Question about Microwave Ovens
Heating hello, i had posted a problem regarding the motor of my m/wave earlier too.faulty motor. i got the motor changed. now,after a couple of months the m/wave is making a good amount of noise ( motor,... ??) and heats up stuff fast enough to burn it if kept in the m/wave for the same duration as earlier. could you help out?
  • 1 more comment
  • pils Oct 31, 2008
    hi,
    something to add to the above info. if i get the power down from 100% to abt 60% then burning no longer occurs.
  • pils Nov 02, 2008
    hi,
    turntable's just fine. i had placed my smallish music system/radio besides it. anything to do with the frequency or magnetic field .. if the magnetron is abt to die off wht other prominent signs should i look for ..if any? in ur opinion is it better to get the magnetron changed or get a new m/wave. the local electrician says tht the windings on the transformer could also be "burnt". any chance of tht happening. thank you for ur time. extremely grateful to bounce off my queries on experts like urself. ty once again
  • pils Nov 18, 2008
    hello ,
    i shifted my music system away from the magnetron side of the m/w. the food doesn't burn anymore. could it be a coincidence or a mere relief in the eventual failing of the magnetron ? Is there some explanation to this phenomena ? could you help me out with this? i am confused so as wht to do. regards . ty
  • Microwave Ovens Master
  • 9,086 Answers
This overheating occurs most often when the either stirrer or turntable is not turning or the magnetron is beginning to die.
Posted on Nov 01, 2008
GE spacemaker GL1800 runs but does not heat
For that sound it will need atechnician but for not heating you cqn replace fuses
Sep 13, 2014 | GE SpaceMaker Microwave Ovens
Everything on my microwave is working except the heating and fan (clock, countdown, lite etc). Is it worth fixing? It is 5 yrs old
If there is no heating please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is faulty, the temperature cut off is faulty or the main capacitor is short. It is also quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron.
So Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off. Check the wave guide covers, if food had deposited
then it must be checked or replaced.
See link: http://www.espares.co.uk/advice/microwave/a/5/1146/how-to-replace-a-microwave-guide-cover.html
Now keeping clear of the microwave, switch on, use a cup of water inside to test.
If you notice any sparks shut off as the magnetron or the main HT capacitor can be faulty. replace with same type.Check the cost of a magnetron and estimate, wave gguides cost less and it is worth replacing.
If there is heating without any issues, you can use the microwave safely
Thank You for using FIXYA.
Sep 06, 2011 | Frigidaire FMV156DC Microwave Oven
My Kenmore Microwave, only a couple of years old, suddenly stopped heating. Everything else works fine. Model # 721.63242300
read the info on the below link, it was posted by me;
http://www.fixya.com/support/r7088553-microwave_oven_not_heat_hear_loud
Good luck.
Jan 14, 2011 | Kenmore Microwave Ovens
My samsung microwave oven is not heating up food. It works normally, lights on, food turning on plate, but not heating the food.
if your microwave does everything you have described , and you can hear the cooling fan running as well after you press the start button , you probably have a faulty wave guide. The wave guide is also called a Magnetron Tube. It is the main part of the microwave which produces the microwave energy . If this part is not functioning it is best to replace the entire unit, rather than have it repaired .
Oct 03, 2010 | Samsung Microwave Ovens
Oven stopped working except for the "express" button.
hello,
what is indicate i that there is a form of disconnection or loose of wire from the connection on the element i.e the heater it is silver in colour
what you have to do to fix up wave back to function is to (unscrew)open the wave then trace the wire down to the element to fine the loose wire then connecte it back to the element and then make sure there is no form of dirt or liquid form on the panel of the wave couple it back with this the problem is solve .
please when doing this put off all power supply connected to the wave.
than you and thanks for using fixa.
Jun 14, 2010 | GE Advantium SCA1001SS Convection /...
My microwave is 18 months old, only and it does not heat anymore nor does the turntable turn, what could be wrong?
HELLO,
THIS MEANS THAT YOUR WAVE HAVE DEVELOP MAIZE PROBLEM OR ELEMENT PROBLEM WHAT THIS MEANS IS THAT THE MAIZE HAS BEEN DISCONNECTED FROM IT POSITION BASS ON THE HEAT WHEN USING
SOLUTION TO YOUR MICROWAVE PROBLEM
PLEASE NOTE THIS
THE MAIZE MENTION ABOVE MEANS WIRE AND WHILE THE ELEMENT MEANS THE HEAT PROVIDER
UN SCROLL YOUR WAVE TO LOCATE THE MAIZE TRACE FROM THE ELECTRICITY DOWN TO THE ELEMENT YOU WILL SEE THE TRACE OF DISCONNECTION FROM THE ELEMENT THEN REPOSITION THE LOSS WIRE AND THEN COUPLE IT BACK HAS IT WAS.
AFTER ALL THIS THEN YOUR MICROWAVE WILL THEN CARRY OUT IT FUNCTION AGAIN
PLEASE MAKE SURE THAT YOU MICROWAVE IS NOT PLUG TO ANY FORM OF POWER SUPPLY
GOOD LUCK AND THANKS FOR USING FIXYA .
Apr 30, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Will not heat. has power going to transformer
There are a couple of steps you can do inorder to varify the main reason for your micro wave not heating.
Microwave doesn't activate / heat.
  1. Make sure microwave is plugged in properly.
  2. Check that door closes completely and its latch is aligned.
  3. Check that interlock switch in door works properly (required for activating microwave).
  4. Replace a blown fuse if it's accessible, or contact a service technician.
  5. Inspect plastic coupling beneath tray.
  6. Check ring and roller assembly for misalignment or debris.
  7. Make sure that tray is sitting properly on turning mechanism.
  8. If carousel motor is broken, contact a service technician.
  9. Make sure there's no aluminum foil or metal trim on dishware.
  10. Food residue or burned spots can cause electrical arcing. Clean chamber thoroughly. Replace wave-guide cover if burned or carbonized.
  11. Sand away burn spots, and smooth rough metal edges.
  12. Touch up spots with microwave interior paint if necessary.
  13. If chamber has burn holes, contact a service technician.
After doing these steps I am sure you would be able to figure out the problem area.
Please let me know if you need any further information.
God Bless.
Jul 09, 2009 | GE Microwave Ovens
Microwave dish/tray rotates intermittently.
If the turntable is not turning, you will get hot spots and uneven heating.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
You can get Samsung parts here.
Aug 03, 2008 | Microwave Ovens
Microwave Ovens Logo
144 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
