Question about Kenmore Dishwashers
Kenmore model 665.17374301 dishwasher
Water does not drain from dishwasher. Replaced electronic control board and problem was not corrected. Purchased new drain pump but want to determine other possible problems before pulling washer from wall. Any suggestions on other items to check, and the checking procedure, will be appreciated.
  • 5 more comments
  • resmes1 Nov 04, 2008
    I have replaced the electronic timer and drain pump. The drain line has been removed,cleaned and replaced. My parts list does not show a drain valve. The accumulator Assy. was removed and the top of the sump was vacuumed out. The washer still does not drain.Could the sump check valve be the problem? I am able to trouble with a volt ohm meter with instructions. I help for this specific dishwasher.
    The drain line is plumbed to the sink drain. I have checked the sink connection and it is open,and the sink drains normally. I do not hear water going into the drain during the drain cycle. This washer has a three wire motor and a separate drain pump which I replaced. How does the motor affect the drain cycle and how can I check it for operation?
    Lights on the control panel are on and change when when the washer changes cycles. The dishwasher has power and appears to operate normally with the exception that when the washer stops at the end of the wash cycle, water remains in the bottom of the tub up to the lip of the door. When I press the "Cancel / Drain" button no water is pumped from the washer. Also, no water is heard to be draining from the washer during its wash cycles. This washer was purchased new from Sears on 09/03/2004. On 05/16/2005 a new pump and motor were installed by Sears under warranty.
    My third comment posted Nov.4, was in response to your Nov. 4, reply concerning a possible blown fuse. As I stated, the washer has power and panel lights are on when the washer is running through its cycles.
    The drain pump was replaced and the pump that was removed had no parts missing. The pump on this washer is separate and not part of the motor. Please look at the model number of the dish washer which was purchased new in 2004. Most of the information you have provided pertains to older dish washers. I have a Whirlpool repair manual, but it was last up dated in 1999 and most of the info. is not applicable to later model dish washers.
  • resmes1 Nov 05, 2008
    FixYa is not providing information that is useful for the repair of my dishwasher. Either provide information that pertains to my dishwasher or return my payment.
    You are not reviewing and responding to my comments. Please return my payment.
  • 958 Answers
if i may offer a solution before you make a refund.
you have done your home work but somehow you have not mentioned if you check the wire itself from the board to the drain pump. check the continuity please. you may just have a broken wire. check the voltage from the board if it has power to the pump when draining then check the voltage at the motor if the voltage is present now at the motor. if there is no power at the motor and there is power to from the board, then the line is broken somewhere to the pump.
hope that solves it.
tnx 4 using fixya,
drcool
Posted on Nov 05, 2008
  • francis rivero Nov 12, 2008
    hi resmes 1,
    just a follow up, have you had your dishwasher running by now? has the pump pumped out the water? i noticed you have not seen my solution since i am the only one without a rating.
    i hope was able to help,
    tnx 4 using fixya,
    drcool
  • 899 Answers
If the drain valve does not open and the pump motor comes on then the valve is either stuck or not working anymore
if you hear the valve open(click sound at drain cycle)but not the pump motor , then the motors fuse or the pump motor needs to be replacd
but if you see the water level has not gone down and the pump motor is running then there is a problem with the valve or the plastic paddle wheel attached to the end of the motor is not holding to the motors shaft( thus not spinning)
what can you tell us about what does seem to engage on those parts and or what does not?
Posted on Nov 04, 2008
    Genius:
  • 2,120 Answers
There is a $2.00 part called a flapper that is inside of the pump assembly that breaks off and clogs the outlet.
  • Leroy Elliott
    Leroy Elliott Nov 16, 2008
    I'm tellin' ya, it's the rubber flapper.
  • Leroy Elliott
    Leroy Elliott Nov 17, 2008
    Take the freakin' pump apart and change the rubber flapper $2.00
    President:
  • Kenmore Master
  • 2,651 Answers
Deos not drain water at all??? is there any lights lit on the control panel??? you have a kenmore machine made by whirpool, a common problem is that a fuse blows when entering the final heat cycle, which would drop out all power to machine, the fuse is actually the little white 2 wire thermo that was located on the control board housing, a simple check will tell you good or bad you should have continuity through the fuse(part number 8193762). thinking in 7yrs w/ this machine had maybe 2-3 bad drain pumps
  • Ron Coons
    Ron Coons Nov 05, 2008
    you should really check your wiring for a possible broken wire leading to the drain pump, a common spot for a break would be at the point where the wires are bundled together making the transition from the door area to the main tub, you can check for power at the pump by inserting your leads in the pump assy and pressing the cancel button . you should have a tech/sheet troubleshooter behind the lower acess panel if not. heres a link to a techsheet finder insert the model number KUDI01FLBL2(your whirlpool equivilent number) open the tech sheet and youll find a strip circuit(wire diagram) of where your drain power comes from and if you have new electronic and new drain pump bad wire is about only other option here
    http://www.servicematters.com/docs/wirin...
  • 728 Answers
You may need to check the drain pipes and make sure they are not clogged or broken to the point where it can not drain. Also you may have backup past the pipes in the place where the water exits out to. If this is the case, you may need to get a plumber to check for backup in that area. And try listening to see if you hear any noise when it is supposed to drain. If you do, then the motor works and if you do not, you may need a new motor or to see if the one you have is jammed.
  • Jazz Boyce
    Jazz Boyce Nov 04, 2008
    Well since I am guessing it is not still under warranty, try taking it to a shop and tell them it will not drain and they will perform tests and they should tell you what is wrong and they should be able to fix it. You might have to get it out of the wall to get it repaired and back to working the right way.
  • 13,433 Answers
If the water doesn't drain from your dishwasher, check these:
Drain line/air gap A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Pump Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Belt One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it.
Motor If the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced.
Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced.
Timer Part of what the timer does is control the motor and drain valve. If the timer doesn't work properly, the water may not drain and you need to replace the timer. This problem is uncommon.
Posted on Oct 30, 2008
The 4th green light on my Ariston dishwasher flashes. What does this mean?
You did not mention what model number that you had but this is what I found after a little digging:
From http://servicetechhelp.com/discus/messages/2801/6823.html?1205974228 :
For future reference, the technician who replaced the control board for me gave me a complete list of flashing LED fault codes for the Ariston LL65 (which are same as Ariston LL64):
001000 Float Switch: Water in Base Pan
001100 No Drain: Dranin Motor Disabled, Filters Clogged, Dramin Hose Blocked
001010 Main Motor Presure Switch Blocked Filter
100100 Control Board: Software of Control Board not Recognized.
000100 Water Valve: Water Valve Diabled <--- This one sounds like your error
000110 Fill Fault: Water Valve Disabled, Turbine Disabled or Control Board
000101 Heating Element disabled or High Limit Open or Control Board
000010 NTC defective or not positioned or control board
000001 NTC defective or not positioned or control board
KEY: 0 = LED off
1 = LED flashing
I also found this for a different model:
http://www.diybanter.com/home-ownership/89945-resetting-controller-ariston-dishwasher.html
No Program Code Fault condition
1 Heavy wash 1000 Operation of flood
protection system
2 Normal wash 0100 Heating
element/Thermistor/Thermostat fault
3 Rapid wash 0010 Drain pump fault or drain
blockage
4 Soak wash 0001 Not filling to correct
level within 6 minutes
Mar 02, 2011 | Dishwashers
How to reset control panel on model 587.1517 kenmore dish washer
From what I have read elsewhere, the interrupt *may* have something to do with a thermostat circuit cutting out if the entry hot water is too high ( more than 145F) - it seems like a buggy safety feature i.e. the circuit board thinks that the water heater is overheating. The makers have apparently made changes to the control board to fix this bug but it costs serious $$$ to get a repairman in and buy the new board.
I prefer to use the reset code, and keep my water temp lower when using it.
Feb 20, 2011 | Kenmore Dishwashers
Kenmore h2 error code
April 8 2002 DIV 26 SOURCE 110 KENMORE ELITE HE3 & HET WASHERS "ADD-A-GARMENT" INDICATOR LIGHT ON DOOR WON'T UNLOCK WHEN PAUSE/CANCEL BUTTON IS DEPRESSED.
MODELS: See additional page for Kenmore model numbers
COMPLAINT: Due to a Microcomputer Machine Control software error , the ADD-A-GARMENT feature becomes inoperative.
CORRECTION: The Microcomputer Machine Control must be replaced with a service part that has been reprogrammed to prevent ADD-A-GARMENT feature loss.
PARTS: Order electronic control listed on this service flash by model from Division 26 , Source 110 following normal ordering procedure.
MERCHANDISE CODES: WASHER Service Flash - Model Nurnbers for: Kenmore Elite HE3 & HE3t Washers: "ADD-A-GARMENT" indicator light on door won't unlock when Pause/Cancel button is depressed. Kenmore models with serial Numbers beginning with CSL23 through CSM04 11042822200 11042824200 11042826200 11042832200 11042834200 11042836200 11042922200 11042924200 11042926200 11042932200 11042934200 11042936200 Electronic conrrol p/n 8181900 Electronic control p/n 8181899
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 11, 2010 | Kenmore 46462 Front Load Washer
Kenmore ultra wash dishwasher model 15752000 is not draining completely after cycle has finished
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter.
Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Oct 21, 2009 | Kenmore Dishwashers
My GE monogram dishwasher won't drain. The (3 different) repairmen who came to my home checked the hoses, replaced the pump and replaced the motor. Nothing worked, and they suggested that the home warranty...
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly
If this model doesn't have a drain solenoid to inspect(uncommon), this will lead to a control issue with the main control board or timer module. replace if found to be defective.
remember, the drain command is initiated by the control.once the command is issued, the pump will carry out the actions of draining the unit. if the control is faulty, it will not issue the command properly.
Jul 10, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
My dishwasher wont drain out? any ideas?
Start checking drain hose first.
Check water level switch.
If water level is ok check drain pump lines , and test drain pump.
If everything else is ok, test the control board (uncommon).
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
May 17, 2009 | Kenmore Dishwashers
Kenmore Elite Oasis Top Loader no spin and then some.
The F1 error code on this washer indicates a Primary Control Board failure.
It is likely that the machine control board will need to be replaced to correct this problem.
The part number for the machine control board is undetermineable because you have not provided me with the exact model # of your washer.
The procedure for replacing the machine control board is provided HERE
LINK: http://media.fotki.com/1_p,wfgstgtftbtkrrdxgtqsskgwtqkq,vi/gfsfgfsgqxgfqtqtgwf/1/1303472/5961857/image55806img-or.gif
NOTE: Be sure to unplug the washer to disconnect electrical power before accessing internal components.
There is a slight possibility that a problem with the pressure switch hose could be causing this problem.
A pinched or twisted air hose can cause this fault code.
When you open the console, check the air hose connected to the pressure switch on the machine control board.
If it is pinched or crimped, I recommend rerouting the hose to resolve this problem.
This may fix your problem without replacing the control board.
NOTE: You may want to check for this condition before ordering the control board. Most electronic control boards cannot be returned for a refund or credit.
If you find no apparent problems with the air hose on the pressure switch, then replacing the machine control board on this washer should correct your problem. There is a risk involved in replacing this part yourself.
As noted above, you could have a problem with the air pressure hose that is not apparent upon your initial inspection. A service technician would normally need to properly and thoroughly diagnose this problem before replacing the control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question!!!!!
Apr 24, 2009 | Kenmore 27032
Power issue
There may be a thermal fuse located on the electronic control board housing that may have failed.This replaceable part (gray or white) is clipped on to the side of the housing.
Jun 13, 2008 | Kenmore 74383 Stainless Steel Dishwasher
Sears Kenmore model# 665-16022401 Serial# FS0304946 - Clean Light Blinking
THE HUMMING NOISE THAT YOU ARE HEARING IS THE ELECTRONIC DRAIN MTR ACTIVATING BUT YOU HAVE NO WATER IN THE SYS. SO IT SOUND LOUDER AND DIFFERENT THE HUMMING IS THE LESS OF YOUR WORRIES THAT IS NORMAL BUT WHAT IS NOT NORMAL IS THE CLEAN LIGHT FLASHING IF IT FLASHES 7 TIMES THEN PAUSES YOU HAVEA BAD PROCESSING BOARD AND ALSO A HEATER ON SOME OF THE KM MODELS THE CONTROL BOARD AND HEATER IS SOLD AS A KIT. TO VERIFY THAT THIS IS THE CASE GO TO WWW.SEARSPARTS.COM . BUT FIRST ALSO CHECK TO SEE IF YOU HAVE A BURNT WIRE AT THE HEATER ASSEMBLY WHICH WOULD REQUIRE PULLING THE DW OUT. GOOD LUCK
Mar 12, 2008 | Kenmore 24 in. 15252 / 15254 / 15259...
Dishwashers Logo
157 people viewed this question
Top Kenmore Dishwashers Experts
D. E. Hev
Fred Sops
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
