Question about Metrologic Instruments MK9540 (ITEMMK954032A38) Handheld
Fail to configure metrologic usb barcode scanner to use virtual RS232 port interface
I am using the Voyager MS9540 barcode scanner and i would like to configure my scanner to work like a RS232 Scanner. i followed the instructions in a pdf file named Metrologic Eclipse and Voyager barcode scanner interface options.Yet i encountered problem when i trying to install the virtual com port driver for the scanner. According to the document, a found new software wizard should be appeared after i scan a barcode with the value 316470, but it didn't appear. I did try to update the driver of the hardware with the virtual com port driver as well, but it's fail also. what should i do in order configure metrologic usb barcode scanner to use virtual RS232 port interface?
Thanks in advanced.
    Problem Solver:
  • 13 Answers
First check the com port speed of computer port which you connected scanner .Com port speed should be 9600.
To change com port speed in computer go to computer/properties/device manager.
Select the ports eg com1 .Right click communication port go to properties and select port settings Bits per second should be 9600.
Serial scanner can not be test in word or note pad.you can download the RS232 software from below link and test the scanner
http://www.lookrs232.com/
Posted on Sep 05, 2009
How i can configurate ms9520 by rs232 which command can i use
Scanners are programmed by printing the barcode & then scanning with them. For this one, go to https://www.honeywellaidc.com/CatalogDocuments/00-02544%20Rev%20K%202-11.pdf
print it & scan the relevant barcode.
Dec 16, 2014 | Microsoft Metrologic MS9520 Voyager...
What is the proper cable for my MS9540 scanner?
Now Metrologic is under Honeywell AIDC
Voyager 9520 9540 Laser Scanner Hand Held Honeywell
If not mistaken,the USB cable P/N should be MX009-2MA7S
Jul 24, 2014 | Metrologic Instruments MS9540 Voyager...
Voyager MS9540 scanner...how do I enable code 93?
Go to www.honeywellaidc.com and click on English under North America. In the search bar type in 9540. You should only get one result for Voyager 95X0 Series of Single-Line Laser Scanners. Click on the heading and under the picture on the tab bar choose documents. Under user Guides choose MetroSelect Single-Line Scanner Configuration Guide. On page 14 you will find the barcode to scan "Enable Code 93" . Page 14 is also labeled as 2-6. Good Luck
Oct 01, 2012 | Metrologic Instruments MS9540 Voyager...
What kind of cables do I need? my friend says that they are doggles - or something like that
RS232 Barcode Scanner Cable
Handheld scanner cable
Connector: DB9, DB15, RJ45
Cable: PU, PVC, 26AWG, 28AWG...
Application: Computer POS system, Scanner 0R Metrologic Honeywell barcode scanner MS9540 MS5145 USB Cable ???4 Similar from this Supplier Straight USB Cable with chip for Honeywell Metrologic MS5145, MS9540, MS9590, ETC....
May 04, 2011 | Computers & Internet
HOW CONFIGURE SCANNER VOYAGER MS9540 TO READ BAR CODE 39
THE BAR CODE IS READ CODE BUT NOT WRITE THIS CODE IN THE COMPUTER FOR EX: WORLD
Oct 23, 2009 | Metrologic Instruments MS9540 Voyager...
Connecting Problems with Metrologic MS9535 BT
hi
that you have cable usb?rs232?ps2?
You have the power adapter?
you have windows xp?
is not difficult
May 20, 2008 | Metrologic Instruments MS9535 VoyagerBT...
Metrologic USB Voyager scanner
refer the manual and scan the default barcode and scan the usb interface barcode properly.
Feb 01, 2008 | Metrologic Instruments 9520 Voyager
Metrologic Instruments MK9540 (ITEMMK954032A38) Handheld Logo
2,758 people viewed this question
Top Metrologic Instruments Computers & Internet Experts
xak_tay98
Level 1 Expert
Daniel Dollive
Daniel Dollive
jackcity
jackcity
Level 1 Expert
Are you a Metrologic Instruments Computer and Internet Expert? Answer questions, earn points and help others
