Question about Western Digital External USB 2.0 80 GB Hard Drive
WRITE PROTECT I JUST BOUGHT A WD 360 EXTERNAL HARD DRIVE--MY OS IS VISTA HOME PRE-- EVVERY TIME I TRY TO ACCESS MY EXT DRIVE I GET DRIVE IS WRITE PROTETED -- TRIED UNPLUGING AND RESTARTING-- CANNOT FIND SETTING FOR WRIE PROTECT IN PROPERTIES--PLZ HELP
  • WSSHAKY101 Oct 30, 2008
    UNLOCKER--will not work it is the entire hard driv e that is write protected--there are no files on it as yet--also it is formatted as FAT32 if that helps--tried to reformat but write protected again. is there a command i can type into the command window that will undo this??
  • 1,031 Answers
You have to initialise your hard drive before usage This procedure is for adding a new, blank hard drive to your computer only.
Occasionally, a hard drive may not be detected by a computer running Windows XP or Windows Vista. If that is the case, you may need to initialize (write a signature to) the drive. If your drive is not detected by Windows XP or Windows Vista when you check in Disk Management, follow the steps below.
Note: In some cases, the Disk Signature Wizard will start immediately when you run the Disk Management utility for the first time after adding a new drive.
  1. Right-click the My Computer or Computer icon on the desktop. If there is not a My Computer or Computer icon on the desktop, you can find the icon on the Start menu.
  2. Left-click on Manage.
  3. Left-click on Disk Management.
  4. The Initialize and Convert Disk Wizard will appear.
  5. Left-click on the Next button.
  6. Check the box to the left of the drive that you want to write a signature to.
  7. Left-click the Next button.
  8. Left-click the Finish button.
The drive is now initialized. You should now be able to create a partition and format it. hope this helps
Posted on Oct 30, 2008
    Master:
  • 848 Answers
There is software called unlocker ........
download it to remove this error ...........
  • gopinath pasupathy Oct 31, 2008
    - Download *MBRFix.exe* to your User folder( http://www.sysint.no/nedlasting/mbrfix.h...)
    - Boot the computer
    into a fresh session
    - Go to -Start | All Programs | Accessories-
    - Right-click on *Command Prompt*
    - Choose -"Run as administrator"-
    - Choose -"Allow"- from the UAC popup box (if you haven't turned it
    off)
    - At the *C:\Users\{your name}\>* prompt, type
    *MBRFix /drive {drive number} fixmbr /yes*
    - Repeat the command for however many drives are infected/write
    protected
    - Restart and check your antivirus or see if you are still unable to
    write to the drive
    - Boot the computer
    off)
    protected
    write to the drive
  • 13,433 Answers
There is possibly a write protect switch in the hard drive case, I will confirm this and get back to you.
  • Ekse Oct 30, 2008
    Can you post me the model details and everything else you can see on the external harddrive so I can find the correct one?
    Thanks.
    Ekse
Problem with the Mobile Disk External Data Storage Enclosure model HD-338-COMP for my 80gb Western Digital HD
just a suggestion but a few years ago is aeons in tech time maybe, just maybe the drivers for that ext drive were overlapped with OS X migration?
check apple site for more or ext drive site for latest drivers
Jun 02, 2012 | Beyond Micro Mobile / 250GB / 7200 / 8MB /...
Hi. My computer says I ejected my WD My Passport external drive but it was not properly ejected. How can I fix this. I need all my thesis files but computer can read the external drive! Help please!
Try to test your WD Ext HDD to a different computer and check if you will get the same problem.
If the same problem persist try to use a different cable for your WD Ext HDD.
If still fails kindly ask the store where you bought the WD Ext HDD on how to retrieve your files and have WD EXT HDD replaced?
If your WD Ext HDD works to a different computer then update the BIOS and Chipset of the computer where your WD Ext HDD connected previously.
Hope this helps.
May 29, 2011 | Computers & Internet
My WD My Book Essential 1TB External is not showing up on 'My Computer'. It was working perfectly in the morning, then when I rebooted my machine it no longer showed up.
disconnect your WD ext HDD. and reboot your computer. then connect again. if still not showing. go to device manager (right click my computer then properties -- click device manager). expand by clickin "Disk drives" category here it will show all the hard drives installed in your computer including your WD ext HDD . if you see yellow sign on your external drive right click and remove then go to Action menu click on Scan for hardware. it should detect and install the driver again. if still the same or maybe its not on the list of Disk drives.. try to change another USB cable .. i hope this will help
Jan 03, 2011 | Western Digital My Book Essential 1TB...
I need to make room on my internal ''C'' drive...was advised to move as many folders as poss to free up space. Have moved Pix, Movies, Doc, Links etc to my WD 500 gb ext HD, but cannot move desktop or...
Have you "emptied" your Recycle Bin?
From the "Start" menu, look in "Accessories".
One of the accessories is a "disk cleanup tool". Run it.
It will also delete all your "Temporary Internet Files" that Internet Explorer has created.
Now that you have "moved" your pictures and movies,
what will you do if your external hard-drive "dies",
taking your _only_ copy of those files to its grave?
It's time to buy a *NEW* "internal" disk-drive, e.g., 400GB for under $100 for a "laptop" disk-drive, reinstall Windows onto it, and copy (not "move") all your files from the external disk-drive to the new disk-drive.
Jan 04, 2010 | HP Computers & Internet
I recently reinstalled my OS (Windows XP Media center edition). Ever since i reloaded the OS my WD My Book Home edition 1TB external HDD stopped showing up in the windows explorer as a drive letter. The...
I can't diagnose the drive issue... but I can offer a reliable and trustworthy data recovery solution that I had to use a year ago. It's Seagate's do it yourself data recovery and will work on your WD drive. So if you can't resolve the issue otherwise, consider this as a recovery option...
https://services.seagate.com/diysoftware.aspx
Sep 24, 2009 | Western Digital MY BOOK HOME 1TB EXT...
WD My Book not displayed in windows explorer as drive letter
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use this program to recover your files.
http://www.asoftech.com/adr/
Western Digital 1T MyBook keeps crashing
it seems a problem with the driver, try plugging it onto a different computer. If that works, reinstall the driver.
Aug 14, 2009 | Western Digital MY BOOK HOME 1TB EXT...
REMOVE WRITE PROTECTION FROM EXTERNAL DRIVE
insert your memory stick or your external drive / go to My Computer / right click your drive / go to properties / under the Security tab, just check the Full Control under permission / click apply then ok
hope this helps
Nov 04, 2008 | Western Digital (WD3200JS) 320 GB Hard...
Wd Hdd inaccessable
try to disable all firewall setings or antivirus...after try accesing frome ur command prompe if u can that the windows is blocking the hdd...uninstall any new software or driver and try again...no effect ok dowload ophcrack live cd frome google and access the hdd by force repare or scan it in surface scan that will fix ur clusters problems that might be in the back off this prob an du know wer e2 go frome there
Feb 12, 2008 | Cavalry Storage Cavalry CAUO37500 500GB...
Western Digital External USB 2.0 80 GB Hard Drive Logo
280 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
