Question about Kodak EASYSHARE 5100 All-In-One Printer
Kodak 5100 all-in-one will not print B&W from pc.
It will not print B&W from the PC. It will copy in B&W fine from the scanner. I can also print color text from my PC. Just not black text or black parts of images.
I have replaced both ink cartridges. I have reformatted PC and reinstalled all printer software. Also ran all the normal printer cleaning and maint. Same result.
First Check if you are printing in true black ( not grey) and if you are not the call KODAK and have them send you a replacement printhead. (if still under warranty).
JaviTech... javitech@yahoo.com
Posted on Nov 09, 2008
The printer does not respond to print order. I get a message saying camera is connected, it is not.
The Camera Detected message is your PC detecting the scanner on the Printer - What happens when you try and print?
Also, try the following:
Remove the printer USB cable from your PC -> Restart your PC -> Log back onto your Profile -> Click on Start -> Control Panel -> Printers & Faxes -> Delete all printer entries -> Restart your PC -> Log back onto your profile -> Plug the printer USB cable into the back of your PC -> Go into Printers & Faxes -> Right Click on the Kodak 5100 AiO entry -> click "Set as Default" -> Now try to print.
Oct 13, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
I bought new ink for photo printing. On the printer it won't let me push the photo button only the copy and scanner one. When I print photos it is black and white and barely see the picture
For that problem kindly try doing the ff:
* Re-seat the inks both color and black then try printing
* Re-seat the Printhead of the printer then print again
* if problem still persist call 1800 421 6699 and the technical rep will replace the printhead
Hope this will help
Thanks
Byron
Sep 28, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Can i use my scanner without putting in a new ink catridge in
no,both ink cartridges should be installed into the printer.buy new ink cartridges from kodak online store if u want to buy.
Jul 16, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak ESP3 scanner problem
Uninstall the driver then after that install it again.If is not work reboot your pc.
May 19, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Printing too light
Kodak EasyShare 5100 series
Clean the print head then print a demo sheet.
  1. Verify that inkjet paper is loaded in the paper trays.
  2. On your desktop, start the KODAK All-in-One Home Center, then select the Help [?] icon.
  3. From the Help menu, select Maintenance, then select Print head Cleaning. The On/Off light flashes green during the cleaning procedure.
  4. When the On/Off light glows a steady green, press Photo and Copy simultaneously to print a demo sheet.
If the Demo print is bad- IE: no black, blurry print etc., then you may need to replace the print head:
http://www.kodak.com/global/plugins/acrobat/en/service/manuals/AiOPrinters/printhead/AUR1780-9_UE_RevC.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 12, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Will not print in black
This seems to be a common problem on the 5100
Contact Kodak Support who will ask you to re-insert cartridge, Print Clean, Calibrate and run print test (press Photo & Copy together) then tell you that you need a new Print Cradle! Which they will supply FREE of Charge by overnight carrier.
Mar 28, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
My kodak 5100 printer is having problems printing black text
Clean the printhead, then print a demo sheet.
  3. From the Help menu, select Maintenance, then select Printhead Cleaning. The On/Off light flashes green during the cleaning procedure.
If the Demo print is bad- IE: no black, blurry print etc., then you may need to replace the printhead:
Thanks, Joe
Dec 31, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
I have a Kodak easyshare all in one printer 5100
You need to clean the printhead of the printer to solve that
issue. Because everytime you print, excessive inks are going
to the printhead that's the reason why it's clogging the
system up. That's because Kodak printers is using
"pigments" as inks that's why Kodak printers are producing
high quality prints unlike other printers - a photo printed from
kodak could actually last for about 100 years. Now back to
your issue, you need to clean the printhead from the printer
but not manually. You could clean it by going to the
software of the printer namely the KODAK HOME
CENTER SOFTWARE. You need to click the "?" mark
icon on the upper right corner of the software window then
under the General Links select Maintenance then choose
Clean Printhead. Do it at least twice and then try making
prints. If that still doesn't work try calling Kodak Technical
Support Representative: 1-800-421-6699
I hope I have been some of help. ^_^
Nov 10, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Printer won't print
Printing on stand alone has a big difference when printing from pc.... try using the kodak website for this issue www.kodak.com/go/itg and use "image quality and blank page" for subclass
Oct 22, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Very poor B&W printing
First thing you can try is running the printhead cleaning. if you double click your status monitor (bottom right hand corner of windows screen) then click the maintenance button on the window. Then click the printhead cleaning button. Try this a few times then attempt another print.
If you dont have the printer connected to a PC there is a combination of 2 buttons on the printer you need to press to do a printhead cleaning. Not sure what they are.
If after you run a few printhead cleanings the black prints still dont print well, the only thing you can do is call kodak customer service they will have you update your firmware and software and reinstall the printhead a few times but in the end you can get them to send you a new printhead. The printheads are not sold in stores.
Good luck
May 19, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak EASYSHARE 5100 All-In-One Printer Logo
75 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
