Question about Philips Magnavox 20MT133S 20" TV
Magnavox converter box turns off
I just set-up a Magnavox converter box & was trying to record a show daily while i'm gone & the converter box keeps turning off & not recording the shows right even though when i set it up i recorded what was on at that time to make sure everything was connected right & it does record just fine, however, the converter box jsut randomly shuts off... is it a setting in the converter menus i need to change or what? Can anyone help??? Thanks a bunch!! :)
There is a setting I think might be causing this. My mom had this
and we went into the menu and details there is a spot in there that
says 2 hour, 4 hour shut down and we turned it to off. Just a thought. Hope it works.
Posted on Jan 26, 2009
I got a magnavox dvd recorder and 4 head hi-fi stereo vcr and im having trouble with hooking it up to my cable box how do i record shows on my recorder without switching inputs on my tv because i switch...
Don't hook the DVD/VCR recorder through ur cable box.Hook the DVD/VCR recorder through ur tv only it should work find.This way each units have it own direct functions to the tv.U recording the shows from the tv not the cable box ok.
Nov 15, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
My Magnavox digital converter box shuts itself off every 5 minute
Check that you have not got an auto power off setting on. Check that the aerial connections are good. That the signal is strong from the stations it is picking up. Weak signals can cause the box to shut down.
It the box is very hot when it shuts down, you might have a fault on it.
Apr 04, 2017 | Philips Magnavox M61117 (DBM61117)
Vcr hooked to tv and converter box. Will not record digital chann
The vcr has to be set to channel 3 or 4. The converter box has to set to the channel you want to record the show from and left on during the time that the vcr is recording or you will get no recordings.
Apr 19, 2009 | Philips Magnavox DVD/VCR Dual Player
Magnavox DV220mw9 won't record from Tv, hard to connect
check out this diagram, paying close attention to the audio video cable hookups.
assume the cable tv box represents the converter box
you are going to come out of the converter box audio and video outputs into the new magnavox dvd/vcr combo audio and video inputs.
Then out of the new magnavox dvd/vcr combo outputs to the inputs on the tv if it has such inputs. The TV will have to operate on the video input 1 or 2 if the tv has such a thing, use the remote for the tv to adjust the input signal to line in 1 or 2 depending on what it has.
If the tv has no coaxial input or audio video inputs then you might have to use an adapter, you can get these from radio shack.
You say it will not record from the tv, but in all actuality the dvd vcr combo is getting the signal from the converter box not the tv, do you understand what I mean here?
So the dvd vcr combo gets input from the converter box so you will have to set it to view signal from the line input you have plugged in from the converter box. line 1 or 2 or whatever the input is.
the tv will have to be set on the line input to view the signal from the dvd vcr combo.
That is as easy as I can put it. Study the diagram closely. You will see what I mean.
Mar 07, 2009 | Philips Magnavox DVD/VCR Dual Player
Recording TV programs on DVD Recorder
if you are using a cable box / converter dvd-r and tv must be on ch 3.............
okay you dont have a cable box the tv is set to ch 3....the dvd-r, set up, initial settings and change cable to air...........then channel setting auto (scans all channels except HBO)...now you able to look at a dvd, record your show (s)
feel free to rate if helpful
Mar 02, 2009 | Toshiba DR410 DVD Recorder
Can play video, but can't record
Have you tried to record your channels with the converter switch set to antenna?
In otherwords;
Step 1. With your converter switch set to converter mode select the Direct tv channel you wish to record.
Step 2. With your converter switch set to antenna press the record button on your DVD Recorder.
Step 3. Switch your converter switch to converter mode.
I hope that you find this solution helpful.
Feb 06, 2009 | Philips Magnavox DVD/VCR Dual Player
Digital TV Converter Box
I have a Panasonic TV with built-in VCR, I had Comcast put in a converter box and was given instructions on how to set up the system to record my wife's programs, I had to select the program (in advance of scheduled time) to be recorded through the TV & converter box to the VCR. Next styep- select "Show" and I received a menu the first of which was "R" I clicked the "R" and a menu for selecting Repeat record start/stop times appeared Click OK and was then directed to to set up the VCR according to Panasonic VCR instructions. Worked for a day then the "R" menu on the converter box disappeared. Both the VCR and TV had to be set to Ch 3 to get it to work, But that's history. When it quit working ("R" menu), I had Comcast come get their box . PS The tech who showed up to pick up the converter box knew nothing about any "R" (record) menus except on the most ecpensive converter box. That cinched my decision, Oh Wel!. Sign me Tom with less trash to watch.
Jul 29, 2008 | Toshiba MV19N2 19 in. TV/VCR Combo
How to connect my dvd & vcr with the converter box
Here is my setup.
1) Separate DVD player 2) Separate VCR 3) Digital to Analog Converter box 4) Analog TV 5) Rabbit ears (UHF/VHF) antenna
The antenna goes into the converter box.   The RF-output of the converter goes into the RF-Input of the VCR The DVD output goes into the front input jacks of the VCR The VCR RF-output goes into the TV RF-Input The VCR Line output goes into the front of the TV
To watch DVDs, we turn on the DVD player, turn on the VCR, and set the VCR channel to L2, and tune the TV to channel 3.  The converter is off.
To auto record on the VCR, the converter must be tuned to the station being recorded.  The converted must be turned on, the TV can be off.
To watch VCR tapes, turn the TV and VCR on.  The TV is set to channel 3.  Just press play on the VCR.
To Watch TV.   Turn the TV and converter on.  The TV is set to channel 3.   Change the stations using the converter.
May 06, 2008 | Insignia Digital-to-Analog Converter for...
Magnavox ZV420MW8
This recorder only records inline. This means that there is no channel on recorder. It records whatever your satellite or cable box is showing. You'll have to change the channel on that.
I don't know that this will work for timed recording. You'll have to make sure that your cable/satellite is on and set to the proper channel before you leave. This wont work if you're recording multiple shows on different channels while you're gone. In that case you may need a different recorder.
Mar 16, 2008 | Philips Magnavox DVD/VCR Dual Player
Philips Magnavox 20MT133S 20" TV Logo
420 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
