Question about Xerox Phaser 7700 Laser Printer
Xerox Tektronix Phaser 7700 Laser - Wrinkling paper slightly.
My 7700 prints fine. Colors are excellent. Duplex fine. Results are good. Except every piece of paper output is wrinkled on the trainling edge close to the middle left side. I would seem to think there is needing to be an adjustment done to a roller or something?
    Habit-Forming:
  • 25 Answers
Hy the problem is: You have to clean the 2nd BTR and the transfer belt cleaner. There is a large amount of used toner on those things.
Posted on Jul 08, 2009
Duplex printing in xerox 7700gx
Try add a printer and add a generic printer driver ( deskjet 990c), and try the Duplex printing. It should work.
Aug 03, 2009 | Xerox Phaser 7700 Laser Printer
Printer error - call for service, 9-911 what does this mean?
It will be best to run diagnostic tests on the printer and especially the electronics before coming to any conclusions. My first guess would be that some part of the memory went south. The test procedures are in the service manual which can be downloaded at: www.lpscomputer.com/ec/Phaser_7700_Service_Manual.pdf
Apr 16, 2009 | Xerox Tektronix Phaser 7700GX Laser...
Xerox phaser 7700 paper feed transparency errors
There is a Transparency sensor (called the OHP) which is part of the Registration Transport 116-1164-00
Clean it first. Or replace the whole assembly
Whit
Item, Inc.
Mar 24, 2009 | Xerox Phaser 7700DN Laser Printer
Phaser 7700 not booting up
a yellow line is comming on both sides of the printout when i print using my phaser 7700
Mar 20, 2008 | Xerox Phaser 7700 Laser Printer
Xerox Phaser 6120 color problems
I am running this one and I perplexed by what your saying.
Although I will offer some ideas.
I am running through my mind why the label would only affect the colors.
So some of what I am saying here is thinking.
That is a carousel color printer, and the label is confusing me, mainly since you said black is fine.
I can understand one color being off with the third party toners, but not all 3.
What you are having in some way has to be a contact issue, as if a piece of the label would up on a ground contact.
I would first try removing the transfer assembly, all the toners and the imaging unit, and carefully inspect for another piece of label.
Look at all the metal contacts on the cartridges and internally to the machine, see if one is dirty or somehow bent.
Go into you menus and run a color calibration series, and also do a memory clear, and NVM/NVRAM reset. But before you do any resets print out a configuration page to confirm your addressing if your using an Ethernet cable.
USB wont make a difference.
The reason I suggest the resets and calibrations is the label could have caused some high voltage arching and therefore corruption.
But, then again, why wouldn't that affect black and white. What does black graphics look like?
This one is making my mind spin.
Calibration makes sense because you say you have wrong color substitution, yet doesn't address streaky appearance That to me suggests a bad ground contact, But why only bad in color LOL.Ahhhh you have me nutty with this one. LOL.
I keep migrating back to software corruption or mis calibration.
Let me know if this makes sense or helps. Reading your problem makes me want to see this one.
Anyhow let me know if my rambling, which is rare helps.
Mar 14, 2008 | Xerox Phaser 6250DP Laser Printer
Phaser 8200
That normally indicated a heating issue with the print head. Could be the printhead itself or an issue with the electronics module providing the source voltage for that heater
Mar 12, 2008 | Xerox Phaser 8200 Laser Printer
Phaser 7700 Accumulator Belt Replaced, upon startup there is an error
POSSIBILITIES
Problem:
1st BTR Contact Failure or 1st BTR Retract Failure Message is displayed after replacing the Accumulator Belt Cause:
A Phaser 7700 Accumulator Belt was installed in a Phaser 7750. The Phaser 7700 Accumulator Belt does not have retractable 1st Bias Transfer Rollers; so these errors will be reported if one is installed in a Phaser 7750 printer. Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix. Remove the Phaser 7700 Accumulator Belt and install a Phaser 7750 Accumulator Belt. TRY FIRST (Solutions without parts):
1. Check that all shipping restraits have been removed.
TROUBLESHOOTING TIPS AND HINTS:
1. Test the 1st BTR motor in diagnostics to verify proper operation. 2. Test the 1st BTR sensor in diagnostics, then run the 1st BTR motor test and recheck the 1st BTR sensor. Sensor state should alternate between L and H. The sensor is part of the accumulator belt.
PARTS:Parts are listed in the order of highest probability for repair.
NUMBER QTY DESCRIPTION
116177400 1 *KIT IBT - UNIT
REPAIR/INSPECT/PREVENT PROCEDURE:
1. Clean feed rollers, exit rollers and guides; replace if
necessary.
2. Clean feed rollers and exit rollers only when dust or
debris is visible.
3. Remove and clean all paper trays.
4. Clean the Laser Scanner Unit window.
5. Inspect the image density sensors; clean if necessary.
6. Inspect the accumulator belt home sensor; clean if
necessary.
7. Inspect the fuser assembly; clean if necessary.
8. Print the Error Log, diagnose and repair any problems as
indicated.
9. Print the Usage Profile, diagnose and repair any
problems as indicated.
10. Check version of all installed firmware; as
appropriate, install the latest version of firmware.
11. Check cleanliness of interior and exterior of printer,
including fans; if necessary, clean (dust or vacuum) these
areas.
Problem:
Jan 25, 2008 | Tektronix Phaser 860DP Thermal Printer
Phaser 860 error code 07.003.45:116163
It is a print head tilt error.
Most likely ink is in the stainless steel pivot block at the bottom of the print head.
Also the printer could have been unplugged and the cleaning blade is stuck to the print head.
Or a cable is binding the print head movement.
Nov 12, 2007 | Tektronix Phaser 860DP Thermal Printer
Phaser 8200
Not a problem, but turning it off causes the machine to do a setup, which then purges the ink supply and is very wastful.
Mar 21, 2007 | Xerox Phaser 8200 Laser Printer
Xerox Phaser 7700 Laser Printer Logo
346 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
