Question about Kenmore 43142 Front Load Washer
Bad Drum bearing need part number
I do not have a manual ,need to know what the part number would be for this bearing
  • 240 Answers
Im sorry, but the rear bearings (unless its changed just recently) is a non servicable part, you will have to replace the entire rear tub section. Also, most of the time, you end up having to change the inner tub as well, the shaft is usually wore out as well.
Posted on Nov 05, 2008
ASKO DRYER T700, DRUM IS MAKING BANGING SOUND AS IT SPINS.
Hi.
The loud banging noise in the spin part of the cycle is usually caused by bad drum bearings. The repair is carried replacing the bearing at the back of the drum. Such kind of replacement is carried disassembling most of the appliance to reach the back of the tub. If you have not done similar repairs before it may be better to call a technician ringing the Asko support number listed on the owners manual.
Regards.
Ginko
Sep 09, 2011 | Dryers
Kenmore oasis washer noisy when spinning
Hi, your probably right about the bearing its usually hard to tell untill they have compltely gone have you tried turning the drum by hand to see if it turns smoothly if it does then it could be the motor thats noisy both can be replaced but the drum bearing is a nighmare trust me you need pullers and its hard work.
So try turning the drum by hand and see if you can feel any roughness or catching this would tell you if the drum bearing has gone.
Let me know the outcome ok
May 01, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Does anyone know the rear bearings (2) and seal numbers for the drum? I have to replace them (along with the drum seal) like so many other have had to. I have the GHW9250MTO
Rear tub is 8181666 - subs to w10208156. It will come with a new tub seal.
If it has gotten really bad, you may want to aslo replace the basket, part number 8181668 - subs to W10269756
May 15, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Ave a loud noise coming from dryer when turned on. How do I know which part I need to replace. And where would I get the part(s)
You did'nt discribe the noise, could be a few things based on noise. Thumping could be a bad drum support wheel, Squeeling could be Teflon bearing strips on lower lip of front drum end, or motor bearings, or tensioner pulley, or belt slipping cause by weak or broken tensioner spring, for starters. A good source for ALL appliance parts is WWW.PARTSCLINIC.COM must have model & serial number, located behind door upper left,or in back on a tag.
Feb 13, 2011 | Dryers
Drum has sagged in front ,bad rollers or drum support? motor wont turn drum enless i kinda lift front of drum .i dont have the manuel.Dave
Hi and welcome to FixYa. I am Kelly. If you can provide me with a mmake and model number I can tell you exactly what parts to order and change including the source to correct the problem you describe.
These parts are in most cases are:
1. The drum bearing ring: (not always bad)
http://www.appliancepartspros.com/Appliance-Parts/WHIRLPOOL-Bearing-ring-for-front-support-item-number-AP2996731.aspx
2. The front drum (Replace)seal: http://www.appliancepartspros.com/part_details.aspx?part_id=3131525
3. The rear drum seal: (replace) http://www.appliancepartspros.com/Appliance-Parts/WHIRLPOOL-Rear-drum-felt-seal-with-adhesive--red-thread--item-number-AP3094149.aspx
4. Roller kit and belt: (replace) http://www.appliancepartspros.com/Appliance-Parts/WHIRLPOOL-Dryer-repair-kit--29-inch-large-capacity-models--item-number-AP3131942.aspx
These are the most common failures. I would recommend ordering and replacing all parts 2 - 4. Doing this will ensure your dryer will last for a long time trouble free. (tumbling)
See this manual for general help: (Important)
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/4829abde74a34d7f85256ab000620794/$FILE/4322260.pdf
Thanks for choosing FixYa.
Kelly
Jul 29, 2010 | Dryers
My maytag model no.mav4755aww makes a whinning sound at the beginning of the spin cycle
Hi
Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.Since you hear whining it means that the bearing is damaged and the seals on bearing are gone too so it rotates without lubricant. It might be possible to hear whining while you rotate empty drum manually...
Turn the drum by hand and listen for loud noises. If the drum itself is split or the 'spider' is corroded, broken or has come apart from the back of the drum it will create a loud noise on every turn of the drum. When the bearings have gone bad, the noise is constant the entire time the drum is spinning.
Take the belt off and run the motor alone if you hear a high pitched squealing noise to check for motor bearing damage or wear. If you still hear the noise without the belt, it's the motor bearing.Then replacing the bearing is suggested.
Let us know if you want something more else accept the solution.
Thanks for contacting fixya.com
May 22, 2010 | Washing Machines
Frigidare ftw 647ghso thumping sound in one spot when i manually rotate drum sounds like its rubbing on something
Suspect a bad drum bearing or bent drum bearing shaft. When you rotate the drum, look for movement of the drum up or down while turning. If the drum moves suddenly, suspect the drum bearing. If it slowly moves up or down during turning, suspect a bent shaft on the drum. In either case, it is a major teardown to remove the drum from the outer drum case. If still under warranty, take advantage! Hope this helps!
Mar 05, 2010 | Frigidaire ATF6000ES Front Load Washer
Neptune MAH5500 Neptune has progressively gotten louder on spin. Very loud noise sound like bearing going. Continues to get worse. Can it be fixed or too expensive to justify?
Hi.
If you get a very loud noise coming from the machine, and this noise is louder when it spins faster, then it is often because of a problem with the drum bearing.
The drum bearing is bad, Check if the drum has excessive play.
To replace the part you take apart machine, undo the belt and depending on the model you may need to remove more parts.
To get a quote on repair call Maytag at the number listed on the owner manual, the machine may still be worth repairing.
You can find parts and diagrams for most models here.
Nov 14, 2009 | Maytag Neptune MAH5500B Front Load Washer
DRYER
you need to replace your drum bearings, you will need to pull the front off the dryer to get to them. They should only run you 6 to 10 each and you have 2 of them. If your handy you can do it on your own. Go to marcone.com with your dryers model # and you will see a diagram of the dryer and be able to order the parts. Good Luck, you can do it!
Jul 15, 2009 | Dryers
Squeaking
The squeaking is usually attributed to any (or all) of the following:
The drum support rollers
The rear drum seal
The front drum ring bearing
The front drum seal and bearing assembly
The Idler Pulley
Now before you throw yours hands in the air in a panic, these parts sound more technical than they are. All the bearings and seals for the drum are either felt or plastic, the drum rollers support the drum at the rear bulkhead, and the idler pulley is what the drive belt rides on. Searspartsdirect.com offers excellent illustrations to show you where these parts are located. Just type in your complete model number and there will be a part listing with part numbers on the next page. If the model number you posted this under is correct the parts can be found under the following headings:
"Bulkhead Parts"
Drum Support Rollers (item 44) Part #349241T (pkg. of two)
Rear Drum Seal (item 66) Part #279857
Front Drum Ring Bearing (item 62) Part #279441
"Cabinet Parts"
Drum Seal and Bearing Assy. (item 38) Part #3406129
Idler Pulley (item 53) Part #691366
I list all these parts as a convenience in case you need to order any of them, and to help illustrate where these parts are located. You may not need ANY of them.
The drum support rollers require lubrication at the point where the roller meets the shaft with a light turbine oil. This should be done periodically to keep them rolling smooth. DO NOT get any oil on the rubber rollers or it may cause the drum to slip. You should also remove any build of lint before lubricating.
The drum seals can become brittle with age and start making noise as the drum rotates. This is particularly true with the rear drum seal. It will become discolored with age and turn brown in many cases. Inspect the front and rear seals of the drum for excessive wear. If parts of the seal begin to protrude into the interior part of the drum, this is a good sign that the seal is bad. The seals cannot be lubricated and will require replacement.
The idler pulley is a small plastic wheel on a shaft that the drive belt rides on. Lubricating the idler pulley wheel in the same manner as the drum roller supports is also required from time to time. DO NOT get any oil on the drive belt.
I know this seems like a lot, but a simple matter of cleaning and lubricating may be all that you need. If you require further assistance, please let me know. I hope this helps you.
Jul 24, 2008 | Whirlpool LER5636P Electric Dryer
Kenmore 43142 Front Load Washer Logo
56 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
