Question about Sony KV-32S26 32" TV
Sony KV-32S26 32"
Our 6 year old Sony TV recently started randomly turning its setup menu on and off and cycling through random options. The remote doesnt seem to be working at all (cant change channels, volume, etc..) and I am unable to change any settings on the TV itself. The on/off switch and the volume button is working but I have little success navigating the setup menu. I have tried "resetting" it as Sony has suggested, no help. Problem is random, will go for weeks without issues (we do have to hit the volume minus buttom when turning on the TV to get rid of the setup menu, takes care of the problem) but when the problem flares up nothing seems to help. Also we didnt notice this proble till a few weeks after our 2 year old launched his matchbox jet into the TV (near the button controls) Any help would be greatly apppreciated.
  • John Lassiter Sep 14, 2006
    Appreciate the info. Father has alot of experience working on TVs. Any ideas on where you can find a schematic for this model TV?
    President:
  • 3,130 Answers
One of the front control switches, that are located in the back of the buttons on the front of the set most likly are damaged or broken. These switchs are small and your going to need to pull out the entire chassis of the TV set to replair or replace them. If you have solid state TV repair experience thenm it should not be a big deal, but if you DONT please seek out a local tech to assist you with this repair as sliding out a TV printed circuit board can be a tricky thing, as it can bend ,crack or pop the surface mounted componets right off the board. A repair like this shouldnt cost alot. really all depends on if the board is damaged or not. good Luck
Posted on Sep 12, 2006
My Sony trinitron tube Tv 36" seems to be going (its 10 years old
no ....the tube will end up after 20 yrs in 10 yr old sony...
it is worth if u fix it. randomly going black means...horizontal driver trans former is the problem..or any loose contact with the 110 volt supply to that transformer,,or any loose contact with line o/p transformer.. (horizontal driver transformer may be gone
then tv behaves like this) if any other parts gone tv wont come back.... there may be a loose contact call a service pro..
Apr 02, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Random close captioning shows up only disappears after turning tv off
Hi you can removed this by using your remote and access to your menu/close caption seting option and turn it off /or by using the menu button on the tv set
hope that help you.
Mar 21, 2010 | Sony KV-32S42 32" TV
I have a sony trinitron XBR 32 inch... The pip was turned on by accident, but i don't have the original remote. How do i turn off the PIP? Thanks in advance.
pls. use remot menu key and open main menu use DW key and select system menu see the PIP option is "ON" set option is"OFF" .
See the PIP screen is clear.
Oct 20, 2009 | Sony FD Trinitron WEGA KV-32FS100 32" TV
My kv-20520 tv wont turn off closed captoining
Maybe you have to scroll through the Closed Captioning options or your menu for a bit until you find it and maybe you blew your speakers
Jul 23, 2009 | Sony KV-20V80 20" TV
Sony KV-34HS420 Random Shut downs
i would say this is a internal problem how long have you had it?
May 28, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
KV-9PT20 have a different service menu handshake?
It is an old model of 1994 and does not have service menu facility.
Not fault of remote, TV has no service data adjustment menu option.
Apr 14, 2009 | Sony KV-9PT20 9 in. Television
Random Turn-Off on KV-34HS420
Hello there,
7 times blinks shows that Horizontal Deflection Circuit doesn't work properly.
I think, its not big fault and can be resolve in low cost at nearest Sony repair shop.
Feb 18, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony Wega KV-27FS100 RANDOMLY Turns itself ON
You said around 4pm TV is switched on everyday. Check in menu options any on-timer and off-timer is changed. If it is not there is a problem in microprocessor section. EEPROM ic malfunction also shows these type of symptoms. But it can be done by Technical persons only. This is not a major problem. This is due to surge current and lightening like that.
Sep 06, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Help!
You have a button stuck either on the set itself or on the remote. Stargazer
Aug 16, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
PIP won't turn off
I pressed "Demo" on the front of my TV and it worked, I have an old Sony KP-53XBR35 VIDEOSCOPE XBR - no original remote and the Universal remote has PIP button but would not shut it off.
Finally it's off!!!!
Jan 23, 2007 | Sony KV-35V35 TV
Sony KV-32S26 32" TV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
