Question about NEC LT 260K Multimedia Projector
NEC LT260's shutting down
We purchased a lot of NEC LT260 video projectors and have had at least 10 of them stop working in the past 2 months...the lamp hours are low, so it is not a lamp issue, although the error seems to indicate a lamp error. Tey are dropping like flies...funny thing is they are dropping at the same rate that we installed them in...approx - 2 a day...any help would be appreciated.
Thank you -
I think I have solved this issue with my LT260K. I too had shut downs after 5 minutes of operation. It roughly followed a replacement of the bulb. I repaired stereos in the 70's and 80's, so I was not going to let the projector get the best of me without a tear down. I cleaned the fan blades, checked their operation. I checked the continuity of the thermostat on top of the bulb bracket, but found no apparent failures. I did find a possible loose connector in the middle of the projector as it seemed loose as I was disassembling the unit (see 1st picture). NEC LT260's shutting down - 7c58d4f.jpgThen I checked for cracked or burned areas on the PCB's. During this I scanned as much of the solder joints as I could. In the 'old' days, the power supply area could get hot and make cold solder joints. I found what appeared to be heat damaged solder joints on the auxiliary power board (Lamp power). This is the one that is back right of the projector opposite the power switch. It is a vertical board that solders into the horizontal bulb power board. I resoldered these and I am up and running. USE CAUTION, I would leave this to a trained professional to repair. This requires major disassembly.18d84c8.jpg
Posted on Jul 16, 2009
Vertical hazy lines are all that can be seen on my LT260 (nec)
make sure the lcd cables are secure in the main board. if that doesn't fix it the polarizers may be burnt.
May 11, 2010 | InFocus Proxima DP6155 Multimedia...
Projector says out of range
The native resolution on the 6100 is 800x600. I have had it recognize 640x480 and 1024x768 though. Check your computer to make sure the resolution is 800x600. Also set the refresh rate at 60htz, if the refresh is too high it can give out of range errors.
Jan 20, 2009 | BenQ PB6100 Multimedia Projector
Security code for Nec lt260 multimedia projector
The menu and logo password are the only ones you can reset by yourself, if you lose your master password you must contact NEC to get the release code.
See page 113 on the manual :
NOTE: Do not forget your keyword. However, if you forget your keyword, NEC or your dealer will provide you with your Release Code.
After you call NEC and get the code do the following:
1. Press and hold the POWER button for a minimum of two seconds.
The projector will be turned on and display a message to the effect that
the projector is security-protected.
2. Select [Projector Options] → [Security] from the menu and press hte ENTER
button.
The Release Code input screen will be displayed as well as your Request
Code (24 alphanumeric characters).
3. Enter your Release Code in the Release Code Input screen.
The projector will turn on.
* If the projector is turned on by entering the Release Code, your Security
will be disabled.
find contact page from here or call the retailer:
NEC Global
Here is also the remote
Sep 10, 2008 | NEC LT 260K Multimedia Projector
button.
will be disabled.
NEC Global
Sep 10, 2008 | NEC LT20 Multimedia Projector
Security code for nec lt 260
The procedure is the same for LT220, LT240 and LT260.
Here is the user manual
LT260/LT240/LT220 User’s Manual
Sep 09, 2008 | NEC LT 260K Multimedia Projector
Lt260 projecto
From user manual :
"In case you forget your passcode, follow the steps below to delete it.
1. Select the Advanced menu from the Basic/Custom menu. The Passcode
entry screen will be displayed.
2. Press the SELECT (up) button four times and then press the ENTER
button.
The "Warning Passcode!!" message will be displayed.
3. Press the SELECT (down) button four times and then press the ENTER
button.
4. Press the SELECT (right) button four times and then press the ENTER
button.
The "Delete Passcode / Are you sure?" message will be displayed.
Use the SELECT or button to select "Yes" and press the ENTER
button. Your passcode has been deleted."
Aug 05, 2008 | NEC LT 260K Multimedia Projector
Nec lt260
Clean optocoupler under pcb 4554B on color disc wheel.
Dusty on this part make not good sincronice with dlp panel.Good luck.
Jun 28, 2008 | NEC LT 260K Multimedia Projector
NEC LT260 PROJECTOR NOISE
To open this projector, you need to undo six screws at the underside of the case. That means you have to turn the projector upsidedown.
Pls note that one of these scews is a little hidden under the carrying handle.
After removing the screws, return the projector to it's normal 'up-side' up, standing position.
Remove the bulb cover srews and remove the bulb cover.
Lift up the top cover carefully starting from the front then all together.
The cooling fan is mounted very near the bulb assembly.
Carefully check the fan blades for any obtacles, wires or even a broken fan blade, that could be causing the noise.
Baba Anji.
Dec 18, 2007 | NEC LT 260K Multimedia Projector
NEC LT 260K Multimedia Projector Logo
979 people viewed this question
Top NEC Office Equipment & Supplies Experts
Electro Med Services...
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
