Question about Kyocera Office Equipment & Supplies
FS-1800 has E2 error. What is this and is it worth fixing?
anantakumarj
  • 330 Answers
SOURCE: getting a E2 error on Kyocera FS-1700+. Any ideas?
this service code belongs to Laser scanner unit (Polygon motor) error
check the connection between scanner unit and engine board .....
Posted on Oct 06, 2009
KYOCERA ECOSYS FS-1118 ERROR-C-6400
Error code relates to the fuser unit.Suggest that it is replaced.
Nov 16, 2011 | Kyocera FS-1118MFP Laser Printer
Error code E2 0012223
Laser scanner motor error. The polygon motor does not deliver a synchronous output (L) within the predetermined period of time. The scanner unit may need cleaning. be careful as there is a laser working in this area turn all power off before attemting. The laser unit sits under the top cover.
May 06, 2011 | Kyocera Mita FS 1700 Laser Printer
Getting a E2 error on Kyocera FS-1700+. Any ideas?
Oct 06, 2009 | Office Equipment & Supplies
Canon copier PC720
A E2 code deals with the scanner. The optics of the copier. Has itbeen moved resently? Your lens may be off it's track. Turn the copier off and remove the copy board glass and the Black Box and try to move the lens and the scanning mirrors to see if they can move smoothly. If not you have found your cause of the noise and what needs to be repaired. It may not be worth getting fixed. That is older model, it's up to you..
Jul 25, 2008 | Office Equipment & Supplies
Error Code explanation for Kyocera FS1700+
l e d are villings countineve one by one up to down
May 26, 2008 | Kyocera Mita FS 1000+N Laser Printer
117 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
NewYork kyocera HP...
Soulvisitor
Soulvisitor
Tech Bravo
Tech Bravo
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
