Question about Emerson MW8987B/W Microwave Oven
How do I reset the time
I found it in the alley but it still works
  • William Miller
    William Miller May 11, 2010
    Please reply back with your brand and model number so we can help you.
Say the time is 8:15. Press the "clock" button, then 8, 1, and 5. Then press "clock" again.
Posted on Jan 16, 2009
Ge profile spacemaker xl1800
Have you tried unplugging it for 24 hours?? Usually a few seconds works but I've found sometimes that it takes a long time for the power supply to fully discharge and the cpu to reset.
Oct 13, 2013 | Microwave Ovens
I have a GE JVM2070 microwave oven that runs for a few seconds and then shuts down. I was told by a repair person that it was the smartboard. I replaced it ($200) and same problem. When it shuts down...
Sorry you found an ignorant repair person!
You have a failing (noisy) magnetron.
You should first return the unneeded circuit board.
Then see this FixYa solution even though your model number is different.
Jan 16, 2013 | GE JVM2070 Microwave Oven
Samsung SMH9151 trips breaker when plugged in
You have a sort circuit inside, call a repairman or take to the repair shop
Aug 23, 2012 | Samsung SMH9151 Microwave Oven
Everythink works except the microwave will not start. Is there a fuze that can be replaced to fix this ? Model # NN-2551 I found the user manual on-line, but I can't find the product spec sheet breakdown...
I'm not sure what you mean by "everything works". do you mean that all the lights and the timer work. Could it be in the timer or clock mode? Try pushing the timerand cancel buttons together.
Try changing the time using the clock function.
I believe your model has a child lockout. Please check your manual for instructions on unlocking this function.
Is it hardwired or plugged in? If it is plugged in you can try a power reset, by unplugging it, waiting a few minutes and plugging it back in. It is completely unsafe to try to work on a hardwired Microwave.
Please let us know if this solution is helpful to you. Thank you.
Dec 20, 2010 | Panasonic NN-S255 Microwave Oven
I have a GE household microwave (model JEM318A002) manufactured 7/1999. It is built into our cabinetry. Periodically it will freeze (nothing showing on the display...no response to keys; sometimes have...
Hello
sometimes you can find a small hole on the bottom or the back of the mircowave.. like the watches you stick a pen in to reset;; this is a reset for the mircowave you need a pin and do it just like the watches,
Also There bis a fuse on the inside panel or back panel after removing it.. the fuse or wires can be croded causing temporay memory loss ,if you clean it up it should hold memory how ever they do not recomend you open or remove the panel rom miorcowave only a experanced person should do this,it is up to you how to handle that
I gave you the information I know but also the safty about it if you do not feel good about opening it I just wouldn't do it
Good Luck
Apr 11, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Its locked
mine just did this too, its the inverter type. I finally found the instructions. It goes in lock when start is pressed 3 times. It can be unlocked by pressing the stop/reset button 3 times, the clock should come back up in the display window. Good luck
Jul 07, 2009 | Panasonic NN-T888S Convection/Microwave...
EM-G4753
I did a google search for the service manual and found one from Sanyo support. From that I was able to figure out how to open the unit safely, and find the fuses and safety switches to check. I found a loose wire plugged onto the main interlock switch (don't know how it worked all this time for how loose it was...). Re-attached it, and now it works fine.
WARNING! There can be very hi voltages on the inside of the uwave so you really need to be careful and know what you are doing! Also, you need a special bit to remove a couple of the cover screws.
Apr 14, 2009 | Sanyo EM-P410W Microwave Oven
LG Microwave won't turn off
Our LG did the same thing - called customer service and they told us the open and slam the door 10 times. It actually worked! It reset the switches somehow.
Apr 02, 2009 | LG LMV2053 Microwave Oven
MMV5000BAW maytag over-the-range microwave
Found this in the GE section instead of Maytag, but we're happy to answer it anyway.
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Let us know if the hard reset doen't fix it.
If not, you may have a shorted keypad or bad control panel, either of which we can repair economically.
Please write back with more details if you need further help.
Nov 25, 2007 | GE JVM1870 Microwave Oven
Microwave timer going too fast
I had the same problem and found that the "demo mode" had been enabled. Turned it off and everything worked fine.
Nov 10, 2007 | Whirlpool MH6130XEB/Q Microwave Oven
Emerson MW8987B/W Microwave Oven Logo
73 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
