Phone display says"Please insert SIM card". The card was not and is not removed. This happened all of a sudden. The phone was not dropped or mis-treated in any way. Thanks for any help!
You have most likely already checked this, but just in case.....make sure the sim card is full inserted, and inserted in the correct position. (There should be a diagram showing which way to insert the card.
Do you want to insert other network sim or if your Blackberry Curve 8350I displaying insert sim card,if already sim card inserted.Don't worry i will help you.You can insert other network sim card in the phone by unlocking the phone from current network lock.To unlock Blackberry Curve 8350I use unlock code.Visit the site Wickedunlock.com get unlock code and unlock it easily.Then insert any GSM network sim card.If the phone displays insert sim card even though sim card is already in the phone.Please remove the sim card and replace it correctly.It is because the phone didn't detect the sim correctly.After inserting if it is display invalid sim or sim not valid message on the screen.It is locked to some network,you need to unlock it.To unlock use unlock code.Get code from online site and unlock it.
Hi, when a phone displays an insert sim message, it means that either the Sim card or the Sim tray where the sim card is inserted in the phone.
First, You can use the sim card on another phone to be sure that the sim card is still working properly. If the sim works with another phone, that means the sim tray where the sim card is being insert into the phone is bad and will need to be replaced.
Hi,when a phone displays insert Sim, it means that the phone's Sim tray where Sim card are inserted in bad and can't make the Sim card display again .You'll need to replace Sim tray.
If the display says "Insert SIM," it means that the phone has no
contact with your subscription card (SIM card) that is inserted in the
phone. We recommend that you remove the battery and the SIM card, and
clean the connectors on the SIM card and the phone with a soft brush,
cloth or Q-tip moistened with any type of unflavored colorless alcohol.
At the same time, check that the card is not damaged or worn in
any way, in that case, the connector may not align with the connector
in the phone. Please contact your operator / carrier for a new SIM
card.
Insert ANY unaccepted SIM card
in the phone and then turn the phone on, follow the steps in 1 to 4
below to enter all the codes. The phone will states "Wrong card" at the
end of step 2 and "network lock deactivated" at the end of step 4 if
you do everything right so pls take your time to enter the code or
follow the instruction correctly at each step. When entering some of
the zeros at steps 3 and 4 your phone may display the zero as hyphen or
minus (-), dont worry, just count when entering the zero to ensure you
enter just the right numbers of zeros. Now let's begin...1/ Put any unaccepted SIM card in your SAMSUNG SGH Phone, turn the phone on, it will display "WRONG CARD"
2/ At the wrong card screen, type *7465625*638*00000000*00000000#
3/ Now remove the battery with the SIM card, Put the battery
back and turn the phone on again without the SIM card, it will display
"Insert SIM card"
4/ At the insert SIM card screen/end of step 3 above type #7465625*638*00000000#
At the end of step 4 phone will show "network lock deactivated"
5/ Now Reinsert your unaccepted card or any other unaccepted SIM card in the phone and enjoy your unlocked phone!
Insert ANY unaccepted SIM card in the phone and then turn the phone on, follow the steps in 1 to 4 below to enter all the codes. The phone will states "Wrong card" at the end of step 2 and "network lock deactivated" at the end of step 4 if you do everything right so pls take your time to enter the code or follow the instruction correctly at each step. When entering some of the zeros at steps 3 and 4 your phone may display the zero as hyphen or minus (-), dont worry, just count when entering the zero to ensure you enter just the right numbers of zeros. Now let's begin...1/ Put any unaccepted SIM card in your SAMSUNG SGH Phone, turn the phone on, it will display "WRONG CARD"
3/ Now remove the battery with the SIM card, Put the battery back and turn the phone on again without the SIM card, it will display "Insert SIM card"
its says please insert sim card the card is inserted what now
I can't find where to insert the sim card in this model/ please help :-)
