Canon PowerShot A310 Digital Camera
Problem for Canon PowerShot A310 Digital Camera
Powershot A310 not able to sense the objects
By sailu on Sep 12, 2006
I am able to view pictures/video (taken already) from the memory card,But when I try to take new photos/video (after putting the camera in video/photo mode) I am seeing blank screen,i.e My camera is not able to sense the objects.
Can you please help me in this regard.
I have tried with different battery/memory card ,same problem.
Thanks
Sailendra
Same Problem
Jul 09, 2008
-   same problem cant take pics just get black screen but can view taken shots-   Guest
Jun 16, 2008
-   i have the same proplem as "guest" acording to canon this and other models are in for a recall and you can get a free repair regardless of warranty status-   brookm
May 19, 2008
-   Yes, i have the same problem. I can review the pictures, but when i want to take new pictures, i take "all black" picture-   Guest
Feb 17, 2008
-   When I go to take a picture it takes a while for the shutter to work and the flash doesn't work and the pictures come out real blurry.-   ggirl2582
Dec 11, 2007
-   I am unable to take a photo. The camera is on and I can view photos already taken, but the camera does not show an object to be photographed. I have checked and changed the batteries and even set the camera to the default settings. The camera worked fine the last time I used it.-   thompson113
Best Solution
posted on Nov 16, 2007
Very Helpful)
t00nz
Rank: Guru  Canon Cameras & Camcorders  Expert
Rating: 91%, 1999 votes
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110
Comments:
Was this helpful?
Yes
No
Solution #2
posted on Sep 14, 2006
Somewhat Helpful)
scrajmer
Rank: Wiz  Cameras & Camcorders  Expert
Rating: 81%, 500 votes
Normally there are two reasons for the given problem.
1). Bad or defective CCD. and/or
2). shutter not working.
in the first case the only solution is the replacement of the CCD. and in the later case sticking of shutter blade, non functioning of shutter blade will cause the problem. This can be rectified by sending it to some repairer.
Was this helpful?
Yes
No
Solution #3
posted on Jan 29, 2008
Not Rated)
t00nz
Know this is an old post, but for the three others who posted recently:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Was this helpful?
Yes
No
Solution #4
posted on Nov 24, 2007
Not Rated)
t00nz
jimmycurt, your problem sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
Was this helpful?
Yes
No
Solution #5
posted on Nov 15, 2007
Not Rated)
t00nz
Sounds like a defective CCD imager. You may be in luck. Canon should fix this for you for free, including free shipping both ways. Please check the following two links for more info:
Comments:
Was this helpful?
Yes
No
Popular Solutions for Canon PowerShot A310 Digital
Questions and Unsolved Problems for Canon PowerShot A310 Digital
Do you recommend Canon PowerShot A310 Digital Camera?
Answer
Answer
lcd view screen flickers bad when camera is turned on but when I take the picture it turns out... (More)
Answer
Hi My Canon A310 is not taking photos. Battery ok. Flash ok. Mem card ok. Have downloaded all... (More)
Answer
I purchases a cannon camera a couple of years ago and have since lost the download software. ... (More)
Answer
Hi, my camera worked fine, until recently. I go to plug it in and it says error messages.No camera... (More)
7 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Nov 15, 2007
camera worked yesterday. it powers on but will not take a picture. it flashes but no picture was taken .. i can view other picture on the card
Comment by jimmycurt, posted on Nov 02, 2007
After turning camera on, the screen has a gray background, with viewing area in the center of the screen, a horizontal line like this above the area 1------>2 with the viewing area below the horizontal line split in half with the left half dark and the right half white. There are also a few icons along the top border of the screen. It will take a picture when I press the button and flash, but the result is a blank screen. If I push menu, I get the record, setup or my camera. ????
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Canon PowerShot A310 Digital...:
Top Digital Camera Experts
Rank: Wiz Wiz
Solutions: 901
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Digital Camera Experts
Top Camera & Camcorder Repair
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
(915) 239-6199
CamerasAndParts.Com Specializes in the Service /...
CamerasAndParts.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
