Question about Electrolux 18 in. ESL4114 Slim-Line Built-in Dishwasher
Electrolux ESL4114 problem
I have a problem with my dishwasher where it is is not working past the first stage where it pumps out any excess water. When I start it I hear it pump out the water and then just a humming sound and it never goes past this.
I replaced the inlet valve as a plumber had said this is probably the issue. this has not fixed it, first time I started it after putting the new Solenoid valve in, the dishwasher did fill with water but didn't continue onto the next step.
Now it doesn't do anything, starting a cycle starts the pump to get rid of any water from the last cycle then thats it, just a humming noise.
Any ideas on what could cause this?
Thanks for any help
  • Anonymous Dec 20, 2008
    yes same prob just changed valve,pumps out ist then hear it wants to let water in but none,it runs a cycle,heater comes on but when finished all thats in washer is steam and condensation, i put about a gallon of water into it via a jug and it washed ok just as a test,so could it be control moduel?thanks nick
  • 4 Answers
My washing machine does fill up with water, sounds like the pump is trying to but no water is entering the machine, all pipes are correct any ideas any one.?????
Posted on Jun 25, 2009
See other problems listed ,other machines have similar problems one chap suggests that the FLOAT SWITCH is stuck or faulty causing the inlet valve to read as full so continues program...
Posted on Dec 20, 2008
Dishwasher trips mains
Good Morning Friend,
I understand that your Electrolux dishwasher, model# ESL4114, keeps tripping your main breaker. This appears to be a UK Electrolux dishwasher. I suggest contacting the manufacturer directly for further assistance. Hope this is helpful.
-Best Regards-
WP
May 17, 2014 | Electrolux 18 in. ESL4114 Slim-Line...
W/H Dishwasher 915 Model had no hot water,resold dry joint according to the instruction as following, but only working one wash, same problem happen again. need help.
If soldering the relay worked once then I would recheck the joint and solder a solid wire between the leg of the relay and the terminal and bypass the track
Nov 12, 2012 | Electrolux 18 in. ESL4114 Slim-Line...
No drying cycle on the electrolux dishlex 302 any idea's
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Nov 10, 2010 | Electrolux 18 in. ESL4114 Slim-Line...
Bad washing
Have you considered cleaning the drain filter and the impeller arms?
Your user guide will have instructions on this. Also buy dishwasher cleaning kit from the supermarket (this is meant to be used in an empty dishwasher). Follow the instructions on the box of the cleaning kit.
Dec 17, 2009 | Electrolux 18 in. ESL4114 Slim-Line...
It isnt cleaning ot rinsing properly
Make sure the drain hose has a clear path. Also where the hose connects to your sink drain,if you pull off the hose to check the connection for a blockage have a empty bucket handy to catch the water. If the drainage path is totally clear and it still does not work right then the water pump is weak. I hope this helps you.
Sep 06, 2009 | Electrolux 18 in. ESL4114 Slim-Line...
Dishlex Global 500 dishwasher
theres a round plug in the top of dish washer pull it out and clean could be cloged or the bottom spram arm can be pulled out and cleaned aswell
Aug 24, 2008 | Electrolux 18 in. ESL4114 Slim-Line...
Dishwasher - water softener not working
Make sure your water temperature is at least 120 degrees .Make sure your heater element is working and last of all ,Rinse Aid is the 2nd most important after water temp.
May 26, 2008 | Electrolux 18 in. ESL4114 Slim-Line...
Goes through cycles but does not clean dishes
Do you know if the washing arms are turning. Normally after the machine fills up the main pump begins and the washer sounds like it is washing dishes. If you carefully open the washer at this point (just a little) it will be eveident that water has been sprayed around inside as it will be dripping everywhere. If not you pump hasn't activated. This does not mean you pump is broken however it could be the pressure level switch sticking and not completing the circuit that starts the pump.
Apr 29, 2008 | Electrolux 18 in. ESL4114 Slim-Line...
Dishlex dishwasher
Theres a problem with the water level sensor or the main electronic control PCB.
Apr 21, 2006 | Electrolux 18 in. ESL4114 Slim-Line...
Electrolux 18 in. ESL4114 Slim-Line Built-in Dishwasher Logo
743 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Starnley Johnwells
Starnley Johnwells
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
