Question about Whirlpool LTE5243D Top Load Stacked Washer/Dryer
Washer will not fill with water
When I turn on the washer at the start of a cycle it will not fill with water. Instead it automatically begins to agitate as if it thinks it already has water in it. Is there a way to reset the water level sensor? Or is there another fix?
  • amosz42 Nov 02, 2008
    Was working fine yesterday, but then during a load, it didn't do the spin cycle and everything was soaked. Now it won't fill with water, it just 'agitates'. When sent to 'spin' or 'rinse' there is a sound of water for 1/2 a second but no water comes out and nothing is moving.
I solved the identical issue that I was having with my washer, maybe it will help you: I opened the front panel to the washer and found a clear plastic line running down the inside; it had become clogged. Could tell, because disconnecting the line caused the washer to function. Removed clog and it seems to run fine now.
Posted on Nov 02, 2008
Starts washing before it begins to fill
Should have a tube that goes from the bottom of the washer tub to the control panel - check the hose for problems first; if none found - you will need to replace the water level switch. It is a pressure sensitive (diaphragm) sensor, that may have failed or stuck, causing a fault to the main controller/timer. I would favor a stuck diaphragm over a hose problem...
Hope this helps...
Jan 07, 2012 | Maytag MVWC6ESWW Washer
I have a top loading Kenmore Washing Machine. I don´t have the excat model but looks like a KENMORE HEAVY DUTY SERIES 70 AUTOMATIC WASHER, MODEL # 110.92273100. The problem presents after finishing...
You may have 2 defective parts.
First,make sure the hot and cold water hoses are connected correctly and both turned on.
If the water fill problem is the same,the water temp switch is bad.
The not filling after the wash cycle could be a bad lid switch.
Set the machine for SPIN and turn it on.
If it does not spin,replace the lid switch.
Sep 20, 2010 | Kenmore 24042 Top Load Washer
Whirlpool LXR9245EQ2 tub won't fill at beginning of cycle
HI, you have a combination issue. the Water fill level pressure switch and, the cycle selector switch are both damaged and, they should be replaced. the total cost of these switches will run you about $90.00.
We recommend the hands of a skilled service tech when repairing this type of electrical issue.
Jun 18, 2009 | Whirlpool Washing Machines
Washer won't wash
Hi!
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 30, 2009 | GE Washing Machines
Water fills to proper level but agitator doesn't come on instead there is a grinding noise, when I move control to just prior to rinse cycle water drains properly, but still just grinding or buzzing n
Hi, Do you know if the washer spins at all?
It sounds like the coupler has gone bad.
Please let me know if it spins at all.
I can send yyou instructions on changing the coupler.
Vic
May 28, 2009 | Whirlpool LTE6234D Top Load Stacked...
Washer not filling up with water at beginning of cycle.
Don't replace anything. You will need to clean out the tube which connects the water level switch to the tub. (or replace that tube)
Feb 26, 2009 | Kenmore Washing Machines
Washer keeps filling with water...
you hae a stuck float switch, it shuts water off when it reaches a certain height, fixing it involes removing the top of the washer (not easily done)
Jan 11, 2009 | Kenmore 22422 Top Load Washer
Shutting down on rinse cycle
Hi this could means that you may need to replace the washing machine bearings. Once the bearings are bad, the motor overheats and it will automatically shut down after the first rinse.
Timonty from WashingMachineAdvisor.com
Jul 28, 2008 | Kenmore 44072 Front Load Washer
Whirlpool LTE5243D Top Load Stacked Washer/Dryer Logo
51 people viewed this question
Dan Webster
Dan Webster
Sal De
