Question about Gateway MX3215 Notebook
Up grade for processor
What's the faster processor for up grade the Gateway mx 3215? How many pins has the mother board?
Thank you!
André / Brazil
  • John Peel
    John Peel Nov 11, 2008
    Current Processor -
    Intel® Celeron® M Processor 360
    1 MB L2 Cache | 1.4 GHz | 400 MHz FSB
    Im looking for something faster.....
    Genius:
  • 1,605 Answers
You can only upgrade cpu with the socket you have, which is 478/479, the best you can do the Intel 1.6Mhz M processor 725
if you want a faster CPU, you need to get a new motherboard.
Posted on Oct 30, 2008
Cpu upgrade
Talk to an IT teckie but there are some many up grades for processors that they do not always fit older mother boards. You may have to up grade the mother board to achieve what you want.
May 05, 2013 | Computers & Internet
Can I use P4 478 processor in K8V-MX mother board
You can not use intel ,It is a athlon platform Mother board.
Follow the link, and you can know every thing from here.Just click here.
Hope it will help you.
Regard's
Shibuda.
Dec 31, 2010 | ASUS K8V-MX Motherboard
Asus Mother Board(P5GV-MX) display off, Boot time sound also off, The ram is OK. Processor can't check. Please give me solution.
Oct 18, 2010 | ASUS P5GV-MX Motherboard
Machine is not booting
  • I know what is your problem?May be problem on your HDD you change it then solve your problem.If you are not fix,You need Fox con MX PK g31 chip mother board.It is very adjustable motherboard for pin less p4 HT processor.
Mar 19, 2010 | Intel D946GZIS Motherboard
I have a gateway MSII have a gateway MSI Ms-7399 mother board. I have an E6300 pentium dual core processor at 2.8 with a FSB at 1066,in it and it works fine. I want to know what the specs on the board are...
The board is maxed out at 1066 and it does not appear that gateway has a BIOS update to allow for the higher FSB reuired with the faster Intel chips. If you installed one of these newer LGA 775 chips into your computer it may work but would be a lot slower than what it is rated due to the chips multiplier would be set for 1333. I could not see any BIOS updates from gateway for this board. Also these chips are designed to run with the faster memory and the 800mhz memory speed would also be a bottle neck for your system.
Oct 10, 2009 | Computers & Internet
Power connections for tower led's
The manual in question can be located here
http://download.intel.com/support/motherboards/desktop/sb/d1047103_en.pdf
It is a pdf file, so you will need ADOBE,
I have checked and the pinout for the front panel connectors is there.
May 24, 2009 | Intel D945GTP Motherboard
ASUS M2N-MX SE Plus mother board windows 2003 audio drivers
It is better to install   windows xp..  because   2003  is not supportting  latest mother boards.
only windows xp  will solve that problem
thank u.....
Nov 19, 2008 | ASUS M2N-MX Motherboard
Pls help me how to solve the asus K8V-Mx mother board
you could check if the pins of the processor aren't bent or broken...(even one single pin will make the processor malfunction and in your case it might not boot up) or you could have wronk ram modules so check the motherboard supportedmodules and check the modules you currently own.
Oct 30, 2008 | ASUS K8V-MX Motherboard
Processor for P5VDC-MX
Hey there alcouto, your motherboard supports Intel Celeron, Intel Pentium 4, and Intel Pentium D processors. The socket set is LGA775. The FSB should be no higher than 800Mhz. It appears you have purchased the wrong CPU for your board. I hope the rest of the info helps you on your next purchase. Good Luck!
Jan 29, 2008 | ASUS P5VDC-MX Motherboard
Gateway MX3215 Notebook Logo
166 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
