Question about Refrigerators
Amana fridge stopped working. Now working again.
Yesterday, fridge not working. Light is on, but no one home. Chinese firedrill for perishables. Left plugged in. Unplugged this a.m. and plugged back in and voila everything starts up. Freezer works and fridge starting to get cold. I am suspicious as this summer we had water drainage (my husband ignored it and said it was just condensation...won't go into procrastination issues...)
Snooped around on internet also called appliance parts guy who thinks that it's the adaptive defrost timer. He told me that it would probably work again and then shut down in about a week.
I think that I could replace this part, but need to know where it is, exactly. I have a picture of the part itself from the web, but don't know where to look.
Would appreciate any help.
  • 2 more comments
  • groovers Oct 30, 2008
    This is an Amana SZD22NW P1162401WW.
    The advice I got was that it needs a new adaptive defrost timer.
    I need to know if from the information provided this is the correct analysis.
    I also need to know how to get to this part through the back of the fridge.
    Not to put too fine a point on it, please do not send me to another website to troubleshoot this. I have spent 4 hours online and that is what I am paying fixya for.
    This is not a frost or ice problem. Fridge doesn't work. I unplug it and replug, then it works.
    Once again it's an Amana SZD22NW P1162401WW. I need to know where to look on the thing to find the adaptive defrost time. I know I go through a panel on the back, but which panel and where is it. Need a blow up diagram of actual model and fridge. Please do not send me to a website for troubleshooting with a blow up diagram too small for a Barbie doll to read.
  • vieneka Jan 20, 2009
    water is reaching the freezer to make ice, but not the water dispenser in the door
  • Prakash
    Prakash Aug 08, 2014
    Hi, I have the same model of Amana as yours, mine is not making any more ice cubes nor does the temperature goes below 60 de F. The Adapive Defrost board on mine is mounted at the bottom, you first remove the grille at the bottom front, where the condenser is located, this module is clipped below and is inside an enclosure . Reading the small wordings on the module, tells how to test the defrost cycle....
  • Refrigerators Master
  • 13,433 Answers
Here are a few troubleshooting tips on this page
http://www.repairclinic.com/0088_4_1.asp
I can find you the part you need if you post me the model of your fridge.
model or part number anything you can find will be helpful, add the details with add a comment button and Il see if I can find you the part.
you can also try looking for the part yourself from this webpage
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
but I will help if you post me the details.
Thanks,
Ekse
Posted on Oct 30, 2008
  • Ekse Oct 30, 2008
    you can find the part you are looking for from this webpage
    http://www.repairclinic.com/SmartSearch/...
    enter your model number into the finder SZD22NW
    Select defrost components from the side panel.
    a good idea might be to pickup a repair manual also.
  • 958 Answers
The tech could be right and he could be wrong. adaptive defrosting is being controlled by the main board. which controls cooling as well and your thermostat.
if you have ice build up in your freezer section, back part, then it could be the adaptive defrosting not functioning but it is not a separate part as if it is a mechanical timer. it is part of the sofware of the fridge and it is in the main control board.
if it is icing up at the back of the freezer section. it could still be two more things,
the defrost heater could be open and would not heat.
or the bimetal which would controll the heater in case it would overheat.
if you can post the part which the tech is talking about, then i could help you further. use the ask me button to direct a question to me.
tnx 4 using fixya,
drcool
    Scholar:
  • 155 Answers
Ok. read this instructions.
  • 1 more comment
  • fixexpert Oct 30, 2008
    The ice maker has a problem
    The ice maker is a separate appliance within the freezer section. Please see the How things Work section of our website to learn about the normal functioning of ice makers. Some common problems with ice makers are:
    The ice maker has completely stopped producing ice
    The ice maker is producing ice poorly
    Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
    When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
    First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
    There's an ice- or water-dispensing problem
    The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
    Faulty Defrost Timer / Control
    Some models use a mechanical timer while others use an adaptive control which is a computer board. Regardless which device is used, the purpose is the same. The defrost control is used to send power to the defrost heaters at the proper time. If power is not reaching the the defrost heater circuity, it is most likely the fault of the defrost timer/control mechanism.
    When the defrost timer is in the defrost cycle, the compressor and fans will cease to operate. If the timer fails to advance from the defrost cycle, the machine will not operate. Mechanical style timers can be manually advance both into and out of the defrost cycle.
    click and check out this link for doing it your self.
    http://www.repair-help.com/kb/index.php?...
    thanks.
How can I get my Amana fridge and freezer working again? My lights were off for two weeks, and now it's not cooling, but the light is on.
Thermostat might be stuck. My fridge stopped working recently and I hit the thermostat control a sharp blow with the handle of a soft-handled screwdriver and it started to work again.
I had to hit it several times over the next few days to keep it going until the new thermostat arrived but since it was delivered the fridge has been working normally...
Sep 06, 2017 | Amana Refrigerators
The freezer if running fine, but the fridge has stopped working- help?
parts of the refrigerator are frozen! turn it off wait until next day and try it, if it does it again it may need a defrost line that keeps certain part from freezing it is very common it todays refrigerators.
Apr 07, 2012 | Refrigerators
I have the Amana ARB220ZCS fridge and yesterday it just stopped working. This light is sill on but it is not getting cold, the fridge or the freezer. Thanks James
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 20, 2011 | Amana ARB220ZCS Bottom Freezer...
Amana #srd2555w bought from a friend in working condition. 3 yrs old brought home on its side. vacumed coils working 3 days then stopped cooling in fridge followed by ice build up and not working in...
You have a defrost problem. 3 parts: Timer (or "adaptive defrost control"), defrost heater and def. termination thermostat.Find the timer, it shoud be nehind the bottom front grille to the right on Amana (if you see a blck box under there with a sticker on it, it's the ADC model) turn the timer CW until it clicks. Take the back off the bottom of the freezer and listen. After 5-10 minutes if you hear the sound of the sound of water hitting a hot grill. If you hear this the heater and thermo are working and the problem is the timer/ADC. No hiss? Unplug fridge. Check thermo and heater for continuity. Replace the one that's open. If the heater's open, replace the thermo too: Maybe it didn't open soon emouhg and caused heater failure.
Sep 25, 2009 | Amana SXD524VW Side by Side Refrigerator
SubZero fridge problems
Ice buildup on the back left wall is the sign of an evaporator leak. Not something you can fix yourself, at some point it is going to be completely out of gas, I would call for service now
Apr 07, 2009 | Sub-Zero 661/F Side by Side Refrigerator
We have an Amana side by side that is only cold on the bottom in both the freezer and fridge. Also the top shelf of the fridge is hot from the light, which does not seem to go off when the door is shut....
amana runs power to the fan thru the defrost sensor that is mounted on the evaporator coil. these sensors will get moisture inside of them and short out causing intermittent fan operation. replace then sensor and your frig will return to normal. thanks for using FixYa peyton
Feb 17, 2009 | Amana ASD 2624 Side by Side Refrigerator
Amana side by side
either compressor is jammed or the starting relay with capacity is faculty
Jan 13, 2009 | Amana ARB8057CSL Bottom Freezer...
Amana Side by side refridgerator Model SBD20TPE P1190006WE
hi
one question : are the units under warranty ?
if not its pretty easy to swap the dispenser paddles and the membranes
infact i have been using this site for many years and have found it helpful: : www.howstuffworks.com
thanks
May 04, 2008 | Amana ACD2232HR Side by Side Refrigerator
Refrigerators Logo
1,582 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
