Question about Eljer Aqua-Saver 12" Two-Piece Pressure-Assist Toilet - 091
No back flush pressure
I have 1.6 gal tiolet (eljer) and when u flush there is no back flush pressure to take everything out. i have snaked the roof vent ,changed from the ball to a new water flow mec,put a new flapper. if u dump 1 to 2 gallons of water in the bowl it flushes perfectly,so i figure that there is no drain problems plus the tiolet on the other side of the wall different brand flushes just fine
  • tiptop49 May 11, 2010
    how do i increase the water in the bowl by half an inch?
    Genius:
  • 1,605 Answers
Increase the tank water level half inch at a time till you have the back flush pressure.
seems like the water in the bowl is too low to create any wirlpool.
Posted on Nov 07, 2008
Down stair toilet bubbles when upstair toilet is flushed. never had this problem with old toilet
The roof vent for the toilets is shared. It is the pipe (on the roof) that lets water in the drain system. When clogged, it causes what you have. A garden hose placed in the roof vent (and turned on) may clear the blockage (could be leafs or pine straw or a dead bird). Needs to be cleared... I have used a plumbers snake with 100% success....but you may not have one...so the garden hose suggestion. Be careful on the roof.
Mar 01, 2014 | American Standard Home
Tip
Tub drains slow
does your bathtub drain slow, and toilet not flush? dont call a plumber just yet, Every fixture in your home should have a air vent associated with it. the vents allow gases to escape and are necessary in allowing the waist water to flowout and down the pipes. most vents lead up through the roof, these are usualy 2" in diameter and raise up about 20" from the roof. there are other ventsin and around the home like the drain pipe for your washer or the overflow drains in sinks and tubs. If you have a tub that drains slow its usually hair buildup in the trap and is simple to clear. If you have a problem like the one i had and you've tried everything and it still wont drain the vent may be clogged. In my case the toilet wouldnt flush allong with the tub draining very slow, I threw every thing i could at the problem including removing the toilet and running a power snake. You can imagine how i felt when i put the toiket back in place and when i flushed it nothing happened:( after some thought i went to the tub and removed the chrome cap 0ver the overflow and ran a wire with the end bent like a hook as i pulled the wire out the toilet flushed, on the end of the wire was a clump of hair . problem solved!
on May 05, 2012 | Plumbing
I have a Cadet 3 toilet with a slow flow when flushed.I just had my sewer lines cleaned and had to pull the toilet. After I reinstalled the toilet, I discovered the slow flow.A toilet snake was used on the...
It could be a venting issue. Check the roof vent for the plumbing system. Perhaps clogged with leaves or other debris causing a blockage in the vent line. You can use a hose up to the roof and flush out the vent line. Another problem may be calcium buildup. CLR , a product available at most hardware and grocery stores will dissolve mineral buildups.
Oct 11, 2013 | American Standard Home
I have a new saniflo tiolet when flushed the paper stays in the bowl untill the tiolet has been flushed 2 or 3 times
the unit sounds like it is not vented properly check vent connection if there is a venalator on it that dosent work it has to be vented to attic the pump has to vent in and out not just in that the ventalators are designed for
Nov 16, 2010 | Saniflo Sanibest Grinder Pump Only 013
Our Kohler K3402 suddenly stopped flushing. When you pull the handle and the flapper comes up, all that happens is the tank begins draining into the bowl and the bowl level rises, almost to the rim. The...
If there is a shower in the same bath is it also draining slowly?
If so check that drain systems air vent, (on the roof).
Find the pipe coming out of the roof nearest the bathroom with the problem and when a second person flushes the toilet you should be able to feel
air moving in and out of the pipe with your hand covering the end. If not the vent could be blocked by leaves or animals etc., this vent has to be clear in order for water to drain properly.
May 20, 2010 | Home
Problem: when I flush my toilet most often the water swirls around and doesn't flush. I've tried bending a coat hanger and snaking it through the exit hole to see if there was an obstruction. Any...
This is a job for a plumber unless you have a ladder. The vent pipe may be plugged or the trap in the toilet may be plugged up but this requires removing the toilet from the floor which is not that hard. two floor bolts and and turn off the water valve and disconnect the water hose then lift the toilet up and see if there is blockage by poring a gallon of water into the drain pipe. if it backs up you need to snake out the main line. You can rent a electric 25 foot snake for 35 bucks but then you have to reinstall everything plus buy a new wax ring which is about 5 bucks. if the pipe is clean and drains fine then you need to run water into the toilet outside to clear the throat of the toilet if there is no blockage then the vent pipe may be plugged and that you have to get from the roof. Best bet is call a plumber.
Jan 05, 2010 | American Standard Colony 2388.012.222...
After flushing the tiolet the water level in the bowl returns but then starts to empty out through the trap again until it starts gluggin for about 10/15 seconds and then re-fills and is ok untill the next...
It sounds like your toilet is not vented properly. Either there is no vent pipe (which is not likely since it has worked properly for a while), or the vent is plugged. Possibly an animal or bird has gotten into the vent stack going out the roof of your house and plugged it. When the vent is plugged, the water in a trap or toilet bowl will get sucked out as the water from the flush goes down the drain. I would say to have someone check your venting.
Good luck.
Dec 04, 2009 | Home
Toilet wont flush completely. it may take 4 times or more to flush solids. i at first thought this was related to heavy rains we had been receiving in the area over a period of about 4 months. 2 days...
there is no air release. the vent must be clogged somewhere. you can take a hose up there and see if it drains all the way or floods over. since the tub drain has a trap and the toilet itself is a trap, there has to bee a good amount of air pressure coming up without a release. i would say an obstruction. possibly at the junction of the main and the vent.
Nov 09, 2009 | Eljer 091-2190-43 Platinum Patriot...
Slow water leak past flapper seal.
Replace flapper, it is worn out.Turn off water valve. Flush toilet, remove flapper. Then replace flapper, adjust chain to same size as old one, then turn water back on.
Aug 19, 2009 | Eljer Toilet Onepiece Canterbury ...
Toilet water wont go down
I have found on many occasions this problem was caused by an obstuction in the internal trap of the toilet. Everything from toothbrushes to Batman figurines have been removed from them. If you intend to do the repair yourself you can use a closet augerwhich is a manual cable snake tool that will be inserted into the bowl of the toilet and the cable ran through the toilet's internal trap to clear obstructions. You could also rent a hand held electric auger that is basically a drill with a drum attached with a drum with coiled cable inside that is shoved down the channel the same as the aforementioned product. This device take a bit of finesse and skill as the cable will try to kink and coil up as you go one can get injured doing this. If you find that the toilet is clear of internal obstructions you may have to pull the toilet up as the obstruction may be further down the line. If you rent a medium sized electric auger you can locate the vent stack for the toilet and run your cable down the vent from the roof so you may not have to pull the toilet. This method will only clear obstructions behind the vent connection and not the length from the connection of the vent to the toilet itself. If yo have an elevated house you may have access to a clean out that by most codes are at every change of direction greter or equal to ninety degrees. You also should test your water pressure if all else fails as that specific model must have at least 25 psi at the very least to operate correctly. Hope this helps you out.
Sep 30, 2008 | Eljer Aqua-Saver 12" Two-Piece...
Eljer Aqua-Saver 12" Two-Piece Pressure-Assist Toilet - 091 Logo
512 people viewed this question
Top Eljer Home Experts
john h
Mike
Donni Steen
Are you an Eljer Home Expert? Answer questions, earn points and help others
