Question about Pyle PLA1585 Car Audio Amplifier
Remote on and off.
Got a problem with my pla 1585. if i turn on the amplifier then remote first shows a fail ( protect mode ) if i turn it off an start op the amplifier again it goes green. what seems to be the problem?
0 characters
1 Points
How do i fix my Power Acoustik LT-980/2 car amp, it keeps on going into protect mode.
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty . .A thumbs up would be greatly appreciated if this answer is helpful to you
Aug 10, 2011 | Power Acoustik LT-980/2 Car Audio...
How do you reset nitro amp that is in protect mode?
If the amp is in protect mode, then there may be a speaker wire that is shorting out or you may have a bad can test this by completely unhooking the speakers on the amplifier and then turning the amplifier on...if it comes out of protect mode then you will need to find out which speaker is bad...if the amplifier does not come out of protect mode when you turn it back on then there is a problem inside the amplifier and you will need to take it to a service shop for further diagnoses
May 15, 2011 | Nitro BMW-482 Car Audio Amplifier
My phoenix gold x200.4 amp turns on but the protect light keep on flashing
  • What does it mean when the LEDs flash on my amplifier?
    With most recently produced Phoenix Gold amplifiers, a flashing/blinking LED is an indication that the unit is in protect mode, usually due to an overcurrent condition caused by an internal short, external short (speakers), or low impedance. Overheating will also cause the amplifier to shut down temporarily.
    If amplifier remains in protect mode, power down the amplifier, disconnect the speakers, and power up again. If LEDs continue to flash, there is probably an internal problem with the amplifier that will require service attention to fix.
  • Sep 23, 2010 | Phoenix Gold ZX600ti Car Audio Amplifier
    Its in protect mode and wont go back to normal
    disconnect everything except the power, remote, and ground. turn off then on. if it goes into protect mode then there's a posibility that the amp if fried. check all the speaker inputs and outputs to make sure that there are no stray wires shorting out. if it stays on then you may have a short on a speaker wire or an auxilary input wire. plug each one in one at a time until it goes into protect mode, then that's the shorted wire or it could be a shorted speaker.
    Aug 09, 2010 | Nitro BMW-486 Car Audio Amplifier
    My nitro bmw-486 amp is in protect mode how can I
    Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty De .A thumbs up would be greatly appreciated if this answer is helpful to you. nitro-bmw-486-amp-in-protect-mode-lv2kkrmxrai4iihdvw4m3np2-1-0.jpg
    Feb 24, 2010 | Nitro BMW-486 Car Audio Amplifier
    Fusion amp soild bold red when the radio comes on
    The amplifier is in protection mode.
    3 reasons for this...
    1. Improper Load/overheat - wrong impedence voicecoils or wired improperly below rated impedence.
    2. Grounded Power - speaker wires touching, power wire touching ground,
    3. Internal component failure.
    if the amplifier will still not go out of protect mode after removing the speakers and jumpering the remote wire to the + terminal - your amplifier needs professional repair.
    Thanks for using FixYa - a good rating is appreciated for taking the time to answer your FREE question.
    Jul 08, 2009 | Fusion Digital designs EN-AM6004 Car Amp
    My amp automatically goes into protect mode
    There are 4 reasons an amplifier tries to protect itself.
    Overheating - thermal shutdown.
    Over Impedence - The subwoofers installed are not configured into a load the amplifier can handle.
    Output is grounded - a positive wire strand may be touching the ground terminal - a wire may be shorted, or a speaker voicecoil is blown.
    Intennal problem - Output on amplifier blown, or some other component has failed.
    Check your wiring to the amplifier again - if all is good - disconnect the speakers and try to power on. If the amplifier turns on normally - test the speakers for blown coils.
    If the amplifier still goes into protect mode - the problem is internal and needs professional repair.
    Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
    May 06, 2009 | AudioBahn A2301 2-Channel Class A/B Mosfet...
    I think my amp is in protection mode how do i trouble shoot
    disconnect speaker,turn gain down to about 10%.repower amp check and see if protection light comes on.if it does recheck power,remote,ground,if it doesent go into protection then kill power and rewire speakers
    Apr 30, 2009 | Visonik V2208 Car Audio Amplifier
    Diamond Audio amplifier 1200W
    If the speaker wires touched and the protection circuit didn't engage quickly enough, the output transistors may have failed. This is the most common cause for an amplifier to go into protect mode.
    If you disconnect the speaker wires from the amp and the B+ and remote voltage are above ~11 volts (place black meter lead on ground terminal of the amp when checking the voltage), and the protect light still comes on, the amplifier will need to be repaired.
    Nov 25, 2007 | Car Amplifiers
    Pyle PLA1585 Car Audio Amplifier Logo
    15 people viewed this question
    Top Pyle Car Amplifiers Experts
    Matthew Spark
    Matthew Spark
    Tygh Duval
    Tygh Duval
    Are you a Pyle Car Amplifier Expert? Answer questions, earn points and help others
