Question about HP Pavilion Slimline S3123W Desktop PC - REFURBISHED
Replace memory cards
How do I remove the cd drive so I can install upgraded memory cards
  • ninjam0nkey1 Dec 06, 2008
    I need to plug in the cord to the hard drive which is under the disc drive how is it that I get to it since the cd drive won't come out?
You will need to remove the face plate to slide the optical drive forward. disconnect the red cables plugged into the SATA slots on the motherboard, noting the order they are mounted (although they can be adjusted in the boot menu if you swap them) flip the case over, so the removable drive slot is at the top. Grab it and slide it straight backwards. It will release and can be hung over the side of the case out of the way. The lower faceplate mounts (now at the top, we flipped it up) need to be pinched towards each other to pop the faceplate off. The upper (again at the bottom not) should be pushed outward from their center to be removed. Once this is done, there is a single screw at the side of the optical drive about 3/4 of the way to the front shich needs to be unscrewed. Now pull a little on the spring catch at the opposite side from the screw, (it is silver and has a little handle so you can guess what to do) it will release and the drive will be able to slide forward. You don't need to remove it, just slide it enough to get to the DIMM slots and swap them out. The reverse procedure is simple and should pose no issues. Please make sure you are grounded and if possible work on a anti-static mat when doing this. I hope this helps. Moondoggy
Posted on Dec 04, 2008
  • 781 Answers
To remove your cd drive on a laptop:
some laptops have a level that you can pull to remove it although I doubt that you need to remove your cd drive in order to install memory.
some laptops have a compartment cover with a panel that have some screw(s) holding it in place that once remove will allow you to get to the part where memory is installed. look for this panel at the bottom of your laptop
fyi
a) before you start disasambling your laptop unplugged your laptop and deattached the battery.
b) laptop are tricky to service so design and brands are different even amoung the same brand, so if you want to post the model of your laptop and make and I'll try to get some instructions for you (no promises)
c) check out this video to get an idea of what you need to do: http://www.youtube.com/watch?v=P5LUXjMIQdg
do you have a desktop?
1. you don't need to remove your cd drive to install memory
2. you need to find out what memory your motherboard takes and how much you can actually put it (post the serial of *********** board and I can aswer that question for you.
3. installing memory in desktop is fairly easy... just open it up, ground yourself before touching any component and installing in the memory slots... depending how old your motherboard/system is some configuration may be needed in your bios but that's only if your system is way too old.. for new systems the memory will be recognized on your next bootup
4. check out this video to get an idea on how to actually put the memory stick in..
http://www.youtube.com/watch?v=SiFIgSQOY7g
good luck!
Posted on Oct 31, 2008
How do you install a macintosh internal Superdrive CD-DVD in a macbook pro?
Assuming you are wanting to replace a faulty drive, turn the computer off and then flip it upside down. With a small eyeglasses phillips-head screwdriver, remove the 10 tiny scores on the bottom of the case. Be sure to arrange the screws in such a way that you replace the screws in the spots you took them out because they sometimes don't seat flush when you put them in difference holes.
Locate the super drive. Disconnect the SATA cable and power cable (they may be one harness or two separate plugs). Remove the screws that hold the drive in place. Install the new drive, replace screws and connect SATA and power.
Replace the case bottom and secure with the screws you removed earlier.
The whole project should take less than 15 minutes. You might want to consider upgrading your memory while you have the case apart. It's very simple, and the memory is pretty cheap these days.
Aug 12, 2015 | Computers & Internet
Memory parity 2000
Hi Kelly, we are dealing with memory problem, if you have available memory try swapping it, the other way is to remove any card attached in *********** board that may cause some conflict with the system, Isolate 1 by 1 the hardware installed from your hardware.
1. remove the memory module, clean the tip of the memory, the one connecting to the slot with rubber eraser or any rubber. If possible swap with good one if you have to isolate memory defects.
2. remove/clean any cards(video cards and others) in your expansion slots.
3. Boot your PC without connecting the hard/CD/FDD drives to speed up checking.
4. Once start up is okay without memory parity error appearing, one by one install the Harddisk, CD and FFD.
Jun 21, 2011 | IBM ThinkCentre S51 Intel Desktop PC -...
I have acer aspire 4520.I have upgraded to windows xp sp2. The empowering technology does not work.It says " the specified file is not found".I cannot find the empowering technology software...
Acer Aspire 4520 Notebook Technical Specifications:
Operating System Genuine Windows Vista Home Premium Processor AMD Athlon™ 64 X2 Dual-Core Processor TK-57 (512KB L2 cache, 1.9GHz) Chipset NVIDIA nForce 610M Memory 1GB (1GB installed in one of two memory slots) DDR2 667 SDRAM User upgradeable up to 4GB (one 2GB memory card in each slot)* subject to availability of 2GB cards
*If upgrading after initial purchase, one or more of the memory cards provided with the system may have to be replaced with optional larger memory cards in order to achieve the maximum capacity.
Storage 120GB* hard disk drive Integrated variable-speed Super-Multi drive (DVD+R, DVD-R, DVD-RAM):
-Read - 24X CD-ROM, 24X CD-R, 24X CD-RW, 8X DVD-ROM, 8X DVD-R, 8X DVD+R, 6X DVD-ROM DL (double-layer), 6X DVD-R DL (double-layer), 6X DVD+R DL (double-layer), 6X DVD-RW, 6X DVD+RW, 5X DVD-RAM
-Write - 24X CD-R, 10X CD-RW, 8X DVD-R, 8X DVD+R, 4X DVD-R DL (double-layer), 4X DVD+R DL (double-layer), 6X DVD-RW, 8X DVD+RW, 5X DVD-RAM
5-in-1 card reader for optional MultiMediaCard™, Secure Digital card, Memory Stick, Memory Stick PRO™ or xD-Picture Card™
Surely to load XP is a DownGrade. As this notebook is dual core, I would run Vista 64 or better still Windows 7 64.
If you wish to persist with an old system, you require SP3 for XP.That may be available from a software store but is no longer supported by Windows.
Try http://www.notebook-driver.com/laptops-information/acer-aspire-4520-notebook-technical-specifications/ for drivers that you will require to have support from Acer.
Hope that clarifies your situation.
Dec 09, 2010 | Acer Aspire 4520-5582 Notebook
I have a gateway 831gm. it has an Intel (Augsburg) 915G Motherboard and a Pentium 4 630 cpu 800MHz fsb & 2MB L2 cache. i've been looking for a cpu upgrade and saw that the Pentium E5200 Dual Core has...
If both motherboards are LGA775 socket, then the next concern is whether or not the case is capable of having the new motherboard installed into it. Disconnect all power cables to all dv drives or cd drives and hard drives. Disconnect all ribbons from drives to the mother board. If you can get to all of the screws that hold the motherboard into the case, you get away without removing drives. Once you've got the motherboard then you can disconnect the power cable from the motherboard. Remove the memory chips, disconnect the sound cable from the old motherboard. install the memory chips onto the new mobo, Connect the power cable to the new mobo, then install the new mobo into the case. Replace the ribbons from the drives to the mobo, replace the power cables to the drives and reinstall the sound cable to the cd or dv drive. You should be done now.
Dec 13, 2009 | Gateway 831GM PC Desktop
Power saver mode problem.
Reset the Memory cards.
And if you have video card reset the video card as well.
and it will work fine and even if it does the same issue your memory or Video card needs to be replaced.
Oct 24, 2009 | HP Computers & Internet
Refresh nokia 5000
1st Step
Formet Your Memory Card
All data transfer CD or Pen Drive or Other Drive
Then Format Your Phone Memory,
2nd Step
Restore Setting, please Early do you Anti Virus Soft. Install & do you upgrade, than give you scan all files or folder,
thanks
Mar 09, 2009 | Nokia 3230
Can't play any games
Yes you need to install the drivers that came with the card. Let me know if that helps you...
Dec 16, 2008 | XFX GeForce 6200TC Graphic Card
PowerEdge Server won't boot after memory upgrade
if you really need the BIOS update. you need a working PC to download the BIOS and unzip it to a CD. install it, since the PC do see the CD, you may have do some maneuver to ge the BIOS installed.
Oct 29, 2008 | Dell PowerEdge 1800 Server
I want to know if I can upgrade the harddrive and memory
Depending on the memory you already have you can install upto a maximum of 1GB 266MHZ DDR, and cannot see any reason for not being able to upgrade your hardrive for a bigger one, but be aware that the Operating system backup will probably be on a seperate partition on your current hardrive, unless you got an installation cd with your laptop.
Oct 12, 2006 | Gateway M305CRV Notebook
HP Pavilion Slimline S3123W Desktop PC - REFURBISHED Logo
87 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
