Question about Hotpoint WD62 Front Load Washer / Dryer
Earth fault I have an earth fault that trips the RCD on my consumer unit. The programme selector is set to the start of a cycle (E) and altering its position makes no difference. The earth fault also ocurrs with the on/off switch on the front of the unit set either to on or off. I have taken the top and back cover off and looking inside there is no obvious wiring fault or damaged cabling. Any ideas?
The wiring loom from the motor to the control board is cable-tied too tight against the motor. this causes the wiring insulation to weaken and short against the motor causing the constant earth fault./ cut the cable ties on the motor loom and refit new ones BUT not too tight
Posted on Mar 05, 2007
Hotpoint washing machine HV8B593 trips RCD after a few secs without start button being pressed
If it trips the RCD then you have an electrical fault. Washing machine can do this once they are a bit old, or if they have had a water leak. The water gets into the electrical equipment and causes a fault that trips the RCD. If you have a circuit without an RCD try that. If it still trips, then the fault is serious and you will need to get it repaired. You can also try putting the washing machine into a warm place for a few days to see if it will dry everything out. Sometimes this will cure a fault if it is due to dampness.
Sep 01, 2018 | Hotpoint Washing Machines
Dishwasher is tripping RCD, can it be repaired?
not necessary-- yet-- to buy a new unit
tripping the rcd is an indication of earth leakage which could amount to water in the wall plug across pins, moisture across the power board, water in the motor, faulty heater element
what you need is an accredited electrician to run tests on the system to find the reason for the earth leakage that is tripping the rcd
the rcd works from microvolts and operates in nano seconds to prevent electrocution of the operator
testing before buying may save heaps of cash
May 19, 2015 | Stoves Dishwashers
I have a eurolec double built under oven. When I turn the bottom oven on the rcd at the house consumer unit pops. The top oven works fine...
The elements in ovens consist of an outer earthed metal tube and an inner resistive element that is insulated from the outer tube by what is effectively a compressed ceramic insulating powder. If the element is not used for a while, enough atmospheric moisture, (or from spills, etc), can penetrate the insulation to cause enough earth leakage to trip the RCD. If the RCD is tripping at the correct level, (They can get too sensitive - see this article here:
Diagnosing RCD earth leakage breaker nuisance trips), then the only long term solution is to replace the element, although they can sometimes be dried out by heating them.
Aug 11, 2014 | Ovens
Zanussi washing machine trips rcd on spin
Hi Ian.
I am assuming your RCD is fitted in your consumer unit (fuse-box)?
If so, then the chances of this being the cause is minimal. The RCD trips wen electricity is not balanced between live and neutral wires - which means some is leaking out to elsewhere - which it shouldn't because it is dangerous.
It would have helped if you had indicated how old your machine is, and how much use it has had but I am currently leaning towards the motor have several winding options that kick in (or not) depending on the spin speed. It would therefore be a motor fault, or something as simple as the brushes are disintegrating (which is often accompanied by hesitant and intermittent behaviour from the motor). These types of faults mean that some of the electricity may be leaking to the motor casing and then to earth.
I would recommend you call an engineer or if you have decent DIY skills, locate a replacement motor (ebay or the likes) and swap it out.
Good luck
David
Dec 15, 2013 | Zanussi Washing Machines
We have just bought a very old house that has a Vulcan Oil heater installed in the fire place. We have tried to light it (but all houses are now by law have installed RCD switches at the meter box,) How...
Is the RCD sensing a leak to earth?
As a test, you could drop the earth wire off the unit and see if the ignitor then works. If it did, then you would need to figure out if there was somewhere else you could earth the unit. This would potentially leave the ignitor without an earth and you need to decide what to do about that.
I hope you can see that I'm absolutely avoiding advice that you remove the earth from your unit in order to make it function. What you should do is get a professional in to correct the fault. What you actually do is a matter for you.
Jul 07, 2011 | Heating & Cooling
Siemens oven tripping RCD
We need wiring diagram for HB905 Siemens double oven, to start with it kept tripping, element ok. Now we have no heat coming from the main oven.
May 02, 2009 | Siemens Ovens
Main oven problem
I suspect not the oven element at fault. you only way forward is to actually test the resistance of the element to earth with a megga if you can beg the use of one. be cautious about the result as on occasion, elements are only faulty to earth when hot. another way to test if you are cdarefull, is to connect the element to mains independently of the oven and see if the rcd trips
Sep 22, 2008 | AEG U3100-4 Electric Double Oven
Cooker keeps tripping the electricity supply.
If the main oven is electric, disconnect the heater element and try, if no trip operqates. then replace element.
Nov 22, 2007 | Belling CookCenter 151 Dual Fuel (Electric...
Hot point washing machine WMA 32
It's unusual for a household RCD to go out on excess current from an appliance - the fuse in the plug top and circuit fuse/MCB in the consumer unit should provide closer protection. This leaves you with an earth fault. Earth faults aren't usually related to motor load. Watch carefully what phase of the cycle the trip happens. Does it correlate with the start of water heating? A very frequent cause of low current earth faults is water ingress into the heating element. If you can trip the RCD reliably on every cycle, running the same cycle with the element disconnected would confirm whether or not this is the cause. A.
Feb 28, 2007 | Hotpoint WMA32 Front Load Washer
Earth Fault
IM GUESSING THAT YOU GOT A LEAKY GASKET THATS SPRAYING WATER ONTO YOUR DOOR INTERLOCK SWITCH CHECK TO SSE IF YOU AHVE ANY RIPS OR TEAR IN THE GASKET. DOOR INTERLOCK WOULD BE WORTH CHANGING AS THEY DONT COST MUCH.
Jul 24, 2006 | Hotpoint Aquarius WD640 Front Load...
Hotpoint WD62 Front Load Washer / Dryer Logo
262 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
Eric Taylor
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
