Question about NetGear WGT624 Wireless Router
Wireless internet connection
Unable to connect to internet with wireless using netgear router.  Does fog outside have anything to do with it?  using 108 Mbps Wireless Firewall Router WGT624 y2
    Scholar:
  • 87 Answers
Fog will not affect radio signals. Please go to the following website and follow the instructions.
http://kbserver.netgear.com/kb_web_files/n101676.asp
Posted on Oct 31, 2008
How to Install Netgear Router Using the Wireless Device
hi john.
To install your NETGEAR wireless router using your wireless device:
  1. Get the preset wireless settings of your NETGEAR router. It is written on the back or at the bottom of your device.
  2. On your wireless device, open the WiFi connection manager and find the SSID or WiFi network name of your NETGEAR router.
How do I install my NETGEAR router using a wireless device ...
https://kb.netgear.com/.../How-do-I-install-my-NETGEAR-router-using-a-wireless-devic...
How to Install Netgear Router Using the Wireless Device Google Search
Nov 06, 2017 | NetGear Computers & Internet
How do you connect netgear extension to router
This article provides instructions on how to wirelessly connect to your NETGEAR Wi-Fi Extender using manual setup after the NETGEAR WiFi Extender has been successfully connected to the Access Point (AP) and obtained a valid IP address.
https://kb.netgear.com/25504/Unable-to-connect-my-NETGEAR-WiFi-Extender-using-manual-setup?cid=wmt_netgear_organic
Feb 23, 2017 | NetGear Computers & Internet
Router problem. unable to connect wirelessly
This is usually up address conflict. You will have to assign the wifi or lap top to different IP addresses. You have to refer to the modem manufacturers instructions or search on net / YouTube how to do this. It's too detailed to do it here I think.
Oct 17, 2017 | NetGear WGR614 Wireless Router
When I connect my computer to Netgear MR814v3 router via wire, I can get internet on my computer. However, when I try to connect wireless internet, I can see my router's SSIP (the name I gave for my...
You have to enter the router password on every wireless device you want to connect to the internet. You usually only have to do it once per device, but it won't connect without the password. The password it's looking for may be on the label on the router or in the wireless setup page of the router.
May 09, 2017 | NetGear MR814 Wireless Router
Connected but unable to view website
You might need to check the security on your router , if its enable or not.
You can try the solution below to check your router wireless security. Note this should be done on a computer that is connecting to the internet thru the router.
1. open browser and enter http://routerlogin.com
2. username is admin , password is password.
3. click on wireless option .
4. look for the wireless security settings.
If you dont have another machine that is connecting to the internet. Just follow the steps below.
1. Reset your router for 30 seconds by holding the reset button.
2. turn off for 30 seconds after resetting it.
3.Power off the modem and turn it back on after 2mins.
4. If all the lights on the modem is stable power on the router, make sure the modem is connected to the internet port On the router.
5. check your computer which has a usb adapter,. Look for the wireless icon, You should be seing an option were in it will allow you to view the available wireless,
6. Look for the wireless name "netgear " and press connect. CHeck if you have internet.
Rate me if the solution is helpful
Kevin angell.
Jun 14, 2010 | NetGear WGR614 Wireless Router
Hi, i have bought this netgear 108mbps wireless router WGT624, 2 weeeks ago, it was working good, but now suddenly it shows less mbps and when tried to restart it, now it not working, i mean it says in my...
I suggest try to check the netgear if it is connected to the internet. If the wirelss signal is good, it might be the internet connection is having some issue.
What you can try to do first is:
1.connect a computer to the netgear directly using an ethernet cable (RJ45)
2. click start then select run type cmd (It's a black screen)
3. type ipconfig/all then press enter on your keyboard
4. check the ip address it should be 192.168.X.X and the default gateway is 192.168.0.1 or 192.168.1.1 depending on the router default ip address
5. on the black screen type ping yahoo.com then enter on the key board
*if there is a "reply from" message it means there is an internet connection going in the router and you need to configure the router. *If the message is "unable to detect" or "request timed out". You need to contact you Internet Service Provider for assistance.
Nov 21, 2009 | NetGear WGT624 Wireless Router
Netgear No Internet connected detected
Are you sure you have a PPPoE Modem? Usually these are DSL connections from Phone and Satellite ISP's... But there are also other ISP's that use them, although a very large percentage of ISP's just use DHCP. Try to set the router up using DHCP instead of PPPoE and see if that works...
To check if you are on the internet:
Start-> Run -> cmd [enter]
in the black box:
ping google.com [enter]
another useful command is:
ipconfig
Dec 10, 2008 | NetGear WGR614 Wireless Router
Plz solve
need more information - do you have cable? DSL? Are you able to connect when you put the Ethernet cable directly into your computer and bypass the wireless router? The wireless signal is only indicating that your router is "broadcasting," but does not mean you have a usable Internet connection.
Feb 17, 2008 | NetGear WGT624 Wireless Router
Open Questions:
See all NetGear WGT624 Wireless Router Questions
NetGear WGT624 Wireless Router Logo
103 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
