Question about Oster 76076-010 Hair Trimmer
Replacement on off switch on a a5 oster trimmer
I took off the on off switch and cannot remember where to connect the wires
  • 22 Answers
Here is the complete service and schematic for you. :)
http://www.peasridge.co.uk/clipper-advice/clippers-products-oster-a5.shtml
Posted on Feb 02, 2009
  • rggp Jul 14, 2014
    The above link no longer works. Here is part list and schematic.
  • rggp Jul 14, 2014
    http://www.clipperrepair.com/parts.htm?m...
Oster a5 clipper not cutting,blades are new,a5 is new,2 days old
make sure the blades are connecting to your clippers turn the clipper on and attatch the blade they should click into place and should not pull off untill the release latch is depressed.
Aug 08, 2010 | Oster 76076-010 Hair Trimmer
Got a new switch...need a wiring diagram..oster a5 two speed
I have found the wiring diagram that you are looking for. Go to http://www.clipperparts.com/schems/oster/professional%20clippers.pdf
I believe you are looking for the diagram on page 18. Hope this helps.
Apr 14, 2010 | Oster Golden A5 2-Speed Universal Motor...
Put new switch oster 76 forgot how to wire it back
middle wire goes to incoming power an the other two wires get connected to the terminale that sets against motor,was wondering where you bought the switch
Jun 20, 2009 | Oster Golden A5 2-Speed Universal Motor...
Run but will not cut
Are you sure you have Andis A5 or did you mean Oster A5 Clipper, if this clipper is A5 Clipper, You need to check the Lever for wear, The front of the Lever show wear on both side, Like white color and is not squad this Lever is worn. Need to replace. This Lever moves the blade side to side fully. if the Lever is worn the blade will not move fully side to side and the cutter blade the smaller blade will stay in the middle with hardly no travel to side to side and will not cut the hair even if you purchase new blades. Also I would like to mention if the Oster Locking Hinge is worn out and don't have the require tension to hold the blade in place the blade will not cut. How do you test the Oster Hinge on a Oster A5 Clipper,
(1) first close the hinge, in close potion with your finger nail try to open the Hinge, if the hinge slightly open or opens loose the Hinge is worn. if the Hinge is good it will not open or move and your nail may just brake your nail.
Many of my customers run into this type of problem, and the problem can be solve easily by checking these parts first.
One more item I would mention here if replace the A5 Hinge make sure you get the A5 Hinge not the Oster 76 Hinge they are driferrent, The A5 Hinge has on the back two wire's sticking out that fit on the Oster Latch for the A5 Hinge, the Oster 76 Hinge would not have these wire's on the back. I recommend replacing the Latch when you replace the Hinge. I hope this helps any body that have a A5 Oster clipper or A Oster 76 Clipper.
I have over 20 years in the repair business of Sharpening & Clipper repair. Mannys Sharpening 323 263-4697
b61c252.jpgOster Hinge
Jun 10, 2009 | Andis Outliner II Hair Trimmer
Looking for switch wiring diagram for Oster Golden A5 two speed clippers..Replaceing switch and unsure of connections..
You must put the new one in exactly as the old one came out. Sorry, no diagrams unless you are an authorized dealer. Most of our repairs are common sense. No books. My husband just replaced mine today. Plus one clipper wasn't the switch as I thought, but was a broken wire in the cord near the clipper that kept shorting.
Mar 21, 2009 | Oster Golden A5 2-Speed Universal Motor...
I need to replace the 2 speed oster A5 toggle switch and the cord. Cant figure out how to put the wires back together
I have a picture of one, can you tell me where you got the new switch, I need to replace mine.
The center lead goes under the white wire.
The two end leads both go to one of the brass connectors
The black wire goes to the other brass connector.
Note the "Tab" at the top
Mar 11, 2009 | Oster Golden A5 2-Speed Universal Motor...
Oster 76 clippers
Here is schematic and instructions for service and repair. The model in the picture is the A5 however it is the animal version of the classic 76.
Oct 10, 2008 | Oster 76076-010 Hair Trimmer
How to put oster golden a5 two speed head on
Go to: www.clipperrepair.com and look at the diagrams. It might help you. Also, I went to Oster's website and found help there with internal parts.
Jun 07, 2008 | Oster Golden A5 2-Speed Universal Motor...
Oster 76
change the carbons
May 25, 2007 | Oster 76076-010 Hair Trimmer
Oster 76076-010 Hair Trimmer Logo
204 people viewed this question
Top Oster Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Michael Vincent Cruz
Are you an Oster Health and Beauty Expert? Answer questions, earn points and help others
