Question about Lexicon Lambda Usb Desktop Recording Interface Sound Card
Sometimes power comes on and sometimes it does not.
Some times when i turn on the computer the lambda works. the next day i turn on the computer and the lambda does'nt work.sometimes if i turn the computer off and then back on it works.
  • phatram Dec 07, 2008
    Same thing here... and I'm on Mac OS 10.4.11 (I downgraded from 10.5.2... and it was the same thing anyway). It's not a software issue I guess... I've tried more than one OS and it always do the same thing. You're lucky yours gets on half the time. Mine won't! Everytime I turn on my computer it won't start. I have to unplug/replug my Lexicon Lambda EVERYTIME. Now I took the habit of putting my machine only on sleep so it won't do it again. I guess the only REAL workaround would be to find a little applet that triggers the USB port ON and OFF everytime you boot your computer.
  • Anonymous Dec 18, 2008
    I have the same problem with Lambda and a brand new iMac
  • 3 Answers
Are you running Vista? Lexicon is working on some firmware and software updates to fix the problem. The only workaround is to unplug and replug your USB cable when it stops working. As long as you are actually using the Lambda, it should work.
Posted on Nov 15, 2008
Intermittant engine management light comes on after approx 250 miles when checked at dealers no fault showing but lambda sensor triggered warning now getting no abs or slip contol warnings on dash could...
abs problem will be a wheel sensor. if speedo working its not the pass side one. now for the lambda sensor. if you are traveling at 70 mph for 250 miles at a time this will over heat the sensor over time. as its a 2007 and normal running over time to replace them is 10 years. most that do over 500 miles a day would need to change them with in 2 to 3 years.
Mar 12, 2014 | 2007 Nissan 350Z
Code 29a8 power management failure, ldont understand the meaning
BMW outputs codes in Hex format. The tool then reads the code and it may translate it to its own format. Some 29A.. code definitions here:
29A0 Lambda Sensor Post Cat Bank 2 Signal
29A1 Lambda Sensor Post Cat Bank 2 Signal
29A2 Lambda Sensor Pre Cat Bank 2 Signal
29A3 Lambda Sensor Pre Cat Bank 2 Signal
29A4 Lambda Sensor Heater Pre Cat Bank 1 Activation
29A5 Lambda Sensor Heater Pre Cat Bank 2 Activation
29A6 Lambda Sensor Pre Cat Bank 1 Signal
29A7 Lambda Sensor Pre Cat Bank 1 Signal
29A8 Power Management Network Failure
29A9 Power Management Battery
29AB Torque Request via CAN
29AE Tank Cap
Code 29A8 i
t's a NETWORK management fault, related with tne main computer. Will need to visit BMW dealer to delete or reset it.
I hope helps with this.
Mar 17, 2011 | 2009 BMW 5 Series
Had trouble booting the computer over time. Sometimes power light would come on and nothing else. By unplugging, waiting 15sec it would power up. Over time this stopped working. Eventually power light...
Time to look for a new computer. That and take out your hard drive to copy your files over.
Sounds like motherboard problem. Probably not worth repair.
I've got an HP desktop with similar problems. It turned on one day just fine. The next day not. I don't even get the boot up screens. Disconnecting Hard Drive and CD/DVD components do not help. I should at least get some BIOS POST beeps and a Hard Drive Not Found or such. I do not. On occassion it will boot to a blank screen with white cursor in upper left. Most the time no screen at all. On rare occassion it comes right on and boots Windows. I guess it could be the power switch ... but I doubt that.
Nov 22, 2009 | E-Machines eMachines Desktop PC
The power button doesnt seem to be working
It sounds like a short in the button itself. If you have a soldering gun, take it apart and resolder the connection. This is typical for Acer laptops.
It's either the button itself or the jack where the power supply plugs in. It's not real difficult.
Jul 15, 2009 | Acer Aspire 5500 5570-2609 Laptop
36xbr800 sometimrs will turn on sometimes won't
it may be open contact on the flyback or
bad solder in standby power supply
Give it a smack open hand on the side
or better yet if you can have someone press
the power button as you rock it back and forth
this can tell you if its bad solder some times.
Jun 23, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Dell Dimension 5150 does not start
Could be a number of things, First take the ram out and then put it back in and see if that helps. next I would unplug any devices not required to start the computer.
You need to be familiar with the inside of the computer to do this.
Most likely suspect however is the power supply.
Jun 19, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Engine looses power, and abs, stc and lampasond lights sometimes comes on...
i had a problem in my S80 .Abs ,STC Brake failure,check Engine and speedometer all of tese didn't work , i just changed the ABS module...it's done now :) just perfect
May 18, 2009 | 1999 Volvo S80
Radio power will not stay on
Then you are saying the switches are part of radio? then the fault is with the radio, there is no computer that runs the radio. Pull the radio and send it out for repair through your local GM parts dept to a authorized GM repair facility, it is not user serviceable.
Jul 31, 2008 | 1993 Buick Century
Lexicon Lambda Usb Desktop Recording Interface Sound Card Logo
179 people viewed this question
Top Lexicon Computers & Internet Experts
Tony
aftab Nawaz
aftab Nawaz
Alun Cox
Are you a Lexicon Computer and Internet Expert? Answer questions, earn points and help others
