Question about Sony KDF46E2000 46" Projection HDTV
Sony rear projection tv keeps shuttin off
I have a sony KDF-46E200 rear projection tv. I changer the bulb but now it will turn on for about 5 minutes then shut off. There is a red light on the front that blinks 3 times. the manual says the bulb or cover is not in correcly but I've tried many times to take it out and put it all back the correct way, but still get same results
  • Anonymous Mar 28, 2014
    its showing the bulb indicator as well as the 3 blink code
  • 320 Answers
If you have correctly seated the lamp door, then check the door itslf near the screw that tightens it down. There is a little tip that sticks through a hole to engage a safety switch. Either the tip has broken off or the safety switch has gotten damaged.
Posted on Nov 08, 2008
  • Any Guy
    Any Guy Nov 09, 2008
    Is there any question I did not answer for you? Just wondering why you rated this as helpful
Problem for Sony Grand WEGA KDF-55WF655. Hello,
5 times Red LED blinks means Lamp Driver Error. (KDF-55WF655)
2 possible reasons, either Lamp is gone or Ballast Supply got bad.
Replace lamp first, in most cases it solved the problem.
How old is this TV and did you replaced lamp recently?
Thanks.
Oct 21, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
TV turns on for about 5 minutes then shuts off.
The projection lamp is out and needs to be replaced.
Jan 16, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
KDF-60XS955 shuts off intermittingly and red light flashes 5 times.
My KDF 60XS955 turned on and off like the above complaints. I had an appointment with a Sony Repair specialist but thought that since my bulb was getting really old and taking too long to warm up, I would change it before he came and tried to sell me one at retail cost. I then noticed that the set didn't turn off any more. I ran it that way for a week and then decided to put the old bulb back in and see what happened. Within 1/2 hour it had turned off twice so I changed it back and said that fixed it. I cancelled the sony tech and saved some money. I hope this works for some of you also.
May 26, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
Sony LCD television will not power on.
I get 5 blinking red lights for about a minute or so before it powers back down. The Sony TV has a specific light that i presume is supposed to light up when the bulb is out. I'm unsure if this is what it is.
no picture, no sound. tries to boot with green light blinking a few times. then goes to red blinking light, six in all, then waits a few moments, then another 6 blinking red light.
Bulb was already replaced several months ago but we do have the TV on for long periods of time.
Jan 15, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Sony Wega Rear Projection TV, Red light flasing
I had the same problem, it because of heat buildup, and the inside is fried, you need repair
Jan 02, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
KDF-42WE655 Wont power up
you need to buy a bulb for the tv its about 179.00 on ebay
Nov 07, 2007 | Sony Grand WEGA KDF-42WE655 42" Rear...
My sony tv will not stay on
If you replace the lamp and need to reset the Lamp Timer Reset procedure is: With The Set In Standby Press Display, 5, Vol Up, Power on the remote control Press Jump 3. Or, To Display The Lamp Time Press 2 Nine Times. To Reset Press 3, Mute, Enter. One of these should work on your model. Make sure you replace the bulb first. There is a possibility that the ballast could be damaged by a defective bulb as well.
Jan 18, 2007 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony KDF46E2000 46" Projection HDTV Logo
263 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
