Question about Zyxel Prestige 2000W IP Phone
Prestige 2000W use with Vonage
I cannot find my manual for my phone. I want to use it with my Vonage phone service and I need help making the connection. Also, I would like to have a manual. Is there one available for download or to read online? Please advise.
contact information
Alan McIntosh
mr_tosh@hotmail,com
(615) 435-3771
  • mr_tosh Oct 30, 2008
    Thank you very much.
  • 25 Answers
Go to this link:
http://www.amazon.com/ZyXel-Prestige-2000W-Wi-Fi-Cordless/dp/B0002KK63Y
Scroll down a little, under "Product Details" will be a link titled "Product Manual".
Just click on that and it will bring up a copy of the manual.
Hope this was helpful
Have a great day!
Posted on Oct 30, 2008
I have comcast cisco cable that is working fine but when I hook up vonage I get no internet why?
More than likely you need to enable split tunneling on vpn settings in router. If Vonage uses a vpn tunnel like other VOIP services do, then it is probably encrypting all traffic on your Internet/WAN interface. With split tunneling enabled it will only encrypt traffic to and from Vonage. I'm making a few assumptions here, but it should be worth a check.
Jul 23, 2014 | Linksys VOIP VONAGE PHONE ADPTR 2-PORT...
Tip
How to use VOIP Phone number in Philippines
US VOIP phone number can be used in the Philippines. For example, If you're Vonage subscriber (I used to), you can hook your phone adapter (basically a router pre-configured to work with Vonage) to your DSL/Cable modem.
You can make/receive phone calls to/from the US, depending on your subscription type. Usually, there are unlimited call plans. All you need is a high speed internet connection.
on Jun 25, 2010 | Computers & Internet
My desktop has a local area connection with limited to no connectivity. I had my desktop pc connected to a netgear n900 router and a vonage phone connected to the router's lan1 port. This caused i
Did this connection ever work before? I have a similar setup with Iristel and once in a while it goes down (Hurricane Leslie generated the problem last week).
Check whether the setup works without the Vonage device. This will tell you whether the problem is with your router or the Vonage box. If it works without the Vonage, the problem is in the Vonage box, you may find a good time to call Vonage for support.
I don't know whether the Vonage box (in my Iristel case it's a mediatrix 2 something) has to 'call home' before it lets your router set itself up.
If your router does not work without the Vonage, you have a simpler problem, the router is the issue. You can reconnect the Vonage and if the phones work, this confirms that the router is the problem. At least you can use the phones.
With the router, you need to log in to the admin screens and poke around until you find the problem. It is always a good idea to only change one thing at a time and always remember what changed immediately before the problem was noticed.
Sep 16, 2012 | Gateway Computers & Internet
My Belkin F7D4302 router will not work with my vonage. I have a clearwire modem. If I hook modem into my my vonage first then to my router, my router does not connect to internet but my vonage does, If I...
It should work with the Vonage hooked into the WAN port of the modem, then the router plugged into the router. I had same issue with a Belkin router. Vonage Customer Service will help you at all hours: 1-VONAGE-HELP (1-866-243-4357)
24 hours a day, 7 days a week If you are calling to speak to our technical support team, please make sure you are near the Vonage phone adapter you are calling about and at the location where you intend to use your Vonage service.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Thanks, Joe
Jan 20, 2011 | Belkin Computers & Internet
HP 3380 All-in-one. wont send faxes. dials, says connecting, and even sometimes starts to send page, but comes up comm error. I have vonage phone service.
Vonage claims to work with all fax machines. However, some customers report having had trouble sending and/or receiving faxes with Vonage and other voice-over IP (VoIP) providers. The difficulties are a frequent topic in help forums and even made the Wikipedia entry for Vonage. Frustratingly, the problems have been intermittent and hard to diagnose, and some customers have resorted to buying a new fax machine that better-suits Vonage’s optimum specifications. The company’s official “help” resource suggests lowering the baud rate on the fax machine to 9600 (or “slow”) as well as disabling the machine’s ECM (error correction mode) feature, if applicable. Also, make sure the fax machine is on the “standard” setting. Some users have had good luck adding *99 before dialing, as that resets the bandwidth for that call.
Vonage also allows its customers to send faxes over the Internet, without a fax machine, by uploading documents to the Vonage web site. There is no additional charge for this service if you’re on the company’s “Unlimited Plan.” Per-minute customers will see fax use applied toward their monthly minutes allowance. Hope this helps.
Apr 20, 2010 | HP LaserJet 3380 All-In-One Printer
Vonage customer, problem running through home phone wiring
Make sure you have disconnected the original phone line at the first entry point to your home. Even though regular phone service is disconnected (software) the original phone line carries some "noise" which can cause issues when trying to utilize existing phone wiring throughout the home.
Dec 02, 2008 | Lands Phones
Can't call home phone
Make sure your the internet is working fine on the router. If it is, you need to call vonage and have them activate the phone ports of the router. The phone ports on the back of the router needs to be registered first through vonage. That should do it.
Oct 14, 2008 | Linksys VOIP VONAGE PHONE ADPTR 2-PORT...
Vonage does not work with D-Link router
If you plugged a telephone into your D-link router, unplug it - that can not work!
You have to plug your vonage router (WAN port) into the D-Link (LAN port) and connect your phone to one of the LAN ports of the vonage router.
If you do not need the wireless capabilities of the D-Link, you can simply take that one out and only use your vonage router.
If you need more help, I would need more details form you:
Which vonage adapter are you using?
How is your setup (i.e. modem -> D-link -> vonage & computers)
What connections are you using (wire/wireless)?
You can also find help here.
Jun 17, 2008 | D-Link DI-704P Router
Vonage V-phone
This indicates a disconnection of service or a cross in the wiring.
Have you done or had done any wiring changes?
Have you move anything around or disconnected anything recently?
Something has changed to get a USB error. Unless you have been disconnected for non-payment.
Hope this helps.
Feb 24, 2008 | Lands Phones
Zyxel Prestige 2000W IP Phone Logo
379 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
