility W230 Phone US with...
Motorola razr2 v9
it sounds like a one in a million defective battery goto service phone tech show them your receipt and have them replace this battery
May 28, 2008 | Motorola Mobility MOTORAZR2 V9 Cellular...
Hi Socrates,
If you purchase and install the Motorola Phone Tools (, the software will update the firmware in your phone when you connect it and run the update tools. It walks you through this (and makes you do it) when you start the software for the first few times.
This may help with battery life, but also keep in mind new batteries can be found on eBay for less than a dollar. Also, a good tip with any rechargable device is to charge it completely when you first get the battery, and then drain it completely without charging it right after that. This helps to set the "life" of the battery, and will generally increase the lifespan of it significantly.
Dec 17, 2007 | Motorola Mobility RAZR V3
My phone not turn on
Check the mobile using another battery then it works normaly this is the problem due to battery.Recharge old battery using external charger
Feb 23, 2007 | Motorola Mobility RAZR V3
Motorola Mobility V60s Logo
35 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
Chris Hunt
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
