Question about Hisense TA42P40M 42 in. Plasma Television
My tv doest work properly em Brazil
Is there any conection in this problkem? I bouth the tv in RSA and brought to Brazil but the color doest show good it is showing in black in whait.
thanks
    Champion:
  • 211 Answers
HI,
I'll think youve got a different PAL system in Brazil.
Brazil has PAL-M en RSA PAL.
regards,
Gerard
Posted on Jan 30, 2009
TV 24" bought 2 TV and brought to Brazil and my analog signal and the image is in black and white how do I use the TV with analog signal with color image
Check the color system settings. Enter its menu, and check it. If the set is a multisystem compactable one, set this setting to "Auto". Gopakumar Gopalan Google
The fault is really related to color system compactability.
Mar 27, 2014 | Televison & Video
No color TV on my Trutech 7'' LCD TV + DVD under the cabinet model KLV3170
The TV broadcast system in Brazil is PAL-M.
If this TV was bought from the US then the TV will be expecting the NTSC system.
Your other American TV may be a multi standard TV and is able to detect and adapt to your PAL broadcast system. Not all TVs do this.
How do you connect the DVD to the Trutech TV? Is it with a Scart connector? If so then the TV will not be using any broadcast standard at all and that is why it works properly.
Unfortunately if you have searched all the menus and manual instructions without finding a TV system selection, then this TV may never be able to receive TV broadcast in colour.
Nov 24, 2007 | Televison & Video
The colors arent lined up!!
although tv is new,sounds like a dead projector lamp?you said its a projection tv,right,i hope you read settings manual,improper saturation,gamma settings,hue will also cause those issues.try getting all hdmi cables and plug em in proper,bad inverter ground possible
companies use cheap partsand a losened ground screwcaused during shippingismy best guess,happens frequently with larger tv's
capacitors cant build up properly with a lose ground"ac cord on inside"good luck"
Oct 03, 2012 | Televison & Video
I bought this tv, more or less 4 years ago, and I'm live in brazil. So, when I got here the Tv was black and white, no color! What's wrong? Can we help me?
Depending on where the set was purchased (USA) it may be NTSC format and Brazil is likely to be different format like PAL or even Seacam---they do make converter boxes that will convert signal from one format to another.
May 01, 2012 | Dell W2306C 23 in. HD-Ready LCD Television
I have a Casio EV-510 Handheld Color TV. Is
The only way is to use a standard "Set top box" or just use it as a video monitor for a VCR or DVD player - It has an A-V input that you can use, but it uses a 3.5mm jack socket (I think) - You'll need to determine the connections, but I'm sure it'll work fine. I'm just researching the conections myself. I'll re-post if I fine 'em.
Nov 17, 2009 | Casio EV-510 Television
Ws-65908
The fact that removing the front helps does not really means anything but is good that you have notice,the age of the set has a lot to do with the problem,I am sure it has many loose conections that need to be resoldered regarless,all sets have many components that disipate a lot of heat and over the years the solder cracks and it forms a ring ,this makes the set intermiatnt until no conection exist any more and it stops working for good.What does the unit do when it shutsdown? does it show a picture with lines that is red ,green or blue and then it shutsdown? or it just goes off? if it shows you a color like I mention it could be the picture tube of that color and the repair will be expensive but it could also be a loose conection somewhere in the power supply or the deflection panel,If you are familiar with repairs ot TV's you can possible take care of it but if you are not familiar with electronics call a qualified technician.I hope you can use this information.
Nov 30, 2008 | Mitsubishi WS-65908 TV
Black and white
Yes there is. Unless there is a systems mode to turn the reception to PAL, you will not be able to use this set there. Good Luck
Mar 31, 2007 | Westinghouse LTV-19W3 19 in. LCD...
Hisense TA42P40M 42 in. Plasma Television Logo
151 people viewed this question
Top Hisense Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
