Question about Goodman CKL24AR24 Air Conditioner
Fan won't come on, either when heater or air-conditioner is turned on.
It's a Goodman model #PGB036100-1A. One day (couple weeks ago), the A/C was working fine, but then some moderate Fall weather came into the area, and I didn't use the A/C (nor the heater for a while). But now, the weather got cold, and when I went to turn on the heater, nothing happened (no blower fan at all). Then I tried the A/C, and it didn't work either. I tried putting the fan on "On" instead of "Auto", but that didn't work either. Any ideas? Thanks in advance.
  • 1 more comment
  • phillfam10 Dec 17, 2008
    I have a York system that has the same symptoms. We used the AC this summer, all worked great. But now the furnace doesn't work. We had is come on once and now nothing. I can't even get the fan to blow when I change the setting from Auto to On. Nada. I have checked the breakers, I have done the "reset" that the instruction on the inside door of the furnace suggested. I can here something running in the furnace, but no heat, no blower. Any suggestions?
  • Anonymous Jan 17, 2009
    We have the same problem. Last night we shut off the heat, went to bed, woke up, turned the heat on and nothing. I checked all the above and still nothing. THe night before when we were playing cards, I thought I heard a strange sounding faint noise that I never heard before. It was like the blower fan needed oil. I dont know where this fan is though.
  • Anonymous Apr 13, 2009
    I have a Goodman GUX060-3 and the burner will ignite but the blower won't come on in the Auto mode. The fan does come on in the manual setting but I believe that is tied to the AC control. Any ideas? I'm thing it is the fan limit control.
    Novelist:
  • 124 Answers
You have lost all control voltage. that is generated in the furnace. either the transformer has failed or the fuse in the transformer board has blown or the circuit breaker to the furnace has tripped or you have an open circuit to the furnace in the high voltage wiring. grab a volt meter and start with checking high volts at the furnace and back to the panel. if you have volts then start checking to see if transformer is generating low volts. as a side, if this is a furnace be sure the door is on secure and the door safty switch is depressed or guess what! no fan no volts no nothing. if any lights on board are flashing etc then you have power and it becomes a control problem. be sure your low voltage is getting sent to the stat via red and common on the furnace terminal board. good luck
Posted on Oct 30, 2008
Ac compressor fan running backwards.
Fan motors have rotations, clockwise and counter clockwise, lead end and opposite lead end. If you are looking at the motor from the fan blade side and the wires are on the back (opposite) side of the motor then you are looking at opposite lead end. Then you need to determine the rotation of the blade. It will scoop the air, so turning the blade that direction will give you the rotation. They also sell motors that you can change rotation by changing certain wires they have added.
When you replace a motor you need to notice the rotation and order that rotation. which end of the motor you are looking at to determine it. Then order the same rotation when buying the new one.
May 30, 2014 | Goodman CKL24AR24 Air Conditioner
I have a goodman furnace/air condition. The fan
start winding going bad or capisitor, either can cause high amp draw and over heat the motor
Jun 13, 2010 | Goodman CLQ36AR49 Air Conditioner
I have a central air and heat heat uses gas so when the heat is on should the main fan be turning
Typical systems are designed with a thermostatic "fan limit switch" which protrudes into the heater (house air portion of the passages). The "fan limit switch" is mounted to, and protrudes into the duct within the burner section of the heater, near the heated metal.
This switch triggers the circulating fan to turn on only after the sensor (thus air) within the duct has reached well above ambient temperature. This design prevents the fan from coming on sooner and the system blowing cold air, which people don't like.
Depending on system design, installation and current operating conditions, the time delay from main burners on to fan on can be up to a couple of minutes.
This same limit switch, if the temperature goes high enough, will also turn the gas valve off; a fire safety function.
Jan 06, 2010 | Goodman CKL49AR49 Air Conditioner
Oustide unit fan won't work
It sure sounds like the out side condenser fan has gone out.If you need to Fix a water hose to run on it like a spray fanning out over the out side coils(condenser)and try and see if it will cool.It will do the trick,until you get it fixed on week days.If I can help,let me know.>>>roniecon@gmail.com
Aug 16, 2009 | Goodman CLQ36AR49 Air Conditioner
Goodman AC fan working but not cool air.
0204 built the second week of 2004 sound like you have a loose or burnt wire in the a-c and arcing when the unit comes on. turn the breaker off next time you fix an outlet
Aug 02, 2009 | Goodman CKL24AR24 Air Conditioner
3:00am my a/c fan stopped turning but about 3 weeks ago i replaced the run capisator
My first guess would be the capasitor too..
If you have a tester - see if there is power getting to the fan motor..
If its getting power - it should be a faulty fan motor..
Hope this helps !!
Please rate me good ;o)
Jul 11, 2009 | Goodman CKL60AR60 Air Conditioner
Outside a/c fan quits but compresser still runs
it sounds like the fan is over amping itself and shutting down on thermal overload check the amp draw during running time and compare it to the sticker on the outside panel it should be running .9 amps, and it will over heat if it runs around 1.2 amps or above
Jun 21, 2009 | Goodman CLQ36AR49 Air Conditioner
Goodman model cpe30-1ab heat pump fan not turning. Air is coming in. I have a call into the repairman, just want to get a headsup. At one point I saw smoke coming out of the unit.
usually if the fan failed the heater will overheat maybe the smoke you saw was coming from the heater. Let the repairman to repair the fan.
Jun 08, 2009 | Goodman CLQ36AR49 Air Conditioner
Goodman CKL24AR24 Air Conditioner Logo
3,024 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
