My toshiba m105-s3074 lcd blank
My lcd screen looks blank but hold a flashlight up to it reveals the images are there. How do I fix it? Laptop Toshiba M105-S3074
  • diecastbutch Oct 30, 2008
    According to Toshiba, the switch that turns the screen on and off is the problem but I can't find the switch.
    Problem Solver:
  • 11 Answers
The lcd would probably have to be replaced. you should take it into a local repair shop.
Posted on Oct 30, 2008
Manual for toshiba m105-s3074
Go to this link:
Satellite M105 S3074 Support Toshiba
Select the MANUALS AND SPECS tab. Download your manual. You'll need Acrobat Reader to read it. If you don't have reader, go here:
Adobe Adobe Reader free PDF viewer download
Hope this helps!
Jan 01, 2015 | Toshiba Computers & Internet
My toshiba l355d black screen all fans and lights are working
There are several reasons that your Toshiba laptop screen may not come on, even if the laptop appears to be running, and several options you may try to get your screen back up and running without an expensive service call.
Common causes for a blank screen include a backlight that is turned off, a display toggled to an external monitor and improper shutdown errors.
To avoid blank screen errors after your current error is fixed, make sure to follow all instructions in your user's guide to care for your Toshiba computer.
Shine a flashlight directly at your screen and look for an image.
If you see one, this means the backlight on your laptop is off but the screen is still working. This backlight normally turns off only when your screen is closed.
Look for a small metal or plastic pin near one of the screen hinges.
The screen pushes this pin in when it is closed, so if the pin is stuck in the screen closed position, the backlight will remain off.
Tap the pin several times to release it.
You may need to use a small object, such as a pencil tip or straightened paper clip, to reach it on some models.
Monitor Toggle
Press and hold down the "Fn" key if you do not see an image when you use the flashlight.
Tap the "F5" key several times while the "Fn" key is pressed.
This will cycle your screen through the various options that toggle the display to an external monitor.
Attach an external monitor, restart the computer and try this method again if no image appears on the laptop screen.
Click "Start," "Control panel," "Hardware and sound," then "Device manager" using the external monitor if you get an image there but cannot toggle the image back to your LCD.
Select the "Monitor" option to expand your selection and select your LCD monitor from the device list.
Click the "Driver" tab and select "Update" to update the driver, as this error is likely caused by a software driver error.
Force Restart
Press and hold the power button until the computer shuts down completely.
Check the indicator lights at the edge of your laptop to see if the computer is truly off or if it has simply gone into hibernation mode.
If it is off, all lights will be off except the battery-related lights if you have a charger plugged in. In hibernation mode, the power light will blink slowly.
Press the power button to restart the computer again after leaving it off for 15 to 20 seconds. This may fix the problem.
If the blank screen returns or you get a flash of images and then a blank screen, move on to the next step.
Force Power Down
Unplug your laptop from the power source.
Remove the battery by pressing outward on the battery latch and pulling the battery unit completely out of the computer.
Press the power button several times to completely discharge the computer.
Replace the battery and plug the computer back in after about 30 seconds.
Press the power button to turn on the computer.
If you get an error screen upon startup, choose to restart Windows normally.
This error is caused by improper shutdown procedures.
Hope this helps
Nov 03, 2012 | Toshiba Satellite L355D-S7901 Series...
Hi can You tell me where can I find all drivers for toshiba satelitte m105-s3074 for Windows XP (SP3) ????? Thank You a lot for Your help :)
Here it is, Please follow the below link and download all the drivers you need for your PC Notebook.
Its an official Toshiba website.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1372985&rpn=PSMA0U&modelFilter=M105-S3074&selCategory=3&selFamily=1073768663
Cheers
Nov 02, 2009 | Toshiba Satellite M105-S3074 Notebook
Need the driver of m105-s3074 i can not find on site
You can download any/all the Windows XP or Vista device drivers for your model laptop from the Toshiba WEB site from their download page.
Make sure you enter the model of your laptop so you can get the correct drivers.
Use this link :-.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp#
Apr 06, 2009 | Toshiba Satellite M105-S3074 Notebook
Memory slot #2 in the Toshiba Satellite M105 - S3074
The second memory chip is directly under the keyboard. you need to gently pry off the plastic cover above the keyboad that has the speaker grid on it. under there you will find the screws to remove the keyboard and then under the keyboard you will find the additional chip. I maxed mine out with 4gb. but since I'm only running 32 bit it only uses 3gb. If your gonna upgrade be sure to do it in pairs.
Mar 17, 2009 | Toshiba Satellite M105-S3074 Notebook
Screen blank
The problem is likely the inverter for the LCD screen. Do a search on laptop screen repairs and you'll find out more about it. doc...
Aug 25, 2008 | Toshiba Satellite A15-S127 Notebook
BROKEN LCD... BURNED TRANSISTOR
better bring it to the toshiba service center
Apr 10, 2008 | Toshiba Satellite M105 Notebook
Computers & Internet Logo
183 people viewed this question
David Payne
David Payne
