Question about The Learning Company Achieve! Math & Science Grades 1-3 (381933) for PC, Mac
What is the area of a semi circle the diameter is 2.500mm the radious is .425mm the circumfrence is 3000mm
  • kenpie Oct 31, 2008
    thanks but it was not a true circle it was a sectional circle ''more like a half moon''
    Sorry its my fault for not being clear, its not the diameter its the axis 2.500 mm and the radius is 0.425, please help.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 185 Answers
You cannot have a semicircle that has a diameter of 2.500 mm and a radius of .425mm and a circumference of 3000mm
Circumference is equal to pi times the diameter. pi is = 3.14
The radius of a circle is always 1/2 the diameter
Area of a circle is pi time the radius squared
Loringh
Posted on Oct 31, 2008
  • Loringh
    Loringh Oct 31, 2008
    Ok, in order to calculate the area of of a non circular section, you would have to have the equation of the line, but that gets into calculus and that probably is not where you are at. BTW, just for your info so you won't thik I'm blowing smoke I used to teach high school math, Alg I, Alg II and Geometry.
    What's your situation with this problem? maybe I can still help if you can upload a sketch of the section
    Good luck Loringh
  • Loringh
    Loringh Nov 01, 2008
    This is not a simple problem. If I understand you correctly what you are trying to find is the area of an arc in a circle as defined by a chord and a perpendicular from the chord to the edge of the circle section
    Go to this web page and you will find the info you are looking for
    http://mathforum.org/library/drmath/view...
    Hope this helps Good luck Loringh
What is the area of a circle if the circumference is 2 pi inches
area formula is PI x r squared
that is 3.1417 times the radius of the circle squared
example is:- 3.1417 times 3 inches squared =3.1417 times 3x3=3.1417x9=28.279 square inches if you want to work back from a circumference measurement, the formula for circumference is 2 x PI x radius or PI x diameter
if you have a circumference of 12 inches then the dia is calculated 12 inches = dia x PI to get the diameter , divide the 12 inches by PI and that will be the diameter so that is 12 divided by 3.1417 =3.819 inches
now you can go from the first formula the radius is the diameter divided by 2 so the radius will be 3.819 divided by 2 = 1.909 inches
so applying the area formula it becomes 3.1417 times 1.909 times 1.909 =11.458 square inches
to find your answer simply substitute the dimensions in place of the example figures.in the relevant formula.
Aug 24, 2015 | Office Equipment & Supplies
How many gallons in 28" diameter by 20"
Just a little over 53.3 gallons
Mar 20, 2015 | Water Heaters
Area of circle
(pi)R squared (Fixya won't let me use the sign for Pi)
Area of a circle=pi*radius^2 or pi times radius times radius
example: suppose the radius of a circle is 10 inches, then the Area of the circle would be pi times 10 times 10 or 100*pi
pi represents the circumference (distance around) of a circle / diameter and for any circle is constantly the same number which is approximately 3.14
so in my example 100*pi=100*3.14 or 314 square inches
Jul 03, 2014 | Computers & Internet
How do you find the circumfrence of a circle?
If the circle is a drawing, you can measure the diameter and multiply by pi (3.14). The diameter is the widest crossing and goes through the circles center. If the circle is an object, you can wrap tape around it. Mark on the tape where it meets up with the start. Remove the tape, lay it flat and measure it.
May 08, 2014 | Computers & Internet
WHAT IS THE AREA OF a circle with a diameter of 20 cm
Come on princess. Use the formula for the area of a circle: Area=PI*D*D/4
where PI can be entered using a key on the calculator, and D is the diameter.
Area =100*Pi cm^2 or about 314.159 cm^2
Feb 03, 2012 | Office Equipment & Supplies
What is the pi button
Pi is a mathematical constant whose value is the ratio of any Euclidean plane circle's circumference to its diameter; this is the same value as the ratio of a circle's area to the square of its radius. It is approximately equal to 3.14159265 in the usual decimal notation.
Mar 05, 2011 | Casio FX82MS Scientific Calculator
If you know about area formulas of class 8 and 9,please solve my question?there is a circle.in the between of the circle,there is a rectangle of dimension 4cm and 3cm.if the rectangle will cut out what...
The diameter of the circle is the diagonal of the rectangle use Pythagoras this rectangle is a made from two 3,4,5 triangles, so the diameter is 5cm, the radius will be 2.5cm don't forget the BODMAS ordering rule (Brackets of Division Multiplication Addition and Subtraction) Also rounding to 2 decimal places. This solution is based on all four corners of the rectangle touching the circumference of the circle.
Area of a circle is P (22/7) i x Radius (squared ^2) ====> 22/7 x 2.5cm ^ 2 ====> 22/7 x 6.25cm
TOTAL AREA of CIRCLE = 19.64 cm^2
Area of the rectangle is length x width ====> 4 cm x 3 cm
TOTAL AREA of RECTANGLE = 12 cm ^2
The remaining portion is the circle area minus the rectangle 19.64-12 = 7.64 cm^2
SIMPLES brought to you by SpideRaY @ http://www.windowstipsclub.com
Jan 31, 2011 | Computers & Internet
Example of program in c++ and there code
Hello my friend, I am Jonas I work as a programmer in some various programming languages. Here try this code:
This program is design to output the Diameter, circumference, and area given a radius of a circle. #include <iostream.h> int main() { int radius, diameter, circumference, area, pi; cout << " Enter the radius of a circle\n"; cin >> radius; pi = 3.14159; diameter = 2 * radius; circumference = 2 * pi * radius; area = pi * (radius)^2; cout << "Diameter formula executing.....(2 x r)\n"; cout << "Diameter is " << diameter << endl; cout << "circumference formula executing.....(2 x pi x r)\n"; cout << "circumference is " << circumference << endl; cout << "area formula executing......(pi x [r x r])\n"; cout << "area is " << area << endl; return 0; }
Also if you need tutorial you can visit this site Learning C++ .Hope this solution will able to help your problem solved. If you need more assistance just reply to this post or send me a mail at geo_jonas@yahoo.comThank you and Godbless.
Jul 09, 2009 | Computers & Internet
Circle circumfrance how can define pi valu 22/7
Entire books have been written on this topic; it's far beyond the scope of a single post. I would recommend the book "The History of pi" by Petr Beckmann for a readable, non-technical introduction.
Jul 17, 2008 | Office Equipment & Supplies
Excel formula
the formulae for the surface area of round disc is
pi * r * r
where pi=3.14 and r =radious of disc= diametre/2
for this 1st u have 2 calculate the radious of the disc that is
180/2=90mm
then convert it to  m by dividing 1000 ,so radious=90/1000=0.09 m
finally calculate the area= 3.14 * 0.09 * 0.09=0.025434 sq metres
for 38 disc multiply 38 with the above area that is
0.025434 * 38=0.966492 sq metres
in excel 2007  u can do it more easily by going 2 formulas tab.
Under formla tab click on engineering formula and  then convert
here u can convert from mm to m
after converting use the above formula i just told u.
Feb 27, 2008 | Computers & Internet
The Learning Company Achieve! Math & Science Grades 1-3 (381933) for PC, Mac Logo
432 people viewed this question
Top The Learning Company Computers & Internet Experts
k24674
Bapco
Are you a The Learning Company Computer and Internet Expert? Answer questions, earn points and help others
