Question about Canon Office Equipment & Supplies
We have a Canon Laser Class 700 series fax machine. When it runs out of paper in cassette tray 1 it doesn't automatically begin to use paper from cassette tray 2. Both cassettes have plain white letter size paper in them. How can I configure this?
    Genius:
  • 2,120 Answers
Swap cassettes.. The side guides on one of them may not be tight against the paper.
Only put paper in the lower cassette and try to print a journal.
Print out a configuration page or parameter list to see if the machine knows you have two trays.
Posted on Oct 30, 2008
I have a Laser Class 710 and the error light keeps blinking. There is a message that says "incorrect paper size received in memory". How do I get rid of this?
Someone has probably sent you a fax on 8 1/2 x 14 inch (legal size) paper. Pull down the manual hand feed tray which is located above the regular paper cassettes and place some legal size paper in it. Hopefully the fax will be outputted and the message will go away. Good luck.
Jul 15, 2011 | Canon LaserCLASS Fax 710 Printer
When recieving faxes on our canon laser class 2050p, the machine has a loud squeak
Your rollers will need to be replaces. Rollers feed the paper through the tray. You can find paper feed rollers for your device here:
http://www.precisionroller.com/paper-feed-components-for-canon-laser-class-2050p/products.html
They are very straight forward to install and instructions should be in your manual.
Mar 07, 2011 | Canon LASER CLASS 2050P
Paper tray will not load
Try switching the m/c off and on!its got a paper cassette arm at the back that needs to go into home position!Good luck!
Apr 07, 2010 | Canon CFX-L4000 Plain Paper Laser Fax
I keep geting remove MP paper
This indicates that the machine 'sees' paper loaded in the multipurpose (MP) paper tray. In order for the machine to print faxes and machine generated reports and lists, this tray must be empty as the machine prints from the cassette. Remove paper from the MP tray.
Jan 18, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
WE have a canon laser class 700 series fax machine. Is there a way to get an automatic confirmation to print after something has been successfully sent?
Press adisional funcktion button,select report settings,select TX report set it to "output on"
Then you will be able to receive the report for every fax you sent.
Dec 18, 2008 | Office Equipment & Supplies
Paper Size
double check the menu section is it set for Letter?
check the tray do you have Letter paper in it, are the guides set correctly?
Aug 19, 2008 | Canon LaserClass 2060 Fax
Paper Feed Not Automatically Switching to Multi-Purpose Tray
Sounds like the paper out sensor for the cassette is either broken or jammed. Pull out the cassette tip the machine on its back and you should see a black arm hanging down. This should be able to swing back and fourth freely. Unless it is missing or broken.
Jun 08, 2007 | Canon LaserClass 2050 Plain Paper Fax
MESSAGE O A PANAFAX UF-790 STATES CHECK CASSETTE MESSAGE IN MEMORY
Check cassette means the paper feed tray. Pull out the paper tray, put in fresh paper. Close the paper tray and see if it starts to print. If not, let me know Ed
May 30, 2007 | Panasonic Panafax UF-885 Plain Paper Laser...
107 people viewed this question
old marine
old marine
