Question about IdeaSoft Scrapbooks Plus (727298900149) for PC
Acessing my pictures.
I am unable to get to my pictures through the software. I get to the my documents and my pictures comes up, but when I click on the button nothing happens. The only pics I can access are the ones in the tutorial. My computer operates with windows vista. Is there anything you can do to help me with this. My email address is belizabethb@yahoo.com
  • travisperkin Feb 25, 2009
    the tutorial. My computer operates with windows vista. Is there anything you can do to help me with this. My email address is travisperkins_10@yahoo.com
  • 849 Answers
Contact me on yahoo chat with same id as fixya, may i solve your problem
Posted on Nov 04, 2008
Using Word 97. Applied a backgound to a document. Saved and printed. Background not printing out or even showing in Print Preview? Thank you
To print the background in your document, do the following:
1) Open the word document and go to File->Print.
2) When the print window comes up, click the option button at the bottom.
3) Then,tick the Background colors and images as shown in the attach picture.
Feb 06, 2011 | Microsoft Word 97 (35100644)
What is the process to save a document or picture scanned with my HP Deskjet F4280? I am using Microsoft Windows 7. I am unable to install any HP software for this printer/scanner while using Windows 7.
There is no need to install any software for scanning from Windows 7 computer.
It's very easy
On computer click "Start" (windows icon)
click "All Programs"
click "Windows Fax and Scan"
click "Scan" and complete the scan as per on-screen instructions there
Make sure printer is turned on and connected to computer through usb cable properly.
Dec 23, 2010 | HP DeskJet F4280 All In One Printer InkJet
I am unable to manipulate a document after scanning it on our Netsacn 4000
Most of the scanners require that you set up the scan first and the software that comes with them will NOT do much if any editing. Be sure and export the document/photo in a FORMAT that is editable. Then use other software such as photoshop or MSWord to edit the document after. The software provided with scanners is usually pretty lame when it comes to editing.
Nov 18, 2010 | Visioneer NetScan 4000
How to upload picture in computer
Connect your digital camera to the computer through the usb cord. Click my computer and double click your files in the camera. Once all the file is displayed, press ctrl A to select all files and right click the mouse. In the drop down command select send to my documents. All the selected files will be transferred to your documents.
Nov 10, 2010 | Pentax Optio S4 Digital Camera
I am trying to get my dell v305w printer to scan and it keeps telling me downloading application list and then it says after 2 mins unable to download apps
The printer is trying to connect to your pc to download a list of programs to send the scanned document and/or picture to when you use your scanner.
The printer will only scan to certain software and there are separate choices for handling pictures and text documents.
When it tries to communicate with your pc to find software that it can scan to, its not finding any installed that will work with your printer. Its telling you that it is unable to get the list of applications after attempting to connect with your pc.
So, what does that mean?
It means that either "bi directional support" is not enabled in your printing preference so your printer is limited to sending info one way oly (to the computer). If this is the case you can go to your control panel and then choose printers and check the preferences listed there.
OR
You don't have applications installed in your pc that your printer can send scanned documents to.
If this is the case then you need to install software that your printer will work with and then set the options on your printer to pick the default you want to use with both pictures and text documents.
Printers usually accept microsoft word, word pad, microsoft works and any other word processing software to scan text documents to.
Printers usually accept just about any picture editing software installed on your pc to send scanned pictures to.
You can avoid all of the above by checking to make sure that your printers software is 100% installed including the scanning features. Go to the Dell website and update the drivers on your printer to make sure you have the full version that is most current.
The printer will always use its own program to scan both documents and text to regardless of the other software applications you might have installed on your pc.
Sep 27, 2010 | Dell V305w All-In-One R840635AU InkJet...
How do i scan a document and then email it
If you haven't done so, install the cd that comes with the HP Officejet package. Once correctly install, you should go to "All Programs" and locate "HP Solution Center" Click on HP Solution Center, click "Settings", click "Scan settings and preferences", choose either "scan document" or "scan picture" If word document then under File type: locate "PDF(*.pdf) If document is a picture then under File type: locate "JPEG image(*.jpg), click ok. Step 2 Choose between Scan Picture or Scan Document, click accept Step 3 your file is locate under "My scan" Hope that helps
Jul 10, 2009 | HP Officejet 5610 All-In-One InkJet...
Scanning a word document Deskjet F4180
Scanning a document is the same as scanning a picture, it must be done from within the document app. In this case I'm assuming you are using Microsoft Word.
Scan a picture and insert it in a document@import url(/Office.css); To do this procedure, your device (a scanner or a digital camera) must be connected to your computer and be TWAIN-compatible. You should also make sure that you have installed the device software that supports TWAIN.
Some devices come with more than one software program. If you are not sure what software is TWAIN-compatible, check the device documentation or contact the manufacturer of the device.
  1. Set up the picture in the scanning device.
  2. On the Insert menu in Microsoft Word, point to Picture, and then click From Scanner or Camera.
  3. If you have more than one device connected to your computer, select the one you want to use under Device.
  4. Do one of the following: If you want to use a lower resolution or you intend for your document to be viewed on the screen, click Web Quality.
  5. If you want to use a higher resolution or you intend for your document to be printed, click Print Quality.
  6. Do one of the following: If you're using a scanner and you want to use predefined settings to scan your picture, click Insert.
    If you're using a scanner and you want to change image settings, or if you're using a camera, click Custom Insert. Then follow the instructions that come with the device you're using.
  7. When the image appears in the document, make any changes you want.
  8. You can use the tools on the Picture toolbar to make changes such as cropping the picture, and adjusting its brightness, contrast, and color.
Note The Insert button might be unavailable when using some scanners because the scanner software doesn't support an automatic scanning. Use the Custom Insert button instead.
Sub HelpPopup(sFile,sID) L_SecurityT1_ErrorMessage="Help can't show you this procedure because the security setting in your browser is set too high" L_SecurityT2_ErrorMessage="or the ActiveX control Ouactrl.ocx didn't install correctly." L_SecurityE1_ErrorMessage="- Select a lower security setting in your browser" L_SecurityE2_ErrorMessage="- If you receive this message after selecting a lower security setting, please see your system" L_SecurityE3_ErrorMessage=" administrator for help troubleshooting the installation of the ActiveX control Ouactrl.ocx" L_SecurityE4_ErrorMessage=" located in the folder you installed Microsoft Office to." sSecurityMSG=L_SecurityT1_ErrorMessage & chr(13) & L_SecurityT2_ErrorMessage & chr(13) & chr(13) & L_SecurityE1_ErrorMessage & chr(13) & L_SecurityE2_ErrorMessage & chr(13) & L_SecurityE3_ErrorMessage & chr(13) & L_SecurityE4_ErrorMessage L_App_DialogTitle="Microsoft Office Help" On Error Resume Next r=oua.HelpPopup(sFile,sID) If Err0 Then Msgbox sSecurityMSG,48,L_App_DialogTitle End Sub
Dec 20, 2008 | HP DeskJet 3930 InkJet Printer
I am in need of a dimage software cd for a dimage 5digital camera, the current one is not opening, for instalation, I am unable to down load pictures Version 1.11windows. Compact disc, thank you for...
Alvin,
you do not need dimage software to download pictures. When you connect your camera to computer, your camera appears as a removable disk on My Computer. Acessing this disk you can copy all your pictures to a folder on your hard disk.
Nov 22, 2008 | Cameras
How do you Delete document and photos once saved to PC
I am using the Vista (Don't have any choice in the matter) OS. I finally realized I may not be able to find any solution to my inability to delete documents and pictures from the MP160 Navigator software so I tried clicking , 'Pictures,' located on the upper far right of the Start menu on my Vista start up screen. Then under, 'Folder,' on the far left of the 'pictures' screen I scrolled and found, 'pictures,' again cliked it and found 'MP Navigator,' under that category. I clicked MP Navigator and was given a long list of the photos and documents already on my MP Navigator software. When you click on of the image titles it will display the image or document. Then, while viewing the image or document, click the file menu, choose, 'delete,' and one by one you can delete the image or document if you want to. (James A. Baker-Opelika, Alabama)
Jul 04, 2008 | Canon PIXMA MP160 All-In-One InkJet...
IdeaSoft Scrapbooks Plus (727298900149) for PC Logo
114 people viewed this question
Top IdeaSoft Computers & Internet Experts
David Payne
David Payne
Are you an IdeaSoft Computer and Internet Expert? Answer questions, earn points and help others
