Operating Systems
Problem for Operating Systems
Generic problem for all Operating Systems
Nvidia driver issue with vista I think
By AKleiman on Oct 30, 2008
A couple days ago my driver started to fail but then recovered each time.  My screen would go black and then go back to normal in a few seconds.  Last night after my computer went to sleep mode this morning I can't even get into window without hooking up an external monitor and even then only to Safe mode.  The blue screen of death tells me nvlddmkm.sys Address 8B880E060 base at 8B808000. Datestamp 47317db2
I think it's a driver issue but I've tried updating it in safe mode and no luck so I tried rolling it back no luck.  Please help if you can, I need the computer for my wedding coming up next week, it's got all the music on it!  I managed to back up all my data files last night (had a bad feeling) but I'm not sure how to restore the comp (or if that would work) without losing all my programs.
Comments:
Oct 30, 2008
- Where do I find the nvidia directory?  But your solution seems to be on track another guys suggested I try deleting that file and I did and it got me into windows but with really messed up graphics and no way to change resolution.  I've readded the file to the system32 directory but can't find the nvidia directory
Oct 30, 2008
- I've found like 8 files all called nvlddmkm.sy_ and chose the most recent one that says vista32 in the folder column and tried the DOS expand.exe thing by typing: EXPAND.EXE nvldmkm.sy_nvlddmkm.sys but then it says: No destination specified for : nvlddmkm.sy_nvlddmkm.sys I'm not to sure where to go from here.  Please advise.  Thanks again.
Oct 30, 2008
- Ok I managaed to expand the file but same result.  Do I delete any of the old files in system 32 that have the same name?  Also which of the nvlddmkm.sy_ files should I be uncompressing.  There are 8 of them in different folders: WinVista 32 (C:\SwSetup\SP34602) WinVista 64 (C:\SwSetup\SP34682)WinVista 32 (C:\SwSetup\SP35880)WinVista 64 (C:\SwSetup\SP35880)WinVista 32 (C:\SwSetup\SP38280)WinVista 64 (C:\SwSetup\SP38280)WinVista 32 (C:\SwSetup\Video)WinVista 64 (C:\SwSetup\Video)
Oct 30, 2008
- I deleted the nvividia and all nvlddmkm.sys files from windows\system32 and windows\system32\drivers.  Restarted, got into windows with messed up graphics, it automatically re-installed the driver, I restarted, got blue screen of death.  Now can only get to windows safe mode and the nvlddmkm.sys file is in windows\system32\drivers but is file version 7.15.11.6743 created 11/7/2007.  This is different from 2/2007 ver 7.15.11.0065.  Ideas?
Same Problem
May 14, 2009
-   Where can I find the nvidia directory ?
Thanks -   Catty86
Solution #1
posted on Oct 30, 2008
Somewhat Helpful)
frcs68
Rank: Wiz
Rating: 82%, 992 votes
you are right insaying that is video porblem. here is the fix.
This is what appears to happen.during the installation of the most current drivers 100.65 Vista, an OLD file nvlddmkm.sys is copied into windows/system32/drivers and not the current one
in the install. As a result the new drivers are attempting to access a file
dated 11/2006 instead of 2/2007 ver 7.15.11.0065 which is in the newest WHQL
driver ver 100.65 vista 32.
Fix: Go to windows/system32/drivers and rename nvlddmkm.sys to
nvlddmkm.sys.old. Go to the nvidia directory and find the file nvlddmkm.sy_
and copy it to windows/system32. Using the cmd window (DOS box) type
EXPAND.EXE nvlddmkm.sy_ nvlddmkm.sys. When the expansion is complete, copy
the new nvlddmkm.sys to windows/system32/drivers and restart the computer.
Your computer should now work properly.
You will notice that any uninstall and reinstall of nvidia drivers will not
remove the old nvlddmkm.sys file and will not overwrite it with the newer
version. You have to do it manually. I do not know why this happens but who
cares as long it is fixed.
Good luck...
Comments:
Oct 30, 2008
- you have to specify the full path and the file name. no wild card.
Windows XP and Vista is not a full version of DOS.
expand.exe nvldmkm.sy_ c:\windows\system32\nvlddmkm.sys
Oct 31, 2008
- you did it the wrong way. you need to keep the Nvidia driver. and the nvlddmkm.sys, not the one from Windows.
I hope yu still have the deleted file int he recycle bin. if not, then you have to get a working machine and download the files for the video. uncompress it and put the file back where it should be.
like I say before the file is i Nvidia folder not the windows folder.
Was this helpful?
Yes
No
Solution #2
posted on Apr 23, 2009
Not Rated)
catherine854
Rank: Apprentice
Rating: 0%, 0 votes
I don't know much about computers and have been struggling for weeks to try and fix this issue on my Dell XPS 1330 (I uninstalled the NVIDIA drivers and allowed them to automatically re-install several times, which worked in the short term but the issue of frozen screen kept coming back). It seems that the solution several people have suggested is to update your c:Windows\System32\Drivers\nvlddmkm.sys file (I found a very old one there), but I couldn't actually find the NVIDIA directory on my computer (oops). Instead, I went to my Dell Support Center, clicked on "Drivers and Downloads" and found a "recommended" download (nVidia driver, under "video", near the bottom). This seems to have updated my driver software and has put a newer version of the nvlddmkm.sys file in c:Windows\System32\Drivers for me. I've only just done this so not sure if it has completely fixed my problem, but it was very easy for a non-computer person, so I thought I'd share it...
Thanks, Catherine
Was this helpful?
Yes
No
Popular Solutions for Operating Systems
Questions and Unsolved Problems for Operating Systems
Answer
How can I upgrade my royal 660 cashregisterlink to cashregisterlink pro
Answer
I have windows vista,when I try to open itunes it says,cannot open,file name is invalid or too long.
Answer
I loose my T mobile signal
Answer
Adobe Encore cs3 returns a message 'PGC internal software error' on burning DVD. Problem is always 2... (More)
Answer
my r 4 card just keeps saying loading
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Operating Systems:
Top Operating System Experts
Rank: Guru Guru
Solutions: 1459
Experience: I have owned a computer networking sales and service company.
Ask Me
Find more Operating System Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
