Question about 2wire (1000-100052-000) 802.11g/b Wireless Adapter
Installing 2Wire usb adapter to a Linksys 802.11b wireless router
My linksys router does not have an encryption key as stated in the installation process. What do I need to do to continue to install? Help!
  • ItsAGrlThang Oct 30, 2008
    WEP is enabled. THX
  • 39 Answers
My first suggestion would be to get rid of the 2Wire adapter. The other part is not quite so simple though. First question, Do you have WEP enabled on the router?
Posted on Oct 30, 2008
  • GrayesGhost Oct 31, 2008
    To follow up on the previous question I asked about WEP - in order for a key to be generated you have to go to your router's wireless security setup page and 1. Choose a default transmit key (1 - 4) - 2. Choose your WEP encryption type (64 bits 10 hex digits or 128 bits 26 hex digits) - 3. Choose a pass phrase (almost any word that you can think of and remember) and 4. Hit the "Generate Button". -- This will produce a number in each of the four listed keys (1 - 4). The number in the key corresponding to the default transmit key you chose in step one will be your encryption key. That is the encryption key that you will need to complete the installation. If you had a Linksys wireless card installed on your computer you should be able to simply enter the pass phrase that you used in Step 3 above. Without a Linksys wireless card installed on the computer in question you will more than likely have to enter the actual number (exactly as it appears) in the default key (1 - 4) that you chose in Step 1 above. -------- This should allow you to connect to the computer to the router. On a side note, the 2Wire adapter can sometimes be a pain to work with and, more than likely, you will have to use the number rather than the pass phrase itself. If you have followed all of these steps and the unit still will not connect you will probably be better off switching to a Linksys adapter, which should make the installation easier. If you have followed all of the above steps and the router has not generated an encryption key as described you may have a defective router - in which case you will need to return it to the place that you purchased it - or contact Linksys for Tech Support.
  • cheri white Sep 28, 2012
    Awesome! Thanks for your support.
Netgear 111v3 usb linksys wireless router windows xp pro NG wizard shows all dots 90% + for signal strength, but cannot renew IP address so no internet
Do you have encryption enabled on your wireless router? There is a strong possibility that you have entered the wrong encryption key (network key) while connecting to the wireless network.
Apr 24, 2011 | NetGear : WG111 54 Mbps Wireless USB 2.0...
I have a 2wire 802.11g usb wireless adapter. I
yes it would you just need to place the 2wire on a bridge mode then configure the linksys
Nov 22, 2009 | 2wire (1000-000005-002) 802.11g/b Wireless...
We formerly used a linskys router, How can we
if you have not changed any settings from belkin router, access the wireless configuration on your windows machine and search for the belkin ssid then hit on connect
Sep 23, 2009 | Belkin N1 Wireless USB 2.0 Network Adapter...
Wireless Devices won't connect to 2Wire Modem
change the channel. this is a common problem when wireless routers are broadcasting on the same channel and at times, some cordless phones will interfer as well.
good luck
Aug 06, 2009 | 2wire HomePortal® 1800HW Router...
Trying to use belkin router with linksys adapter cards..do i need new drivers
You need to configure the Belkin router with a SSID and WAP or WEP encryption, Then install the Linksys adapter driver in the computer and then configure the Linksys adapter with the Belkin router settings (ie. the SSID and encryption) before the Linksys can communicate eith the Belkin router.
Aug 02, 2009 | Linksys (WIFIDESKTOP) Wireless Adapter
Encryptiing
Is your router from linksys also? How many wireless computers do you have? Note that if you encrypt your router, you need to make sure that each wireless computer gets the exact encryption keys you will use on the router. Usually the linksys router page can be accessed via http://192.168.1.1. Leave username blank, password is "admin". Go to Wireless >> Wireless Security. Select WEP-128 key. Enter in a passphrase and hit generate. Copy key #1 on a piece of paper (make sure it's 26 characters) and click apply. Next, go to each wireless computer and use encryption key#1 when you connect to the linksys router.
Jun 19, 2009 | Linksys WMP300N Pre-802.11n Wireless...
3800HGV-B and LinkSys Dual-Band Wireless-N USB Network Adapter
Because the linksys is talking about SecureEasySetup which most lynksys routers use. The 2wire 3800HGV-B button is not a SecureEasySetup button.
Mar 18, 2009 | 2wire (1000-400108-001) Router
Need 2wire dirvers for 2wire USB wireless adapter
I think ur driver is not properly installed, u can try the procedure as defined in below link:
http://209.85.175.132/search?q=cache:uWMw8oAQCeYJ:www.2wire.com/pages/pdfs/USB_Adapter_Driver_Installation.pdf+2Wire+wireless+USB+adapter&cd=2&hl=en&ct=clnk&gl=in&client=firefox-a
Mar 12, 2009 | D-Link 802.11g Wireless Router WBR-1310...
2wire capacity for wireless connection
yes you can return the linksys.
the following link should help you setup the 2 wire for wireless conneciton.
Dec 03, 2008 | 2wire (1000-000057-000) Modem
Win98, Linksys USB Adapter, 2wire router... no internet
hi!
sorry if it took a while to get an answer to your question...
anyway, let's begin by ensuring that you have completed installing the drivers & software of your wireless adapter.
launch the linksys wireless program by clicking on the icon for the linksys on the system tray or generally, this can also be launched from the programs menu after clicking on the windows start button.
on the main screen for the linksys, there are 3 tabs: link information, site survey & profiles. select the profiles tab
on the profiles screen, click on the new button to create a new profile. name the profile with a customized ID & click ok.
under choose a net type, select infrastructure mode. enter the SSID (this is your customized ID created on the new profile) & click next.
under network setting select obtain an IP address automatically (DHCP) & click on next.
under security settings choose "disabled" for WEP and leave the rest of the fields blank.
confirm the settings by clicking on yes.
note: you don't need a driver for your 2wire router, ensuring that the 2wire is already working with the ethernet connection.
also make sure you are able to see your devices on the mdc page, go to homeportal/management, local network> device list.
i assume that the mac g4 is able to connect wirelessly to this 2wire modem, am i correct?
please let me know if you have any issues... we'll work this one out, ok?
Apr 16, 2008 | 2wire (1000-400108-001) Router
2wire (1000-100052-000) 802.11g/b Wireless Adapter Logo
304 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
