Question about Canon BubbleJet i560 InkJet Printer
Grayscale printing When grayscale printing is specified, the printer only prints random paragraphs/rows. To get the full print, the 'grayscale' box has to be unticked. I've downloaded the latest printer driver but without success.
  • 2985 Answers
SOURCE: Can I go to grayscale all the time?
Usually 'black' or greyscale uses all colours to get a true black in many printers. Check you particular printer manual and soft ware to see if it allows for black/grey only. You could experiment [I don't know this particular printer] by putting black carts in all slots [If it is a chipped cart you may have to consider swapping the chips on the carts if removable. Some specialist ink firms[Lycos] do supply monochrome sets for certain printers - check them out. Also take a look at
Posted on May 19, 2007
  • 184 Answers
SOURCE: Color toner used up even though I selected grayscale
Selecting grayscale only will also make use of your color. when u select grayscale, look under the print options and select black cartridge only and for more economic printing, use fast draft or draft printing.
Posted on Jun 09, 2009
SOURCE: My printer is out of grayscale ink. It will not
bukes1 is actually right. I have the same printer and I'm having the same problem. The MP980 has a black, pixel black, cyan, magenta, yellow, and a grey cartridge, so 6 all together. The grey replacement cartridge is not readily available at a store. You have to purchase it online. I don't understand why Canon does not include it in the color multi-pack. It's quite a nuisance, because when the cartridge runs out you can't print at all.
Posted on Nov 11, 2009
  • 4737 Answers
SOURCE: While printing in grayscale mode it is using color cartridges
Open the printer "print options" or "Print Settings" and select the "Black ink only". I am not very sure about your model, but when you carefully check, you'll see "print in color" "Print in greyscale" it should be somewhere below the "print in greyscale". Hope this helps. Good luck. Thanks for using FixYa.
Posted on May 30, 2010
  • 23 Answers
SOURCE: prints white vertical lines and out of focus on
printhead is faulty or if you using refill cartridges the filter in the cartridge is blocking not allowing the ink to flow to the head. this is common with refills
Posted on Nov 01, 2010
  • 186 Answers
SOURCE: I cant print in color plenty of ink it use to
reistalll your printer driver.
Posted on Apr 17, 2011
Testimonial: "THANK YOU..I WILL DO THIS!"
0 characters
1 Points
How can I print in grayscale on my Canon PIXMA MG8120?
That printer has multiple ways to print grayscale. The best is directly from the print menu, when you tell it to print, one of the things in the pop up box on most apps, like Word or Excel is "Options", or Print Options. From there you can set all kinds of things, and there should be a box you can check for Print Grayscale for whatever you are trying to print at the moment. You can also set grayscale as a default setting for all printing on your windows device, but then you have to tell it when you want color every time. Alternatively, on your Printers Menu System, on the third page of your little printer screen, there is a Settings option. This will lead you to all printer settings including grayscale printing setup.
Feb 17, 2015 | Canon Printers & Copiers
Color Cartridge out of ink - override/print in grayscale?
USUALLY there is a setting in the printer setup or propperties that you can specify gray scale right before printing. It normally is on the same screen that print preview is offered. Search the menu items for it.
Sep 24, 2009 | HP PSC 1315 All-In-One InkJet Printer
I have a canon BJC-3000. Do I have to replace my
Just select "grayscale printing" in the properties box for the printer. Open a document to print, when you get the "printer set up" box, select "properties, and look for a check box that says "grayscale printing" and check it. You will now print in B&W
Aug 24, 2009 | Printers & Copiers
When I want to print a clipart picture in grayscale, my printer still does a pinkish color. This is a problem with my church bulletin.
The software print setting is probably designated as color. Follow these steps to check this setting:
  1. In the software application you are trying to print from, click File , and then click Print . The Print dialog box opens.
  2. Make sure your printer is selected, then click Preferences . The printer Preferences dialog box opens.
  3. Select the Color tab, then make sure that the Print in grayscale option is selected.
Dec 14, 2008 | HP PSC 1410v All-in-One Printer
How do I print a selection from apage? and how do I print grayscale?
1) Let's assume you have clicked and dragged your mouse to select some text on a page. To print only the selected text, go to File (at the top of the page), then Print. You should then see a dialogue box which gives you the option to print a selection (on my hp printer, it is under 'Page Range').
You can also try the keyboard shortcut, Ctrl+P, to bring up the dialogue box.
Don't just click the printer icon you see on the menu, because that will print out the full page using your default settings.
2) You should be able to select grayscale by using the same dialogue box. Click the button marked 'Preferences', then the tab for 'Color' and you should see the grayscale option.
I don't know your printer model so the options may be slightly different for you, but hope this helps you get started.
Nov 16, 2008 | HP Printers & Copiers
How can I print Black only?
HP Inkjet printers work only if both the cartridges have ink unlike HP Laserjet printers.
If you want the printer to print only in black, Follow the steps
Start --->Control panel -- >Printers and faxes ---->Right click on the printer icon (HP c5100) select printing preferences.
Under printing prefences there u will see an option to print with black or print in gray scale.
Note:HP Inkjet printers like Photosmart C5180 will work only both the cartridges have ink.
Jul 26, 2008 | HP Photosmart C5180 All-In-One InkJet...
How to print with black/white only with brother MFC-3360C USB printer
Set the product software print setting to grayscale. Follow these steps to change this setting:
  3. Select the Color tab, then select the Print in grayscale option.
May 06, 2008 | HP PSC 1410 All-In-One InkJet Printer
HP deskjet printer D2460
Welcome to Fixya !
I assume that the printer is set to print in grey scale as below. follow the same procedure to change it to colour mode. If its still priniting in the Grey scale mode, Then please check the ink level in the printer.
Print in grayscale
To print in grayscale
1. Open the Printer Properties dialog box.
2. Click the Color tab.
3. Click Print In Grayscale.
4. In the Print In Grayscale drop-down list, select an option.
5. Select any other print settings that you want, and then click OK.
Apr 03, 2008 | HP Deskjet 2460 InkJet Printer
Printing in Grayscale or black
Too few manufacturers will allow their units to print in grayscale when a color toner is low or empty. The only way to get your unit working is by installing the required toner. By the way, start a budget to buy the transfer belt, drum unit, waste toner bottle and fuser unit. These are also consumables with a lifecycle.
Oct 01, 2007 | Samsung CLP-500 Laser Printer
Canon BubbleJet i560 InkJet Printer Logo
13 people viewed this question
Top Canon Printers & Copiers Experts
old marine
old marine
Are you a Canon Printer and Copier Expert? Answer questions, earn points and help others
