Question about Cyberhome CH-DVD 300 DVD Player
Aspect ratio I have a CH-DVD 300 and have not figured out how to see DVDs with 16:9 ratio on full screen.  They show up inside a 4:3 box whether I have the TV picture set to 4:3 or 16:9.  What am I not doing? Jim
Push setup on remote. go to video, select "16:9".
i was looking for a way to get rid of zoom logo from screen and decided to select 16:9 instead of 4:3 in setup. hope this helps
Posted on Dec 06, 2008
Jvc lt-47em59 picture too large in all aspect modes
Larger as in -- the screen looks fatter. 4:3 stretched to 16:9 or as in Larger as in, screen is longer but thinner? 16:9 / 10 fitting onto ratio 4:3?
Asuming... its the second one -- that ur screen is box 4:3 and the picture is huge 16:9 which is why u need to "zoom out" to get the full picture -- are u sure some idiot didnt mess with the settings and make the tv "zoom in" if it isnt a aspect ratio issue?
... if it is a aspect ratio issue, and ur using 4:3 (small old box televisions) there should be a ratio setting either on ur television OR on ur set top box, that would by defualt with digital tv have wide screen 16:9 -- id suggest finding the settings either on the tv or the set top box or...
just get a bigger tv that supports 16:9 cheap for 50 bucks.
Mar 17, 2014 | JVC Televison & Video
Does anyone know if the L37G10A supports PAL I as well as PAL B/G. I'm moving from Australia to UK and am wondering whether to bring the TV
Screen Type LCD Panel Type IPS-alpha Progressive Full-HD LCD Panel Panel Aspect Ratio 16:9 (Widescreen) Aspect Ratio Control Modes (TV/AV modes) 4:3, 14:9, 16:9, Just, Zoom1, Zoom2, Zoom3, DTV: 16:9 & 4:3 Full Aspect Ratio Control Modes (PC mode) 16:9, 4:3 Comb Filter Yes Progressive Scan Yes TV Tuner Receiving System DVB (Digital), PAL-B/G (Analogue) Tuner Type Integrated SD/HD DVB-T 7MHz Australia, PAL B/G
Contrast Ratio 1 - Dynamic: 20000 Picture Adjustment Modes / Film Modes Normal, Dynamic, Cinema, Eco Colour Temperature Control Cool, Standard, Warm
May 21, 2011 | Televison & Video
Hi. We have a Sony dvd player dvp-sr200p and have a wide screen tv, when we play a dvd we get a small square picture with black sides. We would like the have a full picture like we had before. Could...
With the player in STOP mode, or without a disc inserted, press DISPLAY on the remote. Then press either the UP or DOWN arrow keys (on remote) to scroll down from LANGUAGE setup to SCREEN SETUP, then highlight the aspect ratio which best suits the connected TV, in this case 16:9 widescreen (according to the manual the default aspect is 4:3 letterbox). Once you have made the change, exit the setup. It should remember the setting you have made.
Pages 26 to 27 of the owner's manual illustrate the setup procedure for this model DVD player.
NOTE: some DVDs may be encoded as 4:3 titles, hence you will see black borders at the left and right sides of a widescreen TV. Not all DVD movies are encoded in the 16:9 aspect ratio.
However, you can check your player's setup menu just to be sure.
Apr 08, 2011 | Sony DVP-SR200P DVD Player
I purchased a DVD that states: Widescreen Format (Aspect Ratio 1.85.1) I'm unable to get 'widescreen/letterbox'. The movie shows up full screen or a 'stretched' view. All other movies I've...
On the DVD recorder remote: press function menu button: enter setup screen - scroll down to connection - TV aspect - select either 16:9 / 4:3 Letterbox / 4:3 Pan&scan. If you are using an older TV which is not a widescreen, set the aspect to '4:3 Letterbox'.
You should now be able to view your DVD movies from this machine through a 4:3 standard TV in letterbox format. (some DVDs do not allow pan&scan so letterbox or widescreen is recommended). Very rare that a DVD title is not compatible with 4:3 TVs. I assume your deck is set to output 16:9 aspect by default.
I find this is the cheapest and easiest solution and can save lots of dollars in service call-outs. You can always reset the unit back to shipping condition later if you need to, or in the rare case of digital channels disappearing from your tuner memory.
Jan 09, 2011 | Panasonic DMR-EZ485VK DVD Recorder/VCR
How can I get full screen image without distortion on tv viewing? I only get 4:3, zoom, full and justified. Full looks stretched horizontally with tv, looks ok with dvd.
Hello
Most of the telivision transmissions are comes at an aspect ratio of 4:3. Wide aspect ratio is 16:9. If you try to see a picture with aspect ratio 4:3 to wide 16:9, it will look like stretched. it is not the fault of the tv. Most DVD recording have the aspect ratio of 16:9 [Wide]. This aspect ratio will be displayed correctly when your tv is also set to wide mode. If you select normal mode at this condition, the picture will be displayed elongated. Ok Your Tv has no probelm.
Oct 19, 2010 | Panasonic Televison & Video
I cannot figure out how to adjust the aspect ratio. The people look very FAT and I have never been able to adjust any T.V. using the buttons on the set. Help! 32" visio does not have some features on the...
Its not called aspect ratio on the TV menu. Its likely called 'Format'. It could also be called cinema, wide, 16:9,4:3, Picture, etc. The remote is EXTREMELY likely to have the picture adjustment button. 'Auto' should work the best.
However...
Most cable pictures are in 4:3. This will leave black bands on the side of the screen. Zoom helps, but you loose the top and bottom of the picture.
Most DVDs are 4:3 (Standard) unless you connect with RGB cables or HDMI cable. The DVD may need to be switched to Progressive to get the best effect. An upconverting DVD will have the most impressive results.
Mar 30, 2010 | Televison & Video
Occasionaly a wide screen dvd plays only in full screen
The aspect ratio on your DVD player is not set correctly. Look for a SETUP button on the remote control, there should be something like "QUICK SETUP" or something similar on the setup menu, if not then go to the menu that has the aspect ratio settings listed. Change your aspect ratio to 16:9 WIDESCREEN, and this should solve your problem. Your aspect ratio is 4:3 which is for a regular TV, if the images (especially people) look real skinny and tall on your TV then your aspect ratio is not properly set. Good luck to you!
Jul 30, 2009 | Oppo Digital DV-981HD DVD Player
Video files are not displaying right aspect ratio when copied in Windows dvd maker.
If you go into the dvd options dialogue, you find there a DVD aspect ratio option. This option lets you determine if a slide show on the DVD is displayed at 16:9 (widescreen) or 4:3 (standard) aspect ratio.
Alternatively: go into your settings and set 4:3 Pan & Scan or from 4:3 PS to 4:3 LB whichever your aim is or well whichever aspect of a movie you want to see.
If this helped please rate :)
Jan 19, 2009 | Computers & Internet
Wide screen movies dont fill screen
This is normal because they are broadcast in a widescreen format (If they fit the screen the aspect ratieo would be off on the picture!)
Dec 20, 2008 | Hitachi UltraVision 42HDS52 42 in....
Prob. with aspect ratio
The key word here is dropped,was the unit ok before? how hard was it dropped? if the tv is only a 4:3 screen then it can not give you a 16:9 AR unless the dvd can change that, it probably has the main circuit board broken somewhere and it needs professional help.Let's hope is not major damage.
Sep 19, 2006 | JVC AV-27D303 27" TV
Cyberhome CH-DVD 300 DVD Player Logo
110 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Electro Med Services...
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
