Question about Hotpoint Ultima WD72 Front Load Washer/Dryer
Check water supply error F11
My model is actually the WD71. A few times resently I have walked into the kitchen to find it beeping dipslaying the error F11 - Check Water Supply. The drum has had soapy water in it still so I've put it on a G rinse/spin cycle so i can open the door. It works fine again for a week or so then I get the error again. Any ideas ?
  • Anonymous Jul 26, 2008
    Washing machine has almost completed the whole cycle, it began to spin then come up with the code F11 what does this mean??
  • 67 Answers
Pump cannot be activated:check pump , connections and wiring
Posted on Jul 06, 2007
F11 error how to fix it?
F11 code is to indicate a shorted key on the touchpad, which explains your symptom...Replace the electronic oven control.
What is your model #? Help Me Find My Model Number RepairClinic com
Jul 24, 2016 | Frigidaire Kitchen Ranges
The electric stove I have is beeping f11 how do I stop it from beeping
I appreciate your inquiry, friend!
I see that you are having a difficult time with your Frigidaire range displaying an "F11" error code. That error code stands for a shorted keypad and I would recommend performing a reset on your range. You can do that by flipping the household circuit breaker off for roughly ten minutes. If you restore power and continue to receive an "F11" code you may need to replace the EOC (Electronic Control Panel) this is not a simple DIY job. I would recommend contacting a professional technician for proper disassembly and repairs to be completed. I hope this is helpful information. -Matt
Feb 25, 2015 | Frigidaire Kitchen Ranges
F11 and beeping
Unfortunately the f11 error means the clock is shorted. I have actually seen this issue several times on this unit. Its not your fault and theres nothing you did or could have done prevent this issue. You need to have the clock replaced to fix the error code. The clock on this model is the brains of the operations. Here is the part to order.
There is also a video on that parts page to show you how to make the repair.
All parts come with a 365 day, any part, any reason return policy.
Oct 25, 2013 | KitchenAid KESC307 Electric Kitchen Range
It show F11 Error code
Good Afternoon Friend,
I see that you are having trouble with your Frigidaire freestanding gas range showing an F11 error code. F11 means your appliance has detected a Shorted Key, which could also be a key that has been detected as pressed for a long period of time. This will terminate all oven activity. What you can do is to press the "Clear" key and if that does not work you will want to give your range a hard reset. You can do this by either unplugging it or cutting the power at the circuit breaker for 2-3 minutes.
After restoring power you will need to reset the clock. You will do this by entering in the time and pressing start.
Turn the oven on and if you are still receiving the F11 error code, I suggest either contacting the manufacturer or contacting your local authorized technician to diagnose your appliance. Hope this helps.
-Best Regards-
WP
Feb 07, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Error 16 on hotpoint wd71 n what does it mean???
F16 - Extremely high water level Disconnect or turn off the water supply and ensure that the water level does not rise any more. Then Book a service engineer
Mar 12, 2009 | Hotpoint Ultima WD72 Front Load...
Do anyone know what e11 mean on hotpoint wd71 pls
It means "No hot/cold fill" and recommends - Check the water supply, inlet valve and hot and cold hose connections.
Mar 27, 2008 | Washing Machines
Oven not working after controller beeping
if ihe oven is not working. ck ihe igeniter in side ihe oven it trun red hot when you trun the oven on
Dec 31, 2007 | GE JGBP33 Gas Kitchen Range
Have a magic chef oven, f1 display after self cleaning, stove top works fine, any thoughts
F-1 is a fault code.
Disconnect the power plug or turn range power off at circuit breaker. Wait a couple of minutes, then plug the range in or flip the range circuit breaker to ON.
Oven control beeps & displays any F  code error (for example
F11) - Electronic control has detected a fault condition. Press
CLEAR/OFF to clear the display & stop beeping. Reprogram
oven. If fault recurs, record fault number. Press CLEAR/OFF
contact an authorized service agent.
Dec 01, 2007 | Magic Chef CER3725AA Electric Kitchen...
Hotpoint Ultima WD72 Front Load Washer/Dryer Logo
303 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
